Evolution of the Starlet
Bazza
  • Replies 280
  • Created
  • Last Reply
Top Posters In This Topic
Posted Images
250 bhp @ flywheel.... The term "clucking bell" was blurted at my monitor ;) .. no wonder your pleased, i mean the car weighs less then a nat's nut, 250 bhp is... well it's... it's... "scary"
its fun ! ..................scarey fun !
the test driver for Abbeys reportedly came back smiling :blink:
250 bhp @ flywheel.... The term "clucking bell" was blurted at my monitor :) .. no wonder your pleased, i mean the car weighs less then a nat's nut, 250 bhp is... well it's... it's... "scary"
the test driver for Abbeys reportedly came back smiling ;)
Jeramey Clarkson turbo Atom style kind of smile was it :blink:
Ive got an FCON for sale if you need it :)
Actually the plugs might jsut swap straight over , not sure ?
Sounds pretty good if you ask me, that getting on to 300bhp per ton isnt it ?
Doddys car magically stopped boosting the other day so i think race is off ,we're guessing actuators broken or snapped turbine shaft, either way its engine out :)
I think the next step will be to swap over to the Motec ecu !
far superior to the hks, and far more mappers available
Doddy scared off was he !! :)
Ive got an FCON for sale if you need it ;)
Doddys car magically stopped boosting the other day so i think race is off ,we're guessing actuators broken or snapped turbine shaft, either way its engine out :(
Doddy scared off was he !! :(
Nope he was really up for it, he came back from golf the other day and was going fine then nout nothing nudda no boost at all im just hoping its the actuator thats snapped/failed whatever as if the turbo's fooked its not good as it had a fulllllll over hall before being put back on the car and its was mega bucks.
Now yours can go so fast you'll need some good brakes barry ;) give me a shout if you want some of the good stuff hmmmm carbon :D
Doddys car magically stopped boosting the other day so i think race is off ,we're guessing actuators broken or snapped turbine shaft, either way its engine out ;)
Now yours can go so fast you'll need some good brakes barry :D give me a shout if you want some of the good stuff hmmmm carbon :D
pah ! brakes are for wimps :(
  • 3 weeks later...
wow......
wow
erm wow, how the hell you going to get all that power through the front wheels...how is the gearbox going to cope?
did i say WOW
congratulations
traction is a little problematic !
is fine right up until the boost starts kicking in :o
Kaaz LSD going in soon
poly engine mounts will be the next job
gearbox seems fine so far, handily I know where some spare ones live :huh:
wow......
wow
did i say WOW
congratulations
gearbox seems fine so far, handily I know where some spare ones live ;)
Think he was taking the p**s out of the Ibiza Lol.
Hes spent 3 years on it so im guessing most bits including tranny have been uprated, i do agree though putting 460hp through the front wheel is a little excessive.
wow......
wow
did i say WOW
congratulations
typically mat's humour went over my head :)
wow......
wow
did i say WOW
congratulations
Its not hard LoL Any idea if that chap wants the FCON ?
wow......
wow
did i say WOW
congratulations
is fine right up until the boost starts kicking in :)
not heard back from him, so i guess its a no :o
Well hopefully ;) we should be setting some Geo traction control into the rocket on Sunday...... If all else fails Bazza can you bring some string.
some trusty string and a pencil and paper
we dont need all this technology
:o
  • 2 years later...
wow 2 years without an update !!
so about time
2009 went by
the starlet winning class B in the Toyota Sprint Series
without fault it ran like a dream
the only upgrade being willwood 4 pots for the front braking
2010 came
the competition was hotter
although the starlet was running fine, something had to be done to keep up
along came Fensport who took it under their wing
with the existing TD04 turbo starting to smoke it was time for a new one
rather than go for a straight swap a IHI V28 ball bearing unit was sought
fully specced and brand new, one just happened to came along from a local supplier at the right time
with a new turbo capable of more power, new engine management was needed
next was a visit to Fensport and the Motec m4 ecu was fitted and mapped
many recommendations were forthcoming, the biggest was that the car needed a new suspension set up, the existing D2 coilovers being too hard for anything but a perfectly smooth track
new BC coilovers were installed, with a transformation of the handling
still not good enough for the Fensport team, new softer springs were fitted to the front, this allows for absorbtion of the bumps instead of bumping over them
although so much better, they think it could go even softer, quite a contrast to the rock solid D2 coilovers
with the change in set up the geometry was then in dire need of some TLC
with the car stuck in Cambridge it was left for Fensports to evolve WIM's settings a bit further
following on from Tony's recommendation for more castor, more was added, a bit of trickery was carried out
with more castor, the camber could then be reduced a bit
theory being that camber helps the handling in the corners but reduces footprint/traction in a straight line,, with front wheel drive traction is pretty important !!
with a bit more twiddling and twisting the car was ready for round 5 of the Toyota Sprint
what a difference !
the car handled like never before
power strangely enough didnt seem as much as before ?
with a boost leak and a blown head gasket diagnosed, more work was going to be needed
still took second place though
back up to Fensports, new head gasket fitted, head skimmed and new ARP bolts fitted
leaks solved, and another recommendation of taking out the restriction in the exhaust where the down pipe mates up with the main exhaust, all dutifully carried out
back up to round 6th of the Toyota Sprint
power was immense, nothing like i had felt before
sadly the day was wet and the track very slippery
front wheel drive, rain, slippery track do not go together well, with problems getting any kind of traction down, the day was no indication of how well this car goes and how well it handles
next year will tell :D
all the mapping was carried "out on the road"
no dyno charts are available
but in the words of Fensport it is ...................running about 300 bhp :)
not bad for a 1300cc
couple of latest pics
Dave @Fensport :lol:
trickery !
on track wet and slippery
a bit dirty ;)
