jammy Posted July 8, 2018 Author Report Share Posted July 8, 2018 Well I am raising the rear 20mm tomorrow which falls into the lowest option on the machine.. And hopefully should bring the camber and toe back to where is was.. Got a drive to Cambridge tomorrow which I was looking forward to but not so much now Quote Link to comment Share on other sites More sharing options...
Tony Posted July 8, 2018 Report Share Posted July 8, 2018 They should have used the machines lowest settings despite the actual height. Quote Link to comment Share on other sites More sharing options...
jammy Posted July 8, 2018 Author Report Share Posted July 8, 2018 Yeah they did mate.but as you said you thought there wouldn't be enough adjustment on the rear to reach the target due to its ride hight and there wasn't, Quote Link to comment Share on other sites More sharing options...
Tony Posted July 8, 2018 Report Share Posted July 8, 2018 True they do have a limited range....If you adjust the height so the lower arms are horizontal that would be perfect. Quote Link to comment Share on other sites More sharing options...
jammy Posted July 8, 2018 Author Report Share Posted July 8, 2018 I've managed to gain 15mm of hight on the rears reading 335 hub to arch but that's as far as the spring Perch goes.. Just as well I've raised it tbh as I am off to pick up an 8k sound system for beach parties and I'm told it's not that light Quote Link to comment Share on other sites More sharing options...
Tony Posted July 8, 2018 Report Share Posted July 8, 2018 8k ....This i've got to see Quote Link to comment Share on other sites More sharing options...
jammy Posted July 8, 2018 Author Report Share Posted July 8, 2018 you should come to a party Tony Quote Link to comment Share on other sites More sharing options...
Tony Posted July 8, 2018 Report Share Posted July 8, 2018 I should be able to hear it from Hemel Quote Link to comment Share on other sites More sharing options...
jammy Posted July 8, 2018 Author Report Share Posted July 8, 2018 😂 😂 😂 Quote Link to comment Share on other sites More sharing options...
jammy Posted July 9, 2018 Author Report Share Posted July 9, 2018 The car was spared the trip until Friday now. The sellers got back from holiday at 11pm.. I wasn't going nowhere at that time! Quote Link to comment Share on other sites More sharing options...
jammy Posted July 9, 2018 Author Report Share Posted July 9, 2018 Just drove to work and it's horrible Went the same way as I did all last week and I couldn't corner half as hard as I had been. I can feel it sat arseend up.. Not liking it Quote Link to comment Share on other sites More sharing options...
Tony Posted July 10, 2018 Report Share Posted July 10, 2018 Is it partly a damper issue. Quote Link to comment Share on other sites More sharing options...
jammy Posted July 10, 2018 Author Report Share Posted July 10, 2018 No the dampers are find.. I am thinking the bush In the bottom rear arm might be damaged after the guy snapped the bolt on Saturday as I am getting a knocking noise from the n/s/r... I've got to go and pick up the new bolts tomorrow and the owner will be there so I'll be having a chat.. There the snapped bolt issue and on Friday I noticed that the n/s track rod hadn't been tightened up after it was last aligned.. The owner is good at what he does but the monkeys that were there Saturday don't have any fxxx's to give.. No doubt they cooked the siezed and sheered bolt to get it out of the arm Quote Link to comment Share on other sites More sharing options...
jammy Posted July 10, 2018 Author Report Share Posted July 10, 2018 The suspension is working well Imo.. I was on the front again to day working on the camber which has made. Difference.. I had to alter the toe as the change in camber mode the wheels toe out rather a lot.. Will be intetesting to see the first readings Friday as after my last play I got the Fronts to sit parallel by eye Quote Link to comment Share on other sites More sharing options...
jammy Posted November 9, 2018 Author Report Share Posted November 9, 2018 On 27/03/2018 at 19:41, Tony said: Right some numbers.... Due to the height I've based the numbers on the VXR. Rear Camber -2 degrees 7' Toe +10' each side Front Camber -1 degree 5' Castor: Not adjustable so high is good providing there's no more than 45' difference between them Toe +5' each side Found the numbers you gave me last time mate. Should I aim for this again? Quote Link to comment Share on other sites More sharing options...
Tony Posted November 9, 2018 Report Share Posted November 9, 2018 Yeah if you are happy to try them. Quote Link to comment Share on other sites More sharing options...
jammy Posted November 9, 2018 Author Report Share Posted November 9, 2018 SEems to have gone well.. The ight impact had moved things on the n/s by nats c**k. I'll try and get the print out to you mate. Quote Link to comment Share on other sites More sharing options...
jammy Posted November 9, 2018 Author Report Share Posted November 9, 2018 Drives OK for the 10 miles I've driven so far.. Went for bit of toe out at the front it was really twitchy before, no more twitching.. It a bit more road feel now Imo too, plus its less of a crashy ride too.. Let's see how it ikes south France in on hit then Quote Link to comment Share on other sites More sharing options...
Tony Posted November 10, 2018 Report Share Posted November 10, 2018 Result.....Don't hit it on the way to France Quote Link to comment Share on other sites More sharing options...
jammy Posted November 10, 2018 Author Report Share Posted November 10, 2018 well I don't intend on it but hey who knows... Quote Link to comment Share on other sites More sharing options...
Tony Posted November 10, 2018 Report Share Posted November 10, 2018 Quote Link to comment Share on other sites More sharing options...
jammy Posted November 11, 2018 Author Report Share Posted November 11, 2018 Exactly that Quote Link to comment Share on other sites More sharing options...
Rich Posted November 11, 2018 Report Share Posted November 11, 2018 You on holiday mate or going for work? Quote Link to comment Share on other sites More sharing options...
NickT Posted November 13, 2018 Report Share Posted November 13, 2018 On 09/11/2018 at 21:48, jammy said: Drives OK for the 10 miles I've driven so far.. Went for bit of toe out at the front it was really twitchy before, no more twitching.. It a bit more road feel now Imo too, plus its less of a crashy ride too.. Let's see how it ikes south France in on hit then Out of curiosity, how much toe out did you go for in the end? Is it still driving alright? Quote Link to comment Share on other sites More sharing options...
jammy Posted November 14, 2018 Author Report Share Posted November 14, 2018 I'll find the print out mate. I'm going to wim tomorrow anyway as I want an honest opinion and an honest set up if it needs it I've set it now so it definitely wants a once over Quote Link to comment Share on other sites More sharing options...
