adam_r Posted November 21, 2016 Report Share Posted November 21, 2016 Rich. Does the noise change when revved? That sounds like the timing chain has stretched. Quote Link to comment Share on other sites More sharing options...
NickT Posted November 21, 2016 Report Share Posted November 21, 2016 Take the belt of and run the engine briefly ie no more then 2 to 3 minutes (do this at your own risk etc. ) If the noise disappears then the problem is with the bearings etc in the belt driven area. If the noise still exists then unfortunately it's within the engine. Good luck. I hope it's with the belt end. Btw if you were nearby I'd recover the gas and recharge it for you in exchange for a detail, but I think traveling up north would be too far for you... Quote Link to comment Share on other sites More sharing options...
liner33 Posted November 22, 2016 Report Share Posted November 22, 2016 Rich. Does the noise change when revved? That sounds like the timing chain has stretched. Chains can't stretch , if the timing chain was loose the noise would be different and worse when starting up Quote Link to comment Share on other sites More sharing options...
Rich Posted November 22, 2016 Author Report Share Posted November 22, 2016 I haven't tried seeing if the noise changes when the engine is revved, I will have to do that. I had a listen before I went to work after just starting the car and it didn't sound too bad. When I got to work 15 minutes (5 miles) later I had another listen and that metal grinding noise was louder (but not as much with the new idler pulley) so it definitely seems worse when hot. That was going to be my next question, could I run the engine with the belt off as this also drives the water pump. As the noise is worse when it's hot should I go for a drive first then remove the belt or is this more risky than doing it from cold? I would only need to run it for less than 30 seconds to know or not. Quote Link to comment Share on other sites More sharing options...
liner33 Posted November 22, 2016 Report Share Posted November 22, 2016 Yes it will be ok for a short time Quote Link to comment Share on other sites More sharing options...
Rich Posted November 22, 2016 Author Report Share Posted November 22, 2016 I'll have a go on Friday then and see if it's still there - then I can faff around for 30 minutes trying to get the belt back on! Quote Link to comment Share on other sites More sharing options...
Rich Posted November 30, 2016 Author Report Share Posted November 30, 2016 I've not had time to take the belt off yet but I'm still having starting issues and getting annoyed with the car now, everything seems to be happening at once! The missus used it yesterday and said it wouldn't start the first time, it was very cold and frosty in the morning. It started the second time and was fine for the rest of the day. I'm using it today (frosty again) and the car didn't even turn over the first time, then the 3 yellow lights came on (ABS, warning, VSA). The second time there was a clunk and something felt like it was stuck and had freed up, the 3rd time it started. So I'm now thinking the starter motor might be playing up. So I might need a new starter now, plus the other noise in the engine bay and then there's a knocking from the front somewhere Quote Link to comment Share on other sites More sharing options...
Tony Posted November 30, 2016 Report Share Posted November 30, 2016 Is yours an auto? If not put it in 2nd and rock the car back and forth then try to start it again. Quote Link to comment Share on other sites More sharing options...
Rich Posted November 30, 2016 Author Report Share Posted November 30, 2016 Yep it's an auto and the starter is in a location where you can't hit it, under the manifold! I'll check all of the wiring and terminals to make sure they're ok but I think I'll just have to take it to the garage and get everything sorted. Or px it!! Quote Link to comment Share on other sites More sharing options...
Tony Posted November 30, 2016 Report Share Posted November 30, 2016 Would you px it really? Quote Link to comment Share on other sites More sharing options...
Rich Posted November 30, 2016 Author Report Share Posted November 30, 2016 In good condition it's probably worth £1,500 max for a private sale, how it is I reckon £500 px. Trouble is I've just spent £150 on new parts and £200 on new tyres the other month so I don't really want to get rid of it. If the compressor pulley is making that noise then a new one is over £250, starter is over £100, then whatever is causing the knock, possibly ARB bushes. I really need someone to look at it and tell me what's wrong before I decide what to do but I reckon I'm looking at another £500+. Quote Link to comment Share on other sites More sharing options...
liner33 Posted November 30, 2016 Report Share Posted November 30, 2016 did you check all the earths last time ? Quote Link to comment Share on other sites More sharing options...
