Rich Posted November 15, 2011 Report Share Posted November 15, 2011 I need to clean these up when I change the brakes as they're sticking on one side. What grease should I use afterwards, is it the red type? Where can I get a small tube from in the shops as I won't need much? Also can you grease the piston? Quote Link to comment Share on other sites More sharing options...
liner33 Posted November 15, 2011 Report Share Posted November 15, 2011 Usual copaslip , no need to do the pistons Quote Link to comment Share on other sites More sharing options...
scorps Posted November 15, 2011 Report Share Posted November 15, 2011 /\.....What he said, never do pistons as the grease will oooze out onto the pad surface when braking. Quote Link to comment Share on other sites More sharing options...
Rich Posted November 15, 2011 Author Report Share Posted November 15, 2011 But I thought copaslip can damage the rubbers that cover the pins? Quote Link to comment Share on other sites More sharing options...
scorps Posted November 15, 2011 Report Share Posted November 15, 2011 Never heard that,your only using a light coating on the pins. Quote Link to comment Share on other sites More sharing options...
Tony Posted November 15, 2011 Report Share Posted November 15, 2011 Officially it's a high temp resistant silicon based grease, in the real world it's copper-slip. Quote Link to comment Share on other sites More sharing options...
Rich Posted November 16, 2011 Author Report Share Posted November 16, 2011 So the copper stuff will be ok? I've read threads where people say it will eat rubber seals or it's too gritty to use on slide pins. What else would that kind of silicone grease be used for if I got some? Quote Link to comment Share on other sites More sharing options...
Tony Posted November 16, 2011 Report Share Posted November 16, 2011 Poly's..... Quote Link to comment Share on other sites More sharing options...
Rich Posted November 16, 2011 Author Report Share Posted November 16, 2011 Doesn't seem worth getting a tub of it then, think I'll put a smear of copper grease on. Quote Link to comment Share on other sites More sharing options...
hms Posted November 17, 2011 Report Share Posted November 17, 2011 There is a red high temp grease. Something like this: http://motorcycleproducts.co.uk/catalogue/...se-p-12073.html Coppaslip thickens with age. h Quote Link to comment Share on other sites More sharing options...
Rich Posted November 17, 2011 Author Report Share Posted November 17, 2011 Can you buy that grease in small tubes as this is probably the only time I will use it? Just bought some copper grease that cost me 9 quid, plus carb cleaner and still need brake cleaner! Not cheap all these sprays and greases! Quote Link to comment Share on other sites More sharing options...
Rich Posted November 19, 2011 Author Report Share Posted November 19, 2011 I'll probably go for the lithium grease that ECP sells - Click me! Quote Link to comment Share on other sites More sharing options...
Rich Posted November 25, 2011 Author Report Share Posted November 25, 2011 Just remembered I have some of this Castrol LM grease in the cupboard at home...will that be ok to use? It's lithium based and has a high melting point. Quote Link to comment Share on other sites More sharing options...
Tony Posted November 25, 2011 Report Share Posted November 25, 2011 Ideal. Quote Link to comment Share on other sites More sharing options...
Rich Posted November 25, 2011 Author Report Share Posted November 25, 2011 I'll take that as a yes then! Quote Link to comment Share on other sites More sharing options...
Tony Posted November 25, 2011 Report Share Posted November 25, 2011 To the point Quote Link to comment Share on other sites More sharing options...
Rich Posted November 25, 2011 Author Report Share Posted November 25, 2011 Shall I just go down Allparts and get some red grease then Quote Link to comment Share on other sites More sharing options...
