My handling problems
  • Replies 66
Posted Images
Got the car back 30 minutes ago, it’s as high as a range rover but it was a risk I had to take. The ride is smoother as you'd expect and there is quite a bit of roll, however I didn't get the chance to test the handling. Although I did chuck it over a roundabout and it did seem to have plenty more grip, I will report back tonight and get a wheel alignment in the morning.
this thread has got me thinkin now ! my last 2 mk1 mondeo's havnt been lowered atall and though the handeling was!well pooo tbh.but this 1 i have now is lowered 40mm on monroe shock's {standard replacment i beleave } not sure who made the spring's ;) but cant beleave how well it handle's! nice tight steering,very direct and responsive! the last owner never had alingment done after droppin it and the steerin wheel is a nat's c**k out to the right ! strange how on 1 it make's the handlin bad and on the same car but differant mk.
Been out for a drive tonight...
Ride quality has been improved, the roll isn't that bad really although the looks will take some getting used to.
The handling has improved noticeablely which I am happy about, its not as good as I was expecting but I will put that down to the tyres as the Dunlops its on arent that great; they seem too soft. The steering seems to have lost a lot of responsive though, it feels really saggy at low speeds.
Overall I am glad I got the old springs fitted, the whole dilema has cost me a lot of money which is a shame, but I will live and learn. I'll go to the alignment centre tomorrow and get a print out report of the alignment, I'll then post it here and hopefully Tony or someone will be able to tell me if its worth fixing/aligning. Tony, do you know what the standard SAI be for my model car? (Mondeo TDCi).
Once again, thanks all very much for your help; I'll be sure to stick around.
Gary
Gary
The "stock" positions for the KPI was never released by Ford.... You need to concentrate on the Toe positions for now since they must be in distress.
Done a few miles since having the suspension fitted so I thought it was time to get a wheel alignment, you were right Tony; the toe was well out! However the SAI is now 14*, it use to be 15*. Is this bad? I asked the operator what the SAI to test his knowledge and he told me its how much the wheels can turn from left to right :thumbsup_anim:
The SAI at 14d has now changed the good old scrub radius more toward the tyres centre, or below the steering pivotal axis... This is good news :unsure: How goes she handle now?
Yes it does handle better mate, much more acceptable and the feel through the steering gives me more confidence. Its not as good as I had hoped but maybe thats just the Dunlop tyres (they are very soft). So would you say 14d is more normal? You wouldn't think 1 degrees would make such a difference but it does. The car drives sweet now that its been re-aligned, although they charged me £64 :thumbsup_anim:
The SAI/KPI is a perpendicular angle measured against vertical. The lower the figure, the higher the pin is to the vertical.
So the after figures show the pin in a more elevated position... Moving the position of the scrub radius inward to the centre of the steer axis ..... "That's good" :thumbsup_anim:
But what about the camber and castor? They were within tolerances on both occassions but have been reduced considerably in the after.
Point to remember is the cars suspension components are not fixed at right angles. So any change in the parallelograms will move the entire chassis positions.
The "checking range" is vast. What everyone needs to concentrate on is the "target positions" not the range. It angers me to the max that the range is color coded?
Example> Outside the range is red, near is yellow, within is green. Within for the camber has a target of -33' with a range of + - 1 degree 18' and displayed green within that range? So you could have a front camber like \ \ and it be seen as green :thumbsup_anim:
