Tony Posted December 24, 2008 Report Share Posted December 24, 2008 Within the structure of the tyre an impact can do all manner of things hence the need to remove this from the equation. Do you know you can change that format to a column style?..... it's much easier to read. Quote Link to comment Share on other sites More sharing options...
CIH Posted December 26, 2008 Author Report Share Posted December 26, 2008 I like my format :nowink: Quote Link to comment Share on other sites More sharing options...
Tony Posted December 26, 2008 Report Share Posted December 26, 2008 I like my format :nowink: That's ok then..... All i'm trying to say the column version is easier to read "in my opinion".... but hay that's just me Quote Link to comment Share on other sites More sharing options...
CIH Posted January 5, 2009 Author Report Share Posted January 5, 2009 Is there much pratical difference between coilovers or a fixed drop with additional camber/caastor adjustment kits ? Is there much pratical difference between coilovers or a fixed drop with additional camber/caastor adjustment kits ? It depends on the owners intentions? Brought it here so as not to hijack the other thread. My intentions are fast-road (possible occasional track) but either way it's more because I want to experiment. Mainly with "building in" adjustment and aftermarket modifications generally. tbh I'm thinking coilovers may be overkill. Quote Link to comment Share on other sites More sharing options...
Tony Posted January 5, 2009 Report Share Posted January 5, 2009 Is there much pratical difference between coilovers or a fixed drop with additional camber/caastor adjustment kits ? Is there much pratical difference between coilovers or a fixed drop with additional camber/caastor adjustment kits ? It depends on the owners intentions? Brought it here so as not to hijack the other thread. My intentions are fast-road (possible occasional track) but either way it's more because I want to experiment. Mainly with "building in" adjustment and aftermarket modifications generally. tbh I'm thinking coilovers may be overkill. Me too..... you should be able to use "EZ" cams to set the cambers. Quote Link to comment Share on other sites More sharing options...
CIH Posted January 5, 2009 Author Report Share Posted January 5, 2009 I don't know anything about them, save for your Focus RS thread a little while ago. Quote Link to comment Share on other sites More sharing options...
Tony Posted January 5, 2009 Report Share Posted January 5, 2009 I don't know anything about them, save for your Focus RS thread a little while ago. these things They allow about +- 1d 30' Quote Link to comment Share on other sites More sharing options...
CIH Posted January 5, 2009 Author Report Share Posted January 5, 2009 Can they be adjusted "on the fly" ? Like, say, adjustable top mounts or eccentric bolts ? Where do you get them btw ? Quote Link to comment Share on other sites More sharing options...
Tony Posted January 5, 2009 Report Share Posted January 5, 2009 Yep, just loosen the lock nut and turn the bolt for live adjustment.... Demon tweeks are a good outlet. Quote Link to comment Share on other sites More sharing options...
CIH Posted January 6, 2009 Author Report Share Posted January 6, 2009 Meh, I really hate the DT website Quote Link to comment Share on other sites More sharing options...
Tony Posted January 6, 2009 Report Share Posted January 6, 2009 Meh, I really hate the DT website Eibach then Quote Link to comment Share on other sites More sharing options...
CIH Posted January 7, 2009 Author Report Share Posted January 7, 2009 What does WIM make of these ? Ebay S12 Coilovers Doesn't appear to offer any castor adjustment ? Quote Link to comment Share on other sites More sharing options...
Tony Posted January 8, 2009 Report Share Posted January 8, 2009 What does WIM make of these ? Ebay S12 Coilovers Doesn't appear to offer any castor adjustment ? They look good with all the ingredients, i think you will find cheaper out there though..... As for the castor that will need an adjustable lower tie-rod. Quote Link to comment Share on other sites More sharing options...
CIH Posted January 9, 2009 Author Report Share Posted January 9, 2009 Apparantly adjustable S14 (iirc) tension rods will do it Quote Link to comment Share on other sites More sharing options...
Tony Posted January 9, 2009 Report Share Posted January 9, 2009 Apparantly adjustable S14 (iirc) tension rods will do it This place> http://www.japperformanceparts.co.uk/ is great for secondhand parts, they'll have loads of adjusters Quote Link to comment Share on other sites More sharing options...
CIH Posted January 9, 2009 Author Report Share Posted January 9, 2009 Are used adjusters a good idea ? Quote Link to comment Share on other sites More sharing options...
Tony Posted January 9, 2009 Report Share Posted January 9, 2009 Are used adjusters a good idea ? There non-mechanical so there's no problem their secondhand, if you look at the webby they do everything from coilovers to ARB's to everything, plus since i set their track cars you have a backdoor in if you like Quote Link to comment Share on other sites More sharing options...
CIH Posted January 9, 2009 Author Report Share Posted January 9, 2009 Added to favourites! Some very interesting stuff on there. Quote Link to comment Share on other sites More sharing options...
Tony Posted January 9, 2009 Report Share Posted January 9, 2009 Added to favourites! Some very interesting stuff on there. Quote Link to comment Share on other sites More sharing options...
CIH Posted January 12, 2009 Author Report Share Posted January 12, 2009 'Think I'll get some EZ bolts for the front so I can have a quick play with some front camber (stage 1, if you will). Any ideas why I couldn't get any movement from the NSR eccentric (toe) ? Think I may have a bent trailing arm ? Quote Link to comment Share on other sites More sharing options...
Tony Posted January 12, 2009 Report Share Posted January 12, 2009 Is the cam actually moving the arm? Quote Link to comment Share on other sites More sharing options...
CIH Posted January 12, 2009 Author Report Share Posted January 12, 2009 hardly a minute of adjustment either way, across the whole diameter of the cam lobe Quote Link to comment Share on other sites More sharing options...
Tony Posted January 12, 2009 Report Share Posted January 12, 2009 hardly a minute of adjustment either way, across the whole diameter of the cam lobe Isn't the lob an external "D" cam? Quote Link to comment Share on other sites More sharing options...
CIH Posted January 12, 2009 Author Report Share Posted January 12, 2009 IIRC yes. Incidentally, OEM rear spoiler (to go with the "six pack" tail lights) and an FJ bonnet are on the want list. Both are made by an S12OC member in fibreglass. Much better than the foam stuff used by Nissan. Quote Link to comment Share on other sites More sharing options...
Tony Posted January 12, 2009 Report Share Posted January 12, 2009 Doesn't make sense?...... If you can see the cam move then the wheel must move..... could it be seized in the bushing? Quote Link to comment Share on other sites More sharing options...
