Lancer Evo 6
liner33
Bought my car this time last year , found the cleanest example I could with nice but subtle mods , previous owner had spent a fair bit on it shortly before I bought it but I’m pretty fussy
So in one year of ownership and around 5000 miles
Bits bought
Gizzmo MC-IBC Boost controller
Aux pulley
Aux belt
Aux tensioner pulley bearing
Oil temp gauge and sender
Gizzmo shift light
Kenwood Head Unit
Kenwood Ipod interface
Vibe amplifier
DLS front speakers
JBL rear Speakers
Fuel filler pipe
Rear lower arm inner and outer bushes
Rear shock absorber poly bushes
Eibach progressive springs
Whiteline rear ARB
Steering rack ends and gaiters
Track rod ends
New intercooler
Hard pipe kit
Stainless Turbo elbow
New Lambda sensor (OEM)
Japspeed downpipe and system
Willians Harnesses
Nevereverman shifter bushes and shifter base kit
Quickshifter kit
Type R gearknob
Kelsport heat shield
New battery
New actuator
Silicon coolant hose kit
Silicon intake hose kit
New set of wheels
SJS Carbon slam panel
US spec oil filler cap
R spec dump valve
E8/9 Metal type dump valve
Front strut brace
Openport cable and Ecuflash
Innovate LM Wideband logger
LH & RH Trailing arms (Was an advise on last months MOT)
Ralliart exhaust rubbers
Ralliart air suction and battery relocation kit
Other work done
In addition to fitting most if not all of the above
Removed fuel tank cleaned underside of car , painted and undersealed
Rebuilt brakes x 3 (Still squeal)
Cleaned lash adjusters (Still rattle )
Sprayed rocker cover
Removed turbo , replaced manifold studs , gaskets and manifold
Replaced every jubilee clip I could
Steam cleaned plastics and wet vacced interior
Alignment done three times
Replaced dash bulbs and climate control with blue leds
Tweaked the map myself a few times
Bled the brakes
Changed the coolant x 2
Changed the oil and filter x 3
Changed the plugs
Removed the SAS
Fitted camcorder mount on rear shelf
Replaced the washer jets with Volvo items
Fitted HID’s and then removed them in favour of uprated bulbs
Some befores
  • Replies 92
I had a dyno sheet when i bought the car which claimed 300hp at the hubs but it had been mapped badly and the boost was awful, the blow off valve was leaking and the tuner had maxxed the boost up to compensate , when i changed the BOV the boost hit 2 bar so first remap was required
Dyno graphs
Boost was all over the place resulting in low torque and jerky power delivery
Next graph shows a slight remap done by me and a boost controller fitted, much smoother
The aim was to make the boost a little more stable and to get the turbo to spool up quicker which has resulted in a big improvement at 3500-4000rpm
img003.jpg]
Torque is now better than I hoped and results are about right for a Evo 6 of this spec, next step would be cams and headwork which might yield another 20-30hp but may well sacrifice torque a little
What sort of MPG do you get out of these and I'm assuming it's run on VPower etc?
24-26mpg average over a tank usually always Vpower
Small tank though I set the trip meter as the gauge is hopeless and refill at 160 miles would possibly get 200-220 miles between fills at a push
As for not driving it 5000miles its almost twice what i did in my Skyline each year i did 9000miles in 3.5 years in that!!
That's pretty good, more than I thought they do...what size tank do they have?
Dunno for sure i've read anywhere from 8-11 gallons or 40-50 litres
Most people refill at around the 160 mile point , used to get 200miles between fills on the Skyline that was slightly better on fuel probably due to the longer gearing
Are all Jap fuel tanks that small cos the one on the Legacy is around the same size from what I've found out and the Impreza about the same? Considering you don't get many miles out of a tank it would save filling up so often wouldn't it. Maybe they're small to keep the weight down?
  • 2 months later...
Awsome work liner33..car looks great..love the evo 6the front end looks really mean.. :D ....keep up the good work..
I always like the evos but the servicing was a nightmare as it has to be done every 6 months.? is that right.? :D
yeah or every 4500miles but only takes an hour or so and easy to DIY. The AYC anti yaw control needs the oil changed every 9000 miles which needs specialist tool so garage job but no biggie
  • 1 month later...
Got a few jobs on the go , little things that all add up .
I removed some parts from the engine bay and repainted them
Converted the turbo elbow from bolts to studs as it wasnt sealing well (Not as easy as it sounds)
Refitted the downpipe as it rattled on the body
Refitted the front crossbrace as it rattled on the downpipe
Painted the intercooler
Fitted some new pipework for the intake
Fitted an Innovate LC1 wideband and did the wiring for the gauge (bought a 60mm gauge but dont like it so will get a 52mm one :lol:)
Fitted some later seats ,these have been custom trimmed in leather and alacantara and have heaters in them so more wiring to do if i want a warm bum
