Tony Posted August 12, 2015 Report Share Posted August 12, 2015 What's the best night time setting...... Low light, sunset, Auto or something else. Quote Link to comment Share on other sites More sharing options...
SMARTLY Posted August 12, 2015 Report Share Posted August 12, 2015 Try video Otherwise I'd set it on multi-shot if you have that setting or maybe long exposure, I'm not a photographer - can you tell Quote Link to comment Share on other sites More sharing options...
Sagitar Posted August 12, 2015 Report Share Posted August 12, 2015 Lightning isn't easy Tony - auto is no good. You need to devote some time to it, be patient and do some trial and error. There are storm chasers who have written about their experiences and reading them may help you. There is no magic bullet. First, remember that it's dangerous and you may be best off shooting from indoors (and it will keep the camera dry). You need the camera on a tripod; use a lens that will cover a reasonable area of the sky and use a remote release. Set the camera manually. Set the ISO to about 400; use a mid-range aperture so that you get a reasonable depth of field and don't lose too much of the available light (I would try f5.6 to start). Set the shutter on "bulb" so that you can open and close the shutter manually. Frame the area of sky in which you anticipate lightning and focus manually on a distant point (a street light a couple of miles away is good). Then leave the settings alone. Open the shutter with the remote release and keep it open for a period. If there is a lightning flash, close the shutter at once and have a look at the image that resuts. If it's over exposed reduce the ISO setting; if under exposed increase the ISO. You may need several attempts and it can take a long time to get something decent. 1 Quote Link to comment Share on other sites More sharing options...
Tony Posted August 13, 2015 Author Report Share Posted August 13, 2015 Thanks for the in depth explanation....I know the window to capture lightning is very small so added guidance is a great help.... I did manage a few shots years ago and captured a few strokes but they were not defined and although great for my ability at the time most would shrug them off. Quote Link to comment Share on other sites More sharing options...
Rich Posted August 14, 2015 Report Share Posted August 14, 2015 I've not tried myself yet but it won't be easy to capture and will take alot of patience. Had a storm up here last night but no direct lightening, just the sky flashing. Quote Link to comment Share on other sites More sharing options...
Tony Posted August 14, 2015 Author Report Share Posted August 14, 2015 Had nothing here so i didn't even get the chance Quote Link to comment Share on other sites More sharing options...
