Bazza Posted April 25, 2007 Report Share Posted April 25, 2007 thought a few here might be interested in my Toyota GT turbo and its progression over the last 18 months car was brought from an importer and had arrived fresh from Japan started off as a very standard 1.3 turbo running a factory 130 bhp (fly figures) standard boost was switchable between 0.3 and 0.6 bar the first stage saw : WEPR 2.5" stainless exhaust (additional silencer has now been fitted due to being blooming loud) WEPR decatted downpipe Supra fuel pump Sard fuel regulator HKS fcd on a dyno run at Janspeed, power at the wheels recorded at 130bhp and 122 ft/lb torque second stage saw the handling sorted : D2 fully adjustable coilovers White line anti lift plates Whiteline camber bushes Whiteline adjustable panhard rod Cusco rear strut brace Cusco ARB (front) And the all important geometry set up by W.I.M Third stage saw rubber : the original 14" wheels being shod with toyo r888`s a new set of 15" wheels shod with toyo t1r`s fourth stage moved to the interior : HKS boost gauge HKS water temp gauge Greddy egt gauge Greddy oil temp gauge Greddy oil pressure gauge HKS turbo timer Corbeau bucket seats Willans harnesses partial (if its not needed strip it) strip out air con removed Roll cage (1/2) Momo leather steering wheel Quick shift lever fifth stage saw: HKS actuator Greddy e-manage WEPR front mount intercooler Bailey dump valve 8.5mm Magnecor leads NGK iridium plugs Apexi Excedy organic clutch Replacement of air and water pipework with silicone Civic type R radiator mapped to run at 1 bar Dyno run by TDI, power at wheels recorded at 159bhp and 160 ft/lb torque All running nicely trips around the Nurburgring, and Santa Pod where it was running 14`s then i got bored !! sixth stage begins : Hybrid ct20 turbo WEPR Freeflow manifold External wastegate (0.95 bar) WEPR Downpipe WEPR Screamer pipe Serck oil cooler and filter relocator WEPR radiator Sard thermostat HKS blow off valve HKS EVC boost controller Braided brake lines Mintex 1144 pads 3g groovy discs Fog lights removed !! Over exuburance with flourescant green paint ! Presently residing at TDI for removal of Greddy E-manage and the fitment of HKS f-con and awaiting further details a few pics here http://bazzasgallery.fotopic.net/c1012148_1.html a few more pics here http://bazzasgallery.fotopic.net/c988310.html Quote Link to comment Share on other sites More sharing options...
Tony Posted April 25, 2007 Report Share Posted April 25, 2007 Blimey.... You've morphed the car into a bullet. It must be incredibly rewarding to do this since i know most of the fitting you do yourself.... I won't ask a monetary value for all the extras but i will ask how much time do you think has been volunteered? Quote Link to comment Share on other sites More sharing options...
Bazza Posted April 25, 2007 Author Report Share Posted April 25, 2007 Blimey.... You've morphed the car into a bullet. It must be incredibly rewarding to do this since i know most of the fitting you do yourself.... I won't ask a monetary value for all the extras but i will ask how much time do you think has been volunteered? I must admit it is and has been very rewarding, I am not a mechanic so everything has been a learning process from the start i wanted to do everything myself, the complete opposite to the lexus project it started of as a cheap project, but as allways costs and dreams escalate somewhat out of control, the joy is wanting to do things rather than having to, its great when theres no timescale and no rush the best part of it all is when someone passes a compliment, i tend to grin from ear to ear (thanks mat) Quote Link to comment Share on other sites More sharing options...
Tony Posted April 25, 2007 Report Share Posted April 25, 2007 I think your past example with the sexy Lexy has proved your abilities.... Being best car in the shows and displayed in the mags is quite an achievement and well justified in my opinion. Quote Link to comment Share on other sites More sharing options...
Bazza Posted April 25, 2007 Author Report Share Posted April 25, 2007 I think your past example with the sexy Lexy has proved your abilities.... Being best car in the shows and displayed in the mags is quite an achievement and well justified in my opinion. .......im grinning again Quote Link to comment Share on other sites More sharing options...
Tony Posted April 25, 2007 Report Share Posted April 25, 2007 Good..... No one could say this.... Is for the weak hearted or novice Quote Link to comment Share on other sites More sharing options...
jon Posted April 25, 2007 Report Share Posted April 25, 2007 That must be a rapid rollerskate! When am I going to see you at a trackday then? It should fly! Quote Link to comment Share on other sites More sharing options...
Tony Posted April 25, 2007 Report Share Posted April 25, 2007 That must be a rapid rollerskate! When am I going to see you at a trackday then? It should fly! Now that's an inviting gauntlet bazza Quote Link to comment Share on other sites More sharing options...
