Tony Posted March 30, 2018 Report Share Posted March 30, 2018 Good it's handling better, as for taking an image what's the problem, it's your data? Quote Link to comment Share on other sites More sharing options...
jammy Posted March 30, 2018 Author Report Share Posted March 30, 2018 Still having to hold the wheel right most of the time..starting to wonder if vib have a fubard tyre on the front right Quote Link to comment Share on other sites More sharing options...
jammy Posted March 30, 2018 Author Report Share Posted March 30, 2018 Good it's handling better, as for taking an image what's the problem, it's your data? Just wont let me upload at all Quote Link to comment Share on other sites More sharing options...
jammy Posted April 1, 2018 Author Report Share Posted April 1, 2018 Sooooo then 😬 going to now have to check the whole car again myself and see if there is any issues as the car should be sweet now..  There is either something that has now worn between mot 2 weeks ago and now or the drivers right tyre is damaged due to an impact it took on a pot hole in September when they was still on my vectra Quote Link to comment Share on other sites More sharing options...
Tony Posted April 1, 2018 Report Share Posted April 1, 2018 What problems are you having? Quote Link to comment Share on other sites More sharing options...
jammy Posted April 1, 2018 Author Report Share Posted April 1, 2018 Still goig off to the left mate..having to hold the wheel to the rightheir. .more noticeable over 40 mph..it wasn't apparent untill I got on the motorway Friday morning.. Quote Link to comment Share on other sites More sharing options...
Tony Posted April 1, 2018 Report Share Posted April 1, 2018 I need the front camber and castor numbers... Quote Link to comment Share on other sites More sharing options...
jammy Posted April 1, 2018 Author Report Share Posted April 1, 2018 Ok mate I'll get them tomorrow as the print out is at my house Quote Link to comment Share on other sites More sharing options...
Tony Posted April 1, 2018 Report Share Posted April 1, 2018 Quote Link to comment Share on other sites More sharing options...
jammy Posted April 3, 2018 Author Report Share Posted April 3, 2018   FRONT        camber -1°26 left  -1°29 right        castor  2°50 left   3°50 right          toe  0°04 left   0°04 right      total toe 0°09      steer ahead 0°00         REAR        camber  -2°04 left   -2°03 right          toe  0°10 left   0°10 right      total toe 0°21   thrust angle 0°00 but is grey ???  Yes mate set as a vxr I will upload the final result when it let's me..       Quote Link to comment Share on other sites More sharing options...
Tony Posted April 3, 2018 Report Share Posted April 3, 2018 Well there's your pull? The degree difference between the castors with the OSF more dominant to the left and the NSF less dominant to the right. Quote Link to comment Share on other sites More sharing options...
jammy Posted April 3, 2018 Author Report Share Posted April 3, 2018 How can I solve that if it's not adjustable? Quote Link to comment Share on other sites More sharing options...
jammy Posted April 3, 2018 Author Report Share Posted April 3, 2018 Would that mean the drivers front sits further back than the left? Or other way round? Quote Link to comment Share on other sites More sharing options...
Tony Posted April 3, 2018 Report Share Posted April 3, 2018 Most time if the subframe is loosened you can get some movement because the bolts holding it arn't a surgical fit. Quote Link to comment Share on other sites More sharing options...
jammy Posted April 3, 2018 Author Report Share Posted April 3, 2018 I did mention the castor results and they said it wasn't a lot out but to me reads quite a bit out? Quote Link to comment Share on other sites More sharing options...
Tony Posted April 3, 2018 Report Share Posted April 3, 2018 Add the road crown to it then it's significant.... If i could i would have the positions the other way around which is what we do to the Merc's to stop them pulling. Quote Link to comment Share on other sites More sharing options...
jammy Posted April 3, 2018 Author Report Share Posted April 3, 2018 ... Quote Link to comment Share on other sites More sharing options...
jammy Posted April 3, 2018 Author Report Share Posted April 3, 2018 Most time if the subframe is loosened you can get some movement because the bolts holding it arn't a surgical fit. Â The frame does move side to side but can't say I have ever got it to move forward or back when I was setting the vectra back to the car. Â What way would it need adjusting mate? Quote Link to comment Share on other sites More sharing options...
Tony Posted April 3, 2018 Report Share Posted April 3, 2018 The NS needs to come forward and the OS back. Quote Link to comment Share on other sites More sharing options...
jammy Posted April 4, 2018 Author Report Share Posted April 4, 2018 Ok mate Quote Link to comment Share on other sites More sharing options...
jammy Posted April 4, 2018 Author Report Share Posted April 4, 2018 Only seems to have left and right movement on both front and rear bolts to the subframe Quote Link to comment Share on other sites More sharing options...
Tony Posted April 4, 2018 Report Share Posted April 4, 2018 If that's the case you can move it and stagger the camber to stop the pull...If you push the top of the NS wheel toward the right, then that will deepen the NS camber and retract the OS camber. Quote Link to comment Share on other sites More sharing options...
jammy Posted April 4, 2018 Author Report Share Posted April 4, 2018 Ok mate..I've given it a shove over and almost got it is think..will take it up the motorway Saturday and see what it's like..I'll take it back to the place soon and get a check up on it.it won't get used for a few weeks anyway once it requires more fuel as my pockets are near empty..  Into my 4th week of no work now 😠Quote Link to comment Share on other sites More sharing options...
Tony Posted April 4, 2018 Report Share Posted April 4, 2018 Sorry about the work front mate but hang on in there.... Â Some of the German cars adjust the same way i suggested. It's called an "optimised" adjustment. Normally we jack the front, loosen the cross member then find an area to lever. In the case of the German cars we move the subframe so both wheels have the same value whereas in your case we want the NS to have more camber than the OS. Quote Link to comment Share on other sites More sharing options...
jammy Posted April 4, 2018 Author Report Share Posted April 4, 2018 Yeah it will pick up soon as the tax year starts rolling again.there is work were just not allowed to start yet..we do sainsbury aldI waitress answer m&s stores new and old..our side of contacts for the current 2017 to 2018 are complete so it's a case of sit tight.....I will get my other wheels on next visit to that place.. Quote Link to comment Share on other sites More sharing options...
