Tony Posted April 30, 2009 Report Share Posted April 30, 2009 These are a sliding ball joint adjuster that allows a +- 1d 30' Simply remove the upper wishbone and press-out the existing joint Bolt in the new adjuster Reinstall the wishbone The adjust to your hearts content........ Simples Quote Link to comment Share on other sites More sharing options...
SMARTLY Posted April 30, 2009 Report Share Posted April 30, 2009 Will these be of benefit to a standard car? Quote Link to comment Share on other sites More sharing options...
Tony Posted April 30, 2009 Author Report Share Posted April 30, 2009 Will these be of benefit to a standard car? Not as yet... Tango's car is lowered and suffered some road trauma, hence the need for the correctors..... In time though as the stock owners coils sag i think they will have issues. Quote Link to comment Share on other sites More sharing options...
Rich Posted April 30, 2009 Report Share Posted April 30, 2009 They look good, could something like that be used to adjust the castor on mine? Quote Link to comment Share on other sites More sharing options...
Tony Posted April 30, 2009 Author Report Share Posted April 30, 2009 They look good, could something like that be used to adjust the castor on mine? Sadly no..... reason being the upright is not off-centre, meaning the adjustment is "transverse" rather than longitudinal. Quote Link to comment Share on other sites More sharing options...
Tango Posted May 2, 2009 Report Share Posted May 2, 2009 I assume the stud length on the adjusters prevented the refitting of the original washers? Hope that's going to be OK. The car drove a lot better on the way home, especially on the twisty bits. I got the impression it was slightly more tail happy, but soon realised it was just feeling more precise on the front end as the previous trace of understeer has disappeared completlely. I'll have to give it a good try out next time I'm at the airfield . Quote Link to comment Share on other sites More sharing options...
Tony Posted May 2, 2009 Author Report Share Posted May 2, 2009 The original pin was an M10 nut with a fixed washer Whereas the new adjuster has a M8 nut, although the tapper into the upright is the same.... Now these are installed we can play with the handling but i think as you say you need to get a feel of the car. Quote Link to comment Share on other sites More sharing options...
Tango Posted May 2, 2009 Report Share Posted May 2, 2009 When I eventually got on some twisty bits when driving home yesterday it had been raining, so I was a lttle restrained, but I had a play today in the dry and the handling now can only be described as 'superb' Quote Link to comment Share on other sites More sharing options...
Rich Posted May 2, 2009 Report Share Posted May 2, 2009 They look good, could something like that be used to adjust the castor on mine? Sadly no..... reason being the upright is not off-centre, meaning the adjustment is "transverse" rather than longitudinal. What about the camber then? Someone on meg was asking whether it could be done this way instead of using the top mounts. Quote Link to comment Share on other sites More sharing options...
Tony Posted May 2, 2009 Author Report Share Posted May 2, 2009 They look good, could something like that be used to adjust the castor on mine? Sadly no..... reason being the upright is not off-centre, meaning the adjustment is "transverse" rather than longitudinal. What about the camber then? Someone on meg was asking whether it could be done this way instead of using the top mounts. No it won't work.... The attachment points are totally different. Quote Link to comment Share on other sites More sharing options...
CIH Posted May 3, 2009 Report Share Posted May 3, 2009 Wonder if they could fit other cars. I noticed the 350Z looked similar yesterday. Is there a specific term for this set-up btw ? Quote Link to comment Share on other sites More sharing options...
Tony Posted May 4, 2009 Author Report Share Posted May 4, 2009 Wonder if they could fit other cars. I noticed the 350Z looked similar yesterday. Is there a specific term for this set-up btw ? Off-set spherical ball joints is the only terminology i know of. Quote Link to comment Share on other sites More sharing options...
Mat Posted May 5, 2009 Report Share Posted May 5, 2009 Wonder if they could fit other cars. I noticed the 350Z looked similar yesterday. Is there a specific term for this set-up btw ? looks like the is200 and GS upper wishbones could be modified to fit these, id be interested to see if these fit my GS300 Quote Link to comment Share on other sites More sharing options...
Tony Posted May 5, 2009 Author Report Share Posted May 5, 2009 Wonder if they could fit other cars. I noticed the 350Z looked similar yesterday. Is there a specific term for this set-up btw ? looks like the is200 and GS upper wishbones could be modified to fit these, id be interested to see if these fit my GS300 We fitted a set on a 200 and they did look the same. Quote Link to comment Share on other sites More sharing options...