Adie Posted April 25, 2007 Report Share Posted April 25, 2007 Nice one Barrie, well done mate Quote Link to comment Share on other sites More sharing options...
TDIPLC Posted April 26, 2007 Report Share Posted April 26, 2007 Here are some pictures to show you the work that Barrie did himself Quote Link to comment Share on other sites More sharing options...
TDIPLC Posted April 26, 2007 Report Share Posted April 26, 2007 Barrie has asked us to install and try and get working this used HKS EVC4 and Scramble Trigger button Quote Link to comment Share on other sites More sharing options...
TDIPLC Posted April 26, 2007 Report Share Posted April 26, 2007 Work has started on removing the old Emanage engine management system Quote Link to comment Share on other sites More sharing options...
Bazza Posted April 26, 2007 Author Report Share Posted April 26, 2007 cheers Mark missing it already a couple of pics on the day i picked it up finally , i think have worked out how to load piccys Quote Link to comment Share on other sites More sharing options...
TDIPLC Posted April 26, 2007 Report Share Posted April 26, 2007 cheers Mark missing it already No problem Bazza, we should make a fair amount of progress tomorrow. You may even see it back next week Quote Link to comment Share on other sites More sharing options...
w481ggc Posted April 26, 2007 Report Share Posted April 26, 2007 Looks very professional Barrie , nice car Quote Link to comment Share on other sites More sharing options...
Tony Posted April 26, 2007 Report Share Posted April 26, 2007 Work has started on removing the old Emanage engine management system Makes me nervous looking at all those wires...... Something of a birds nest methinks!... I must confess when i was at tdi there was a car with wires allover the place and Mark said this will be running this afternoon.... To my non-educated mind i thought 'no way' .............. Wrong it was a done deal later that day! Needless to say i was impressed but don't tell Mark that... Quote Link to comment Share on other sites More sharing options...
Mark H. Posted April 26, 2007 Report Share Posted April 26, 2007 What does a scramble trigger button do? Quote Link to comment Share on other sites More sharing options...
TDIPLC Posted April 27, 2007 Report Share Posted April 27, 2007 What does a scramble trigger button do? It provides higher boost pressure for a predetermined length of time Quote Link to comment Share on other sites More sharing options...
jon Posted April 27, 2007 Report Share Posted April 27, 2007 What does a scramble trigger button do? It compares the letters you've got against a dictionary and gives you the highest scoring word. Oh wait, that's a scrabble trigger Quote Link to comment Share on other sites More sharing options...
Bazza Posted April 29, 2007 Author Report Share Posted April 29, 2007 That must be a rapid rollerskate! When am I going to see you at a trackday then? It should fly! Nurburgring june 22nd fancy joining us ? Quote Link to comment Share on other sites More sharing options...
scorps Posted April 29, 2007 Report Share Posted April 29, 2007 Stunning example Barrie....nice job well done Quote Link to comment Share on other sites More sharing options...
Mark H. Posted April 29, 2007 Report Share Posted April 29, 2007 What does a scramble trigger button do? It provides higher boost pressure for a predetermined length of time :ph34r_anim: Thanks for that. Sounds like something an X-wing from Star Wars would have. Press the button and it sends a signal to everyone in the convoy to go in a random direction. I would have thought something like overboost would be a good name for it. I think thats what Saab call it on their HOT models. Extra boost for 20 secconds iirc. Quote Link to comment Share on other sites More sharing options...
Tony Posted April 29, 2007 Report Share Posted April 29, 2007 What does a scramble trigger button do? It provides higher boost pressure for a predetermined length of time :ph34r_anim: Thanks for that. Sounds like something an X-wing from Star Wars would have. Press the button and it sends a signal to everyone in the convoy to go in a random direction. I would have thought something like overboost would be a good name for it. I think thats what Saab call it on their HOT models. Extra boost for 20 secconds iirc. I have to agree 'Scramble button' does read into insignificance compared with 'Overboost' may as well call the scramble a 'Dump blocker'. ......... Whatever the name, performance is the key, so Mr Bond we await the application of the 'Scramble button' Quote Link to comment Share on other sites More sharing options...
TDIPLC Posted May 2, 2007 Report Share Posted May 2, 2007 The Starlet is running on the new FCON today. We have some tidying up and some minor issues to deal with, then it should be on the Rototest tomorrow Quote Link to comment Share on other sites More sharing options...
Janey Posted May 2, 2007 Report Share Posted May 2, 2007 The Starlet is running on the new FCON today. We have some tidying up and some minor issues to deal with, then it should be on the Rototest tomorrow Excellent news Mark Does this mean Barrie won't be doing the gardening this weekend Since the car has been away he has discovered he has green fingers (and thats not just because he has a cold :graduated: ) Quote Link to comment Share on other sites More sharing options...
