Tony Posted September 17, 2013 Report Share Posted September 17, 2013 No, it relates to the ECU or level censor fitted to the lower wishbones. Quote Link to comment Share on other sites More sharing options...
MarsdenDean Posted September 18, 2013 Author Report Share Posted September 18, 2013 so you think it could be the above Tony. A possible problem with a sensor on the lower wishbone if there is one? The car is now in again on the 28th Oct. lexus said they couldn't really feel anything but will start with another geo setup and have another look into the problem. The tech also said the car needs to settle down once it has been down country lanes at a brisk pace but I think this is rubbish? they say they have never had problems with stuck actuators on the dampeners but again the car is going in. I'm going to film the car from behind and inside the car, combine the videos so lexus can look at the footage to prove the problem does exist as bad as it is 1 Quote Link to comment Share on other sites More sharing options...
MarsdenDean Posted September 18, 2013 Author Report Share Posted September 18, 2013 also lexus are saying an actuator stuck would throw a fault code Into the ecu memory Quote Link to comment Share on other sites More sharing options...
parthiban Posted September 18, 2013 Report Share Posted September 18, 2013 I don't think this is a mechanical problem, it's got to be a sensor somewhere. The car is thinking it needs to lean when it shouldn't, so it must be a sensor reporting the wrong information. Or otherwise an issue with the relevant ECU, but that would probably throw up some sort of error code. Quote Link to comment Share on other sites More sharing options...
MarsdenDean Posted September 18, 2013 Author Report Share Posted September 18, 2013 Thanks parthiban its such a shame lexus say there is no problem. we're going to film the car on Sunday morning, one from behind showing the car and road, and one on the steering wheel and how the car is reacting then post the video here. The leaning changes but always seams to be onto the passenger side, sometimes it can lean, other times its flat. We will also be measuring ride height from the floor to the centre of the wheel arch at various points aswell Quote Link to comment Share on other sites More sharing options...
parthiban Posted September 18, 2013 Report Share Posted September 18, 2013 Have you been able to spot any common occurrences that trigger it? Perhaps a certain speed/angle of road/smoothness of surface? And have you taken out someone from Lexus in the car to let them experience it while you're in it? I had an issue with engine idle which they said was absolutely fine until I took the service manager out in my car with me and showed him exactly what the problem was. Quote Link to comment Share on other sites More sharing options...
Tony Posted September 19, 2013 Report Share Posted September 19, 2013 Video evidence is a great idea. Quote Link to comment Share on other sites More sharing options...
SMARTLY Posted September 19, 2013 Report Share Posted September 19, 2013 Is it still under warranty? When Lexus were unable fix my problems I left it at the dealership and walked away. It was a bit complicated but I eventually got a replacement new car. Quote Link to comment Share on other sites More sharing options...
MarsdenDean Posted September 22, 2013 Author Report Share Posted September 22, 2013 the car is still under extended guarantee and this was purchased as the car developed the fault at 2 years old. It all started after a creaking anti roll bar motor, and various bits that was changed. rpnderbouts or country lanes followed my straight line driving causes it , or sometimes pulling a hard left or right turn continues to make the car try to go left or right. should have a video to view tomorrow. It basically wants to pull left most of the time, but this can be cured by some miles on a motorway, Quote Link to comment Share on other sites More sharing options...
Tony Posted September 22, 2013 Report Share Posted September 22, 2013 "anti roll bar motor", what's that? Quote Link to comment Share on other sites More sharing options...
MarsdenDean Posted September 22, 2013 Author Report Share Posted September 22, 2013 a motor that twists the rear anti roll bar when it's in sport mode. It twists to reduce body roll, since it's the gs450h sport and there is only 91 left on the road, it's quite a rare system Quote Link to comment Share on other sites More sharing options...
Tony Posted September 22, 2013 Report Share Posted September 22, 2013 Sounds problematic but being transverse it can't control trim height like a torsion bar. I look forward to the video. Quote Link to comment Share on other sites More sharing options...
MarsdenDean Posted September 22, 2013 Author Report Share Posted September 22, 2013 took a video today but it's hard to see the internal of the gs. just trying to edit the 2 videos together to see side by side but you can see at 4 points where the car pulls a hard right or left. car returns to lexus 28th Oct for one week. which includes a machine polish after using sponges which they was told not to wash the car . . . . .. Quote Link to comment Share on other sites More sharing options...
parthiban Posted September 23, 2013 Report Share Posted September 23, 2013 A fault is bad but fair enough, it's a bit worrying if they can't work out what the problem is after repeated visits........ Quote Link to comment Share on other sites More sharing options...
Tony Posted September 23, 2013 Report Share Posted September 23, 2013 It's starting to read like there's an inherent problem with the 450H Quote Link to comment Share on other sites More sharing options...
parthiban Posted September 23, 2013 Report Share Posted September 23, 2013 It's starting to read like there's an inherent problem with the 450H It's only the Sport models that had this system, and it was a limited run for just the last few years and hasn't been used in the new model I believe. So perhaps a system that wasn't tested very well, and then not developed further to iron out the issues. Quote Link to comment Share on other sites More sharing options...
Tony Posted September 23, 2013 Report Share Posted September 23, 2013 Then if it proved to be problematic then they should know what issues to look for. Quote Link to comment Share on other sites More sharing options...
parthiban Posted September 23, 2013 Report Share Posted September 23, 2013 Then if it proved to be problematic then they should know what issues to look for. Should be a no brainer! Not the best response from a company like Lexus........ Quote Link to comment Share on other sites More sharing options...
Tony Posted September 23, 2013 Report Share Posted September 23, 2013 Look at the IS200 tyre issues Quote Link to comment Share on other sites More sharing options...
parthiban Posted September 23, 2013 Report Share Posted September 23, 2013 Look at the IS200 tyre issues Haha good point, they still never really acknowledged it did they! Quote Link to comment Share on other sites More sharing options...
Tony Posted September 23, 2013 Report Share Posted September 23, 2013 Would have cost them millions in liability had they have done. Quote Link to comment Share on other sites More sharing options...
MarsdenDean Posted September 23, 2013 Author Report Share Posted September 23, 2013 Please let us know how you get on. The 2 issues the car is having is pulling to the left or right, and uneven ride heights. still working in combing these videos to give a little picture of what is hapoening Quote Link to comment Share on other sites More sharing options...
MarsdenDean Posted September 23, 2013 Author Report Share Posted September 23, 2013 most of the gs450h cars from 2007 onwards used the avs system, but only a limited run used the asss which controls the roll bar. The problem is happening all the time, and we believe that the roll bar only moves when the button is pressed to engage sport mode Quote Link to comment Share on other sites More sharing options...
Tony Posted September 23, 2013 Report Share Posted September 23, 2013 How goes that video? Quote Link to comment Share on other sites More sharing options...
MarsdenDean Posted September 26, 2013 Author Report Share Posted September 26, 2013 I'm just creating the movie but its taking a while to compress and render it. There is around 3 times it pulls heavily and is leaning, just waiting for it to finish Quote Link to comment Share on other sites More sharing options...
