NickT Posted December 18, 2016 Report Share Posted December 18, 2016 After all this I bet it'll be something silly like tyres or a rear suspension bush causing the wayward steering because of rear steer . . Quote Link to comment Share on other sites More sharing options...
Tony Posted December 18, 2016 Report Share Posted December 18, 2016 It's definitely something outside of the box? Quote Link to comment Share on other sites More sharing options...
Gman Posted December 18, 2016 Author Report Share Posted December 18, 2016 I'm starting to think the same .. I can't but think they have missed something simple ... Yes am pretty sure the ECU as been read . The car is better then what it was but still no where near how it should be back roads are a constant fight. Quote Link to comment Share on other sites More sharing options...
Tony Posted December 19, 2016 Report Share Posted December 19, 2016 If the handling is so pronounced are you sure Ford won't entertain further inspection? Quote Link to comment Share on other sites More sharing options...
Gman Posted December 19, 2016 Author Report Share Posted December 19, 2016 Not sure at this point waiting to hear back from Ford. Quote Link to comment Share on other sites More sharing options...
Tony Posted December 20, 2016 Report Share Posted December 20, 2016 If not tell them you will take it for arbitration Quote Link to comment Share on other sites More sharing options...
Gman Posted December 22, 2016 Author Report Share Posted December 22, 2016 I'm pulling my hair out over this !! Ford have been in contact I've filed a complaint so just have to wait now. Strange thing happened tonight when reversing I turned onto full lock wheel wouldn't turn any more then the wheel turned again further .... I've also noticed the lock seems less then before... ?? Shed any light on this Tony. Thanks Quote Link to comment Share on other sites More sharing options...
SMARTLY Posted December 22, 2016 Report Share Posted December 22, 2016 On the Mk3 the lock is different depending on the size of the wheels so they don't foul the arches, maybe one of the stops has come off or been damaged. Think it's 17" upwards. Quote Link to comment Share on other sites More sharing options...
Gman Posted December 22, 2016 Author Report Share Posted December 22, 2016 I'm on 18" . Stops ? Where are these exactly and how do they work? I take it they are basically a rubber type stop to stop like you say the tyre fouling. Quote Link to comment Share on other sites More sharing options...
Tony Posted December 23, 2016 Report Share Posted December 23, 2016 Is the restricted lock only on one side? Quote Link to comment Share on other sites More sharing options...
SMARTLY Posted December 23, 2016 Report Share Posted December 23, 2016 No idea, just remember them being there on the two that I had. Meant a apin reversing off my drive and backwards in a 180 on the road ( corner ) to go out. Have you posted or searched on the Focus TalkFord forum? Try here, looks like it's both sides and in the rack: https://www.fordpartsuk.com/shop/ford_focus_steering_rack_limiter_kit_f_1717039_c_964.htm Quote Link to comment Share on other sites More sharing options...
Gman Posted December 26, 2016 Author Report Share Posted December 26, 2016 Yes thinking about it i think it is ... 😬 Quote Link to comment Share on other sites More sharing options...
Gman Posted January 5, 2017 Author Report Share Posted January 5, 2017 This seems never ending ... car is going back to Ford in a couple of wks time they have agreed to look at it with no charge and take it from there..,! Car as got worse it's now developed a steering wheel vibration from 55mph upwards and it's started to clonk with slow manoeuvres as well as the other issues... If I could hand this car back I would . 😬 Quote Link to comment Share on other sites More sharing options...
Tony Posted January 6, 2017 Report Share Posted January 6, 2017 Are they sure the drive train is ok??? Quote Link to comment Share on other sites More sharing options...
NickT Posted January 6, 2017 Report Share Posted January 6, 2017 I bet 50p they've tightened all the suspension bolts up with the wheels not on the floor and the bushes are pre loaded Quote Link to comment Share on other sites More sharing options...
Tony Posted January 6, 2017 Report Share Posted January 6, 2017 I agree it's something that silly. Quote Link to comment Share on other sites More sharing options...
Gman Posted January 8, 2017 Author Report Share Posted January 8, 2017 Not sure Tony but this would definitely be a area I would of thought could be damaged on a impact. Quote Link to comment Share on other sites More sharing options...
Tony Posted January 9, 2017 Report Share Posted January 9, 2017 Any history of an impact? Quote Link to comment Share on other sites More sharing options...
Gman Posted January 10, 2017 Author Report Share Posted January 10, 2017 Just the hole that I hit .. Quote Link to comment Share on other sites More sharing options...
Gman Posted January 10, 2017 Author Report Share Posted January 10, 2017 On a slightly different subject .. I have recently got a Peugeot partner van that pulls severely to the left.. steering wheel is straight . Having googled this it appears many of these vans are affected by this due to the rear subframe being slightly out. If this is the case could a good alignment center improve it? Thanks Quote Link to comment Share on other sites More sharing options...
Tony Posted January 11, 2017 Report Share Posted January 11, 2017 Well the rear beam can be moved but i find most times it's the front tyres making the van pull..... Easy test is swap them side-to-side. Quote Link to comment Share on other sites More sharing options...
Gman Posted January 12, 2017 Author Report Share Posted January 12, 2017 Thanks , the car is my main gripe after it cost me £1400 !! I've just listed 7 items / issues with the car since the new rack. Can't wait to see what Ford say! 🤔 Quote Link to comment Share on other sites More sharing options...
SMARTLY Posted January 12, 2017 Report Share Posted January 12, 2017 £1400 !! cheap Quote Link to comment Share on other sites More sharing options...
Gman Posted January 13, 2017 Author Report Share Posted January 13, 2017 That's £1400 to fix ... the car cost 14k . 😀 Quote Link to comment Share on other sites More sharing options...
SMARTLY Posted January 14, 2017 Report Share Posted January 14, 2017 Ah sorry I misunderstood. So you paid £1400 to fix and it's not fixed? Quote Link to comment Share on other sites More sharing options...
