Tony Posted November 14, 2018 Report Share Posted November 14, 2018 Please bring those reports with you so i can work out what part in each set-up worked for you and then i can put all the good bits together. Quote Link to comment Share on other sites More sharing options...
NickT Posted November 14, 2018 Report Share Posted November 14, 2018 Have a great day out, let me know how it goes. I just set mine to 0mm toe in parallel for now. Quote Link to comment Share on other sites More sharing options...
jammy Posted November 14, 2018 Author Report Share Posted November 14, 2018 Thank you mate... Are you standard suspension? Mine has been parallel but I didn't like the twitchy steering wheel over every lump and bump.. I can't remember where input the print out but I'll get Tony to post a before and after of the read out Quote Link to comment Share on other sites More sharing options...
NickT Posted November 14, 2018 Report Share Posted November 14, 2018 1 hour ago, jammy said: Thank you mate... Are you standard suspension? Mine has been parallel but I didn't like the twitchy steering wheel over every lump and bump.. I can't remember where input the print out but I'll get Tony to post a before and after of the read out Yes mate, standard suspension and my steering is as you've just described too. Light steering but not self centering enough. Tony is the man with the geometry so it'll be interesting to see his results Quote Link to comment Share on other sites More sharing options...
jammy Posted November 15, 2018 Author Report Share Posted November 15, 2018 Yeah vectra aren't to keen on parallel that's for sure.. Yeah Tony is a true chassis god Quote Link to comment Share on other sites More sharing options...
jammy Posted November 15, 2018 Author Report Share Posted November 15, 2018 Wow its pwopa foggy out! Quote Link to comment Share on other sites More sharing options...
Tony Posted November 15, 2018 Report Share Posted November 15, 2018 That'll be your tarnished headlamps Quote Link to comment Share on other sites More sharing options...
jammy Posted November 15, 2018 Author Report Share Posted November 15, 2018 omg it was ten times worse on the way home.. Just walked through the door mate.. 4 hours.. Drives nice though mate that little fine tune mad a lot of difference.. The adding weight to preload has always had me baffled anyway.. If you add 70 kg on both front seats and the. Set the car, what about when just one person is in the car that must make the numbers do over time? I've written on my last print out 'DO NOT PRELOAD BEFORE GEOMETRY' I did insist it was preloaded each time so part blame on me for that then haha.. Maybe a visit in 6months for a check and maybe a fine tweek if ifs warrented? I expect it will have poly lower arm rear bushes by then to.. @nickT front toe set to - 2 but remember mines modified set up so this may not work for you... Thank you so much Tony you truly are a chassis god was great to see you and Rich can't believe its been ten years Quote Link to comment Share on other sites More sharing options...
jammy Posted November 15, 2018 Author Report Share Posted November 15, 2018 Oh yeah I covered 266.5 miles today and only used 5.5 gallons of fuel. This big ol 3.0v6 derv is better on fuel than my 2.2 honda diesel Quote Link to comment Share on other sites More sharing options...
NickT Posted November 15, 2018 Report Share Posted November 15, 2018 11 minutes ago, jammy said: omg it was ten times worse on the way home.. Just walked through the door mate.. 4 hours.. Drives nice though mate that little fine tune mad a lot of difference.. The adding weight to preload has always had me baffled anyway.. If you add 70 kg on both front seats and the. Set the car, what about when just one person is in the car that must make the numbers do over time? I've written on my last print out 'DO NOT PRELOAD BEFORE GEOMETRY' I did insist it was preloaded each time so part blame on me for that then haha.. Maybe a visit in 6months for a check and maybe a fine tweek if ifs warrented? I expect it will have poly lower arm rear bushes by then to.. @nickT front toe set to - 2 but remember mines modified set up so this may not work for you... Thank you so much Tony you truly are a chassis god was great to see you and Rich can't believe its been ten years Glad you got a great result there, I'm chuffed for you Quote Link to comment Share on other sites More sharing options...
jammy Posted November 15, 2018 Author Report Share Posted November 15, 2018 Thanks mate.. I'm even more chuffed that my set up I done to it Friday works well for the car and me Tony fine tweeked the beast with his magic fingers I softened up the front and rear dampers a little bit to to give me a bit more feel of the road along with a very small bit of lean into the bends is making the barge grip well.. What spec do you have nick? Yours is a vectra right? Quote Link to comment Share on other sites More sharing options...
