Tony Posted September 6, 2018 Report Share Posted September 6, 2018 If yes then how does it work Quote Link to comment Share on other sites More sharing options...
liner33 Posted September 6, 2018 Report Share Posted September 6, 2018 Same as normal plugs the spark arcs from the electrode to the body of the plug Quote Link to comment Share on other sites More sharing options...
SMARTLY Posted September 6, 2018 Report Share Posted September 6, 2018 and non-adjustable Quote Link to comment Share on other sites More sharing options...
liner33 Posted September 7, 2018 Report Share Posted September 7, 2018 Most plugs are preset from the factory anyway , so are already "adjusted" to an ideal gap and with many types you should not adjust them as they are fragile Formula one uses plugs like these http://www.formula1-dictionary.net/spark-plug.html Quote Link to comment Share on other sites More sharing options...
Tony Posted September 7, 2018 Author Report Share Posted September 7, 2018 F1 as the race series or F1 as in the fast fit company?.... If these don't need the correct gap then i'm struggling with that. Quote Link to comment Share on other sites More sharing options...
Rich Posted September 7, 2018 Report Share Posted September 7, 2018 I would've thought the website gives that a way! I don't think I've ever adjusted the gap on a spark plug, they're fitted straight out the box. Quote Link to comment Share on other sites More sharing options...
Tony Posted September 7, 2018 Author Report Share Posted September 7, 2018 What does the web-site give away. Quote Link to comment Share on other sites More sharing options...
Rich Posted September 7, 2018 Report Share Posted September 7, 2018 To your question about F1... Quote Link to comment Share on other sites More sharing options...
SMARTLY Posted September 7, 2018 Report Share Posted September 7, 2018 Quote I don't think I've ever adjusted the gap on a spark plug, they're fitted straight out the box. Really? Different cars can have different gaps and there is no guarantee that all four plugs have the same gap out of the box Quote Link to comment Share on other sites More sharing options...
Rich Posted September 7, 2018 Report Share Posted September 7, 2018 Nope I've never adjusted them and never had a problem with the ones I've fitted. Quote Link to comment Share on other sites More sharing options...
Geoffers Posted September 7, 2018 Report Share Posted September 7, 2018 I remember many, many moons ago checking with my gap adjuster when I was going over my car.... I remember taking them out and giving them a tap on the pavement to knock them in ever so slightly. Tell you how long ago it was, it was my Escort Mk2. Gulp. Last time I did it I swapped the rotor arm and points too as the spark seemed a little weak. My mate used to do his and was convinced the gap was exactly the width of the cardboard on No6 ciggy box! Quote Link to comment Share on other sites More sharing options...
Tony Posted September 8, 2018 Author Report Share Posted September 8, 2018 I used to close the gap that way....Before that I'd hit it with a hammer but then i went posh Quote Link to comment Share on other sites More sharing options...
liner33 Posted September 10, 2018 Report Share Posted September 10, 2018 On 07/09/2018 at 21:19, SMARTLY said: Really? Different cars can have different gaps and there is no guarantee that all four plugs have the same gap out of the box rarely do different cars have different gaps modern spark plugs have a set gap that they operate best at , the problem with adjusting plugs is that some are very fragile and easy to damage if not careful Quote Link to comment Share on other sites More sharing options...
Tony Posted September 10, 2018 Author Report Share Posted September 10, 2018 That's a turn-a-round since back in their time the car wouldn't run unless the gap was correct. Quote Link to comment Share on other sites More sharing options...
