Tony Posted September 8, 2011 Report Share Posted September 8, 2011 NSF Castor adjuster OSF Castor adjuster Entire subframe There's something very wrong here, do you know what it is? Quote Link to comment Share on other sites More sharing options...
SMARTLY Posted September 8, 2011 Report Share Posted September 8, 2011 Are those bits on the wrong side? Quote Link to comment Share on other sites More sharing options...
phipck Posted September 8, 2011 Report Share Posted September 8, 2011 those bolts look identical but should be a mirror image of each other, causing no end of terrible geometry stuff (thats as technical as i can be this eve ) Quote Link to comment Share on other sites More sharing options...
adam_r Posted September 9, 2011 Report Share Posted September 9, 2011 one adjuster is all the way forward and the other is all the way back giving a very weird angle(do you call it wash or something. i presume this in turn twists the alingment to one side of the car causing some very funky handling! Quote Link to comment Share on other sites More sharing options...
Rich Posted September 9, 2011 Report Share Posted September 9, 2011 The NSF bolt is the opposite of what it should be? Quote Link to comment Share on other sites More sharing options...
liner33 Posted September 9, 2011 Report Share Posted September 9, 2011 Where is the anti roll bar?? Quote Link to comment Share on other sites More sharing options...
Tony Posted September 9, 2011 Author Report Share Posted September 9, 2011 Your almost there other than the reason why the adjusters are in the position they are Quote Link to comment Share on other sites More sharing options...
adam_r Posted September 9, 2011 Report Share Posted September 9, 2011 I think i may have spotted it..... not sure i believe my eyes though.... is that subframe fitted incorrectly / damaged ? it looks like it is / has twisted towards the front nearside. Larger gap at the back of the subframe on the back right (offside) than the back left (nearside). Quote Link to comment Share on other sites More sharing options...
scorps Posted September 10, 2011 Report Share Posted September 10, 2011 N/S/F is a cut n shut....? Quote Link to comment Share on other sites More sharing options...
Tango Posted September 10, 2011 Report Share Posted September 10, 2011 Looks like the near side front has been jacked up, distorting the subframe Quote Link to comment Share on other sites More sharing options...
Tony Posted September 10, 2011 Author Report Share Posted September 10, 2011 Ok, out of your misery.. NSF has suffered some trauma, exactly what is impossible to say, nevertheless an impact on the NSF has moved the subframe back. The castor adjusters are NSF as far forward as possible and OSF as far back as possible. On another car this would be end of days but thanks to the MX5's over engineered adjusters we were able to compensate for the displacement. Quote Link to comment Share on other sites More sharing options...
Rich Posted September 11, 2011 Report Share Posted September 11, 2011 Shouldn't the subframe be repaired properly though, is it safe if it's been moved? Quote Link to comment Share on other sites More sharing options...
Tony Posted September 12, 2011 Author Report Share Posted September 12, 2011 It's not possible to move it back because it's bent. Since this car is adjustable, correcting around the bend is safe. Quote Link to comment Share on other sites More sharing options...
Rich Posted September 12, 2011 Report Share Posted September 12, 2011 So surely the best thing to do is replace the bent subframe? Won't this put stress on other suspension parts, even if the whole chassis is adjustable. Quote Link to comment Share on other sites More sharing options...
liner33 Posted September 12, 2011 Report Share Posted September 12, 2011 MX5 gearboxes are long arent they?? Quote Link to comment Share on other sites More sharing options...
Tony Posted September 12, 2011 Author Report Share Posted September 12, 2011 Yeah..... very old school i think. Quote Link to comment Share on other sites More sharing options...
