eddie Posted April 8, 2013 Report Share Posted April 8, 2013 Hi Tony, not sure when I last got my geo done, I think it was last year. Question: how often should it be done, annually or is every two years ok? The Lexus is driving ok but I have a problem, I get my antiskid coming on almost every time I pull away now, looked at the rear tyres and they seem fine, plenty of tread on them, so slightly confused? Quote Link to comment Share on other sites More sharing options...
Tony Posted April 8, 2013 Report Share Posted April 8, 2013 With the state of the roads it should be checked one a year i think, obviously the whole car won't need correcting so it's cheaper... Not sure if it's wrong the traction control would come on when you pull away. Quote Link to comment Share on other sites More sharing options...
eddie Posted April 8, 2013 Author Report Share Posted April 8, 2013 Well I need to do 10 year service, MOT Cam belt change etc. I will book her in after that, going to be an expensive month...... Quote Link to comment Share on other sites More sharing options...
eddie Posted April 8, 2013 Author Report Share Posted April 8, 2013 Was going to say, its nearly 9 years since you did the first Geometry on her, down Watford Lower High Street! Can't believe how time flies Quote Link to comment Share on other sites More sharing options...
parthiban Posted April 8, 2013 Report Share Posted April 8, 2013 Could it be a faulty ABS sensor thinking the wheels aren't spinning at the same speed even though they are? Quote Link to comment Share on other sites More sharing options...
eddie Posted April 8, 2013 Author Report Share Posted April 8, 2013 Could it be a faulty ABS sensor thinking the wheels aren't spinning at the same speed even though they are? Good point, I'll get the garage to check it out when the car goes in for a service Quote Link to comment Share on other sites More sharing options...
Tony Posted April 9, 2013 Report Share Posted April 9, 2013 Nine years .........I wouldn't mind but i remember it well. Quote Link to comment Share on other sites More sharing options...
parthiban Posted April 9, 2013 Report Share Posted April 9, 2013 Was going to say, its nearly 9 years since you did the first Geometry on her, down Watford Lower High Street! Can't believe how time flies I was thinking the same thing the other day, probably a similar time I first took my car down to see Tony........ Quote Link to comment Share on other sites More sharing options...
Tony Posted April 9, 2013 Report Share Posted April 9, 2013 A lot of water has passed under the bridge in that time Quote Link to comment Share on other sites More sharing options...
parthiban Posted April 9, 2013 Report Share Posted April 9, 2013 A lot of water has passed under the bridge in that time Absolutely, we're all older and wiser too hopefully Shows my car's getting on a bit too, was almost new when I first came down, coming up to 11 years old now Quote Link to comment Share on other sites More sharing options...
eddie Posted April 9, 2013 Author Report Share Posted April 9, 2013 A lot of water has passed under the bridge in that time Absolutely, we're all older and wiser too hopefully Shows my car's getting on a bit too, was almost new when I first came down, coming up to 11 years old now Yes indeed, mine is 10 years old this month. Great build quality and a lovely car to drive, thats why I never changed it all these years Im certainly older, not sure about wiser, hopefully a bit wiser! Quote Link to comment Share on other sites More sharing options...
Rich Posted April 9, 2013 Report Share Posted April 9, 2013 The Lexus is definitely a nice car and has aged well. I'm always admiring your 300 Eddie whenever I drive past. I would've liked one if it weren't for the bad mpg. Quote Link to comment Share on other sites More sharing options...
eddie Posted April 9, 2013 Author Report Share Posted April 9, 2013 Yeah I know what you mean about the mpg, at 1.40 a litre its best part of £80 to fill and you only get 280 miles odd out of the tank Quote Link to comment Share on other sites More sharing options...
Rich Posted April 9, 2013 Report Share Posted April 9, 2013 What size is the tank? Quote Link to comment Share on other sites More sharing options...
eddie Posted April 9, 2013 Author Report Share Posted April 9, 2013 59 litres is the most I can put in when its on fumes Quote Link to comment Share on other sites More sharing options...
parthiban Posted April 9, 2013 Report Share Posted April 9, 2013 59 litres is the most I can put in when its on fumes It's actually a 70l tank, I think the worst time was the one below when I got in about 67 litres - you're not being brave enough And yes that is 292 miles off that tankful (and mine's a 200) Quote Link to comment Share on other sites More sharing options...
eddie Posted April 9, 2013 Author Report Share Posted April 9, 2013 66.24 litres apparently, guess there must be a few litres left when I fill up, how much do you have left when the reserve light first goes on? Quote Link to comment Share on other sites More sharing options...
parthiban Posted April 9, 2013 Report Share Posted April 9, 2013 My guess is around 10-15 litres, I always do 40-50 miles after the light comes on. Quote Link to comment Share on other sites More sharing options...
eddie Posted April 9, 2013 Author Report Share Posted April 9, 2013 maybe I should be braver then, as soon as I see that light I just stop and stick some petrol in. Mind you these days I dont fill up that often I usually leave the tank half full unless its a long journey! Quote Link to comment Share on other sites More sharing options...
