Rich Posted January 9, 2015 Author Report Share Posted January 9, 2015 Yep I'll be doing that Nick but if I can pick up some sensors for a few quid it can't hurt to have spares to hand. Car is still starting first time and I checked the spark plugs when I got in, all 4 look like this, which I think are fine. Only took me 10 minutes but spent 30 looking for a nut I dropped! There's quite abit of rust in the engine bay and some of the electrical points could do with a clean. This is the stat/bottom hose, should I clean this up or leave it? Quote Link to comment Share on other sites More sharing options...
Tony Posted January 9, 2015 Report Share Posted January 9, 2015 If anything it looks like it's running lean. Quote Link to comment Share on other sites More sharing options...
Rich Posted January 9, 2015 Author Report Share Posted January 9, 2015 What makes you say that, the fact they don't look worn? As I said it wasn't that long ago I changed them, 2 years ago maybe and the car doesn't do much mileage. Quote Link to comment Share on other sites More sharing options...
liner33 Posted January 9, 2015 Report Share Posted January 9, 2015 Plugs look fine , slightly rich but consistent with your use. You can test for a vacuum leak by spraying wd40 or easy start over suspect connections , if the rpm rises you have a leak Quote Link to comment Share on other sites More sharing options...
Tony Posted January 10, 2015 Report Share Posted January 10, 2015 Running rich? I thought the light grey means running lean and hot. Quote Link to comment Share on other sites More sharing options...
Rich Posted January 10, 2015 Author Report Share Posted January 10, 2015 According to NGK they're good - http://www.ngksparkplugs.com/techinfo/spark_plugs/faq/faqread.asp?nav=31200&country=US Quote Link to comment Share on other sites More sharing options...
Tony Posted January 10, 2015 Report Share Posted January 10, 2015 Kind of suggests you don't have fuel issues then. Quote Link to comment Share on other sites More sharing options...
SMARTLY Posted January 10, 2015 Report Share Posted January 10, 2015 Kind of suggests you don't have fuel issues then. Not when the plug was examined, but something was causing not to continue running after starting ( possibly not enough fuel getting through ) and then not starting at all ( probably flooding ). Hopefully it was just a glitch. Quote Link to comment Share on other sites More sharing options...
liner33 Posted January 10, 2015 Report Share Posted January 10, 2015 Running rich? I thought the light grey means running lean and hot. you look on the white bit not the earth strap Quote Link to comment Share on other sites More sharing options...
Tony Posted January 10, 2015 Report Share Posted January 10, 2015 So it's a good burn then.... Quote Link to comment Share on other sites More sharing options...
NickT Posted January 10, 2015 Report Share Posted January 10, 2015 Have you done the basics first like change the fuel filter to an oem one? Quote Link to comment Share on other sites More sharing options...
Rich Posted January 10, 2015 Author Report Share Posted January 10, 2015 Have you done the basics first like change the fuel filter to an oem one? Fuel filter (Honda call it a strainer) is in the tank and is not supposed to be a serviceable item. The car has been used twice today with no issues so if the filter was a problem I don't think the car would still be running ok. I'll do some live data logging and see how it is when it's really cold again. Quote Link to comment Share on other sites More sharing options...
NickT Posted January 10, 2015 Report Share Posted January 10, 2015 Good luck with it Quote Link to comment Share on other sites More sharing options...
Tony Posted January 11, 2015 Report Share Posted January 11, 2015 Get some decent protective spray over the electrics. Quote Link to comment Share on other sites More sharing options...
Rich Posted January 11, 2015 Author Report Share Posted January 11, 2015 Like contact cleaner? Quote Link to comment Share on other sites More sharing options...
Tony Posted January 11, 2015 Report Share Posted January 11, 2015 Yeah or a silicon type of coating.... WD40 works good but it displaces water rather than protect from the effects. Quote Link to comment Share on other sites More sharing options...
SMARTLY Posted January 11, 2015 Report Share Posted January 11, 2015 Problem with using a protective spray or sealant is it seals all the moisture and dirt in - so has to be thoroughly cleaned and dried first. Quote Link to comment Share on other sites More sharing options...
Rich Posted January 11, 2015 Author Report Share Posted January 11, 2015 Sounds like it's something to do in the summer then. I just bought 4 x 500ml bottles of redex for £14 in Costco, that should last a while! In Asda that would've cost £32 as they only sell the 250ml ones. Quote Link to comment Share on other sites More sharing options...
Tony Posted January 12, 2015 Report Share Posted January 12, 2015 Don't put to much in or it will smoke like a bugger. Quote Link to comment Share on other sites More sharing options...
Rich Posted January 12, 2015 Author Report Share Posted January 12, 2015 No I'll only put the recommended amount in. Quote Link to comment Share on other sites More sharing options...
Tony Posted January 12, 2015 Report Share Posted January 12, 2015 With the correct amount of fuel in as well. Quote Link to comment Share on other sites More sharing options...
Rich Posted January 19, 2015 Author Report Share Posted January 19, 2015 Well the car has still been fine so god knows why it kept stalling the other week! Something I've noticed now is the rpm needle is doing the same as the Accord after I was unplugging sensors and re-charged the battery, which probably reset the ECU. When you release the throttle is jumps down suddenly and then rises again, I thought it was something to do with the drive by wire system on the Accord but the Civic is cable so it must be down to the sensors. AFAIK there isn't an idle learn procedure on the Civic. I still haven't got around to doing any live data logging yet so must do that. I topped the coolant up this morning, probably used 1/4 litre between the min and max marks and that was the first time in 3.5 years so I don't think it has any leaks. I can't actually remember what level it was at when we bought the car. The coolant was due a change at 100k miles I think, it's now done 120k. The cambelt is due in 10k miles so I'm not sure whether to change it now or wait until the the belt is done along with the water pump, it's been ok so far but I need to find my tester to check it. Quote Link to comment Share on other sites More sharing options...
Tony Posted January 19, 2015 Report Share Posted January 19, 2015 Cars and gremlins..... I know where your at because my Vectra started running like a dog, plumes of blue smoke when i stopped in traffic and the glow plug warning light started flashing... I had a meeting last week went back to the car turned on the ignition the light had gone off and the car run perfectly Quote Link to comment Share on other sites More sharing options...
Rich Posted January 19, 2015 Author Report Share Posted January 19, 2015 Random! I'm hoping it was just something simple like that fuel cut off switch tripping or blockage that has cleared. Quote Link to comment Share on other sites More sharing options...
Tony Posted January 19, 2015 Report Share Posted January 19, 2015 Personally i prefer the car to brake down so you can find the definitive reason for the problem..... Example a customer says his car vibrates at 70mph but not all the time then where do you start looking? Quote Link to comment Share on other sites More sharing options...
