Tony Posted July 1, 2011 Report Share Posted July 1, 2011 Look how easy the rear lets go..... Please wait a few moments for Video to Load! Quote Link to comment Share on other sites More sharing options...
liner33 Posted July 1, 2011 Report Share Posted July 1, 2011 Ditchfinders these cars , i heard of one doing this on the motorway during a lane change , I'm all for RWD but the s2000 is just to light on the back end , needs the old Capri trick of sandbags in the boot Quote Link to comment Share on other sites More sharing options...
Rich Posted July 1, 2011 Report Share Posted July 1, 2011 They seem ok with a WIM geo though. Quote Link to comment Share on other sites More sharing options...
Tony Posted July 1, 2011 Author Report Share Posted July 1, 2011 We use different settings to Honda, but nevertheless their still twitchy. Quote Link to comment Share on other sites More sharing options...
Rich Posted July 1, 2011 Report Share Posted July 1, 2011 When I've been in the car with Iain it feels very planted, shouldn't break free like that did. Quote Link to comment Share on other sites More sharing options...
adam_r Posted July 1, 2011 Report Share Posted July 1, 2011 guys, this is due to the owner actually lifting off slightly, plus not reducing rear toe angle to reduce the 'bump steer' effect. and i though snap over steer occured when it 'snapped' back and spun you the other way. Quote Link to comment Share on other sites More sharing options...
Tony Posted July 1, 2011 Author Report Share Posted July 1, 2011 Very light lift though Quote Link to comment Share on other sites More sharing options...
adam_r Posted July 1, 2011 Report Share Posted July 1, 2011 im aware he only just lifted off, but thats the problem yet again, in RWD when you lift off the rear goes light (in any rwd car) you need to feed to power in very slightly when going around a corer like that to keep the back end planted and pushing the front end through the corner. Quote Link to comment Share on other sites More sharing options...
andyelcomb Posted July 1, 2011 Report Share Posted July 1, 2011 in RWD when you lift off the rear goes light (in any rwd car) you need to feed to power in very slightly when going around a corer like that to keep the back end planted and pushing the front end through the corner. Quite so, you can really feel the difference at Brands in the M3s through Paddock & Surtees if the customer doesn't keep a bit of power on. Had an almighty moment at Paddock on Wednesday when my customer decided that whilst it was fine to blat into the corner at a good speed, having then got cold feet about it he decided to come off the throttle and jump on the brakes right on the apex. Pillock! Thank goodness we had full Traction and Stability Control switched on or we'd have been a LONG way off the road. Quote Link to comment Share on other sites More sharing options...
Tony Posted July 1, 2011 Author Report Share Posted July 1, 2011 I know what you mean "moment of inertia", it's just the car hardly slowed. Quote Link to comment Share on other sites More sharing options...
phipck Posted July 1, 2011 Report Share Posted July 1, 2011 dont forget that the situation is amplified by where he lifts off, at the brow of the hill, so you have a suddent lift from that as well. Quote Link to comment Share on other sites More sharing options...
phipck Posted July 1, 2011 Report Share Posted July 1, 2011 although having said that......... Please wait a few moments for Video to Load! Quote Link to comment Share on other sites More sharing options...
Tony Posted July 1, 2011 Author Report Share Posted July 1, 2011 Nasty......They should make non-stick frying pans out of S2000's Quote Link to comment Share on other sites More sharing options...
Rich Posted July 1, 2011 Report Share Posted July 1, 2011 Wipers were on so obviously a damp track. Quote Link to comment Share on other sites More sharing options...
phipck Posted July 1, 2011 Report Share Posted July 1, 2011 or he'd got use to driving a french car and tried flashing his lights Quote Link to comment Share on other sites More sharing options...
adam_r Posted July 1, 2011 Report Share Posted July 1, 2011 commenting on that second video, the guy is obviously trying a little too hard, he almost miss shifted and could not quite make (5th?) gear ? . and a few seconds before he spin's, he does the right thing and has let the engine do some braking, but he seems a little bit too feirce with re- applying the throttle. And to make matters worse for himself, he choses to feed in the power even though he has already started turning in to the corner. Wet track + slightly nervous driver + applying throttle when your turning = spin. Cars like the S dont just spin for 'no reason', it is due to drivers inputs. I can find you hundreds of other RWD cars that lose their tails around those corners on the ring. Quote Link to comment Share on other sites More sharing options...
adam_r Posted July 1, 2011 Report Share Posted July 1, 2011 look at these: and many other pages of people spinning in the same fassion. http://www.youtube.com/results?search_quer...rgring&aq=f Quote Link to comment Share on other sites More sharing options...
andyelcomb Posted July 1, 2011 Report Share Posted July 1, 2011 2nd spin very interesting. The rear let go at 125mph and he was previously up to an indicated 150 (briefly) so isn't hanging about at all - particularly in the damp. His reaction to reverse and J-turn the car shows he's very familiar with throwing the car around so I'm not so sure it was the usual dummy error, but I haven't got sound on the video so can't tell what happens just pior to the spin. Quote Link to comment Share on other sites More sharing options...
adam_r Posted July 1, 2011 Report Share Posted July 1, 2011 with sound you would here at 0:14 he lifts off (look at dash), then between 0:15 / 0:16 he starts to accelerate (again look at speedo), as he does this the back end kicks out. this is helped by the fact that the front wheel are already turned to the right which will cause the back end to step out.. just like it did. Quote Link to comment Share on other sites More sharing options...
