Tony Posted June 29, 2010 Author Report Share Posted June 29, 2010 They want £880 to service the engine ...... Their having a laugh methinks. Get Tony to do it then I will Quote Link to comment Share on other sites More sharing options...
NickT Posted June 29, 2010 Report Share Posted June 29, 2010 They want £880 to service the engine ...... Their having a laugh methinks. Quote Link to comment Share on other sites More sharing options...
Tony Posted July 9, 2010 Author Report Share Posted July 9, 2010 Either the clutch doesn't like the hot weather or it's on the way out because i had loads of trouble getting it into gear and reverse was a hoot..... I think it has a hydraulic slave cylinder so hopefully it just needs bleeding. Quote Link to comment Share on other sites More sharing options...
Rich Posted July 9, 2010 Report Share Posted July 9, 2010 Either the clutch doesn't like the hot weather or it's on the way out because i had loads of trouble getting it into gear and reverse was a hoot..... I think it has a hydraulic slave cylinder so hopefully it just needs bleeding. Don't you just love old motors! Quote Link to comment Share on other sites More sharing options...
Tony Posted July 9, 2010 Author Report Share Posted July 9, 2010 Quote Link to comment Share on other sites More sharing options...
Tony Posted July 20, 2010 Author Report Share Posted July 20, 2010 Come to the conclusion the normally aspirated Lotus does not like hot air...... She stutters between gear changes like a bitch, popping and farting on over run like a gatling gun, she hits a dead zone on pull off almost like a stall. I know the Esprit is designed to "over fuel" but i think i'm punching flames out of the exhaust at the moment...... And another thing? what idiot decided to run the coolant pipes though the cabin, you can actually feel the heat from the pipes radiating inside the cabin Quote Link to comment Share on other sites More sharing options...
Rich Posted July 20, 2010 Report Share Posted July 20, 2010 And another thing? what idiot decided to run the coolant pipes though the cabin, you can actually feel the heat from the pipes radiating inside the cabin Nice drive to work then, gets you sweaty before you even start! Quote Link to comment Share on other sites More sharing options...
Tony Posted July 20, 2010 Author Report Share Posted July 20, 2010 I had a business meet in Watford this afternoon and i looked like i ran there.... They where genuinely concerned how hot looked. Quote Link to comment Share on other sites More sharing options...
parthiban Posted July 20, 2010 Report Share Posted July 20, 2010 what idiot decided to run the coolant pipes though the cabin, you can actually feel the heat from the pipes radiating inside the cabin That's the central heating Quote Link to comment Share on other sites More sharing options...
Tony Posted July 20, 2010 Author Report Share Posted July 20, 2010 Only problem with this one is can't turn it off..... Quote Link to comment Share on other sites More sharing options...
Rich Posted July 20, 2010 Report Share Posted July 20, 2010 I had a business meet in Watford this afternoon and i looked like i ran there.... They where genuinely concerned how hot looked. Should've said you got bird flu or something (depending on how well you know them!)...there's no way I could put up with that, once it gets above 20 that's hot enough for me. Quote Link to comment Share on other sites More sharing options...
Tony Posted July 20, 2010 Author Report Share Posted July 20, 2010 I told them i had "lack of money in the till a'tituse" and funnily enough they have the same illness. Quote Link to comment Share on other sites More sharing options...
Mark H. Posted July 21, 2010 Report Share Posted July 21, 2010 You do realise that a naturally aspirated car has no turbo Tony? Your turbo esprit has a forced induction engine, not naturally aspirated like the later V8 models. Quote Link to comment Share on other sites More sharing options...
Tony Posted July 21, 2010 Author Report Share Posted July 21, 2010 Ok what i mean is it's carburetors not injection. Quote Link to comment Share on other sites More sharing options...
adam_r Posted July 21, 2010 Report Share Posted July 21, 2010 Tony.. how can you confuse a turbo with a carb or injector ! Quote Link to comment Share on other sites More sharing options...
Tony Posted July 21, 2010 Author Report Share Posted July 21, 2010 Cos when it comes to engines i'm as thick as s***e Quote Link to comment Share on other sites More sharing options...
adam_r Posted July 21, 2010 Report Share Posted July 21, 2010 fair enough. i just thought you may have a little more knowledge as you do deal with some pretty nice metal : Quote Link to comment Share on other sites More sharing options...
Mark H. Posted July 21, 2010 Report Share Posted July 21, 2010 Ah ok, so you have a forced induction engine with a carb. Quote Link to comment Share on other sites More sharing options...
adam_r Posted July 21, 2010 Report Share Posted July 21, 2010 Ah ok, so you have a forced induction engine with a carb. pretty sure the lotus has a twin carb setup. old age stuff Quote Link to comment Share on other sites More sharing options...
Tony Posted July 21, 2010 Author Report Share Posted July 21, 2010 Yeah it does but i think they need tuning because on over run the exhaust pops and bangs like a bastard. Quote Link to comment Share on other sites More sharing options...
adam_r Posted July 22, 2010 Report Share Posted July 22, 2010 Yeah it does but i think they need tuning because on over run the exhaust pops and bangs like a bastard. Tony, you need to look about. There are some seriously good tuners out there who can set the carbs up properly and it will make the car better Quote Link to comment Share on other sites More sharing options...
Tony Posted July 22, 2010 Author Report Share Posted July 22, 2010 I found a farther and son operation in Watford who are Esprit specialists so i plan to contact them. Quote Link to comment Share on other sites More sharing options...
Tony Posted July 26, 2010 Author Report Share Posted July 26, 2010 Any idea what this holder is for on the dash Quote Link to comment Share on other sites More sharing options...
adam_r Posted July 26, 2010 Report Share Posted July 26, 2010 pen ? Cigar ? Quote Link to comment Share on other sites More sharing options...
Tony Posted July 26, 2010 Author Report Share Posted July 26, 2010 To tight for a cigar, i thought pen but there's no paper and why would you need a pen. Quote Link to comment Share on other sites More sharing options...