NickT Posted November 15, 2018 Report Share Posted November 15, 2018 Yes Jammy, 3.0v6 z30dt, the one with the dpf and untunable engine. All bog standard, even the suspension is standard. The only mod I've done is an led boot light so I can see my stuff better in the boot Quote Link to comment Share on other sites More sharing options...
jammy Posted November 16, 2018 Author Report Share Posted November 16, 2018 All you need to do is work out how to uprated the fuel pump as they are pretty much to the max.. Mines the y30dt and the same problem hence I bought the tuning box Quote Link to comment Share on other sites More sharing options...
jammy Posted December 27, 2018 Author Report Share Posted December 27, 2018 Track rod ends finally gBe up this week,a couple of pot holes s cured that deal though didn't really affect the car's drivemich tbh.butbi now know it was definitely them making it twicth about and tramline as now the new ones are on it stays in lane properly and literally no twichy steering.. Its going on the geo ramp tomorrow to see what's what and probably a little tweek.. I was a bit concerned that n/s was 18 turns and the o/s was 15 1/4 turns though..had to do a naughty adjustment by eye as I can't drive it about with a p**sed steering wheel as it's so annoying but it's sat straight and is driving surprisingly well and runs straight when I let go of the wheel...... Must be a good day for it as I also changed the track rods on my mates cavalier as the was seized solid and needed adjustment s after lowering it 40mm and got that driving nice too thats in for alingment after I've done mine.. Now is it worth the cavvie going on the geo ramp or take it to somewhere with 4 wheel laser alingment? Quote Link to comment Share on other sites More sharing options...
Tony Posted December 28, 2018 Report Share Posted December 28, 2018 I wouldn't worry about the difference in the turns. It would only affect the full lock and how often are we on a full lock. Quote Link to comment Share on other sites More sharing options...
jammy Posted December 28, 2018 Author Report Share Posted December 28, 2018 Ok mate..by the time I had adjusted the n/s there was probably a turn and a half difference TBF.. Quote Link to comment Share on other sites More sharing options...
Rich Posted December 28, 2018 Report Share Posted December 28, 2018 What's the longest you've gone without doing any work to your cars?! Quote Link to comment Share on other sites More sharing options...
jammy Posted December 28, 2018 Author Report Share Posted December 28, 2018 Ages..the track ends have been on there way out for a while mate...if you see the road where I live you would understand why it's a constant up keep .. I'm putting in a claim against Thanet council as one of my other setbofvwheeps got mullard before I got the vxr wheels.. Quote Link to comment Share on other sites More sharing options...
jammy Posted December 28, 2018 Author Report Share Posted December 28, 2018 Plus I do a hole lot of miles in a week too..honda is off road ATM as the steering pipe has now broken in half and all four calipers are leaking so it's effectively a death trap..MOT due in 3 weeks but we're skint after Christmas so the signums been doing a 1000 miles a week since second week of November so it actually does quite well.. Quote Link to comment Share on other sites More sharing options...
jammy Posted December 29, 2018 Author Report Share Posted December 29, 2018 I'll drop a pic of the results up soon..there was a new lad there it took him ages to do he wasn't listening when the boss and me both said it's very sensitive and to do little adjustments and let it settle after each adjustment and got all cocky saying I've got it don't you worry Yuh huh it became so amusing that we both let him carry on untill he got it where it was before he said we were horrible c***s but he was glad he stayed at it....he doesn't like my car and he has only had to set it once! The boss has done it at least 6 maybe 7 times me twice so I just said expect to see more of it the more work gets done tramlining and twichy steering has gone now Quote Link to comment Share on other sites More sharing options...