Rich Posted November 30, 2016 Author Report Share Posted November 30, 2016 No only the battery one which looks ok so I need to do that, if I can find them all. Would the battery clamps benefit from a clean? Quote Link to comment Share on other sites More sharing options...
liner33 Posted November 30, 2016 Report Share Posted November 30, 2016 A poor connection would explain a lot of the issues you have been having so i would clean up every one you can find Quote Link to comment Share on other sites More sharing options...
Rich Posted November 30, 2016 Author Report Share Posted November 30, 2016 I'll have a look then. Just got home from work and the car started first time with no hesitation so something didn't like the cold the last 2 mornings. Quote Link to comment Share on other sites More sharing options...
Rich Posted December 1, 2016 Author Report Share Posted December 1, 2016 Doesn't sound good, I had a listen to some bottom end noises and it's very similar! Although it's noisier with the belt fitted, it's still there after removing it. Quote Link to comment Share on other sites More sharing options...
adam_r Posted December 1, 2016 Report Share Posted December 1, 2016 Oohhh is that your car in the bud? Deffo a mechanical twang in there. I would be tempted to drop the oil and do some fishing.. See if any deposits are present.. Certainly sounds like the start of a knock Quote Link to comment Share on other sites More sharing options...
Rich Posted December 1, 2016 Author Report Share Posted December 1, 2016 Yes that's my car in the video, doesn't sound good does it! I did the oil change 4 months a go and although I wasn't looking for deposits I don't remember seeing anything. I also don't remember this noise after doing the change as I would've warmed the engine after filling to check the level. I'm hoping to take it to a garage tomorrow and get a diagnosis but I'm already looking for a replacement. I can't see it being good news or cheap repair! Quote Link to comment Share on other sites More sharing options...
liner33 Posted December 2, 2016 Report Share Posted December 2, 2016 Its so hard to tell noises like this i'm sure a garage will be able to pinpoint it , as i said some thicker oil might help you get you a few more months even if its terminal Quote Link to comment Share on other sites More sharing options...
Rich Posted December 2, 2016 Author Report Share Posted December 2, 2016 I wasn't looking for a diagnosis on here, just showing the difference (or lack of) in noise with the belt on and off. Definitely engine related though. I'm waiting for the garage to let me know when I can take it down there. If it's terminal then I'll have to cut my loses and sell it for spares. So annoying when I've spent quite a bit making sure it'll last a few more years. I, like all of us on here make sure my cars are looked after, yet I seem to get the worse luck compared to those who don't! Quote Link to comment Share on other sites More sharing options...
liner33 Posted December 2, 2016 Report Share Posted December 2, 2016 if its bottom end you really need to try an oil change , some engines will quiet right up with some thicker oil it has to be worthwhile for £50-£60 Quote Link to comment Share on other sites More sharing options...
Rich Posted December 2, 2016 Author Report Share Posted December 2, 2016 I'll see what the garage says but if it is this then I'll try some thicker oil. What would happen if I just left it and used the car as normal? Quote Link to comment Share on other sites More sharing options...
liner33 Posted December 2, 2016 Report Share Posted December 2, 2016 it would just get worse and worse , unlikely just to fail though Quote Link to comment Share on other sites More sharing options...
Tony Posted December 2, 2016 Report Share Posted December 2, 2016 And i thought the engine was bullet proof Quote Link to comment Share on other sites More sharing options...
Rich Posted December 2, 2016 Author Report Share Posted December 2, 2016 They can't see it until Wednesday next week so will find out then hopefully what the actual problem is. Quote Link to comment Share on other sites More sharing options...
