parthiban Posted August 16, 2011 Report Share Posted August 16, 2011 My car is at the dealer at the mo for a service and to sort a few other issues, and one of those was that I was getting a knocking sound from the suspension sometimes. They investigated, and discovered a bolt that was corroded and almost all the way out (mistake I made was not actually asking what that bolt was screwed into ) The bolt has been replaced, but apparently having been screwed back in the car they can't get the geo back together. It's a noticeable problem too, the car won't drive true so they won't let me take the car either so I can bring it down to WIM. Any ideas what the issue is? Any other dealer and I'd suspect they were just trying to rip me off but these guys have had many chances to do that over the years and they're a pretty honest bunch so I'm pretty sure that's not it, just a bit concerned as to what's happened to the car as the geo at WIM wasn't that long ago and all was fine. Quote Link to comment Share on other sites More sharing options...
Tony Posted August 16, 2011 Report Share Posted August 16, 2011 Reads very odd...... when do you want to come in? Quote Link to comment Share on other sites More sharing options...
Rich Posted August 16, 2011 Report Share Posted August 16, 2011 Reads very odd...... when do you want to come in? I don't think he can if they won't give him the car back!! Quote Link to comment Share on other sites More sharing options...
Tony Posted August 16, 2011 Report Share Posted August 16, 2011 Find out what bolt it was and how the hell have "THEY" made the handling so bad. Quote Link to comment Share on other sites More sharing options...
parthiban Posted August 16, 2011 Author Report Share Posted August 16, 2011 Doesn't help that they seem to be baffled as to what the problem is too - nothing obviously wrong yet the geo is way out. Will try and get more info this afternoon. Quote Link to comment Share on other sites More sharing options...
parthiban Posted August 16, 2011 Author Report Share Posted August 16, 2011 Just got off the phone with Lexus, not sure what the bolt was but will find out and let me know in a bit, only thing they did know for sure was that it was one of the adjusting bolts used for the geo. Been told the track rod ends (not sure what they are) were seized solid so they've cut them off? New ones will be fitted tomorrow (at minimal cost it seems) and then all should be fine. Does that help explain the scenario at all? Quote Link to comment Share on other sites More sharing options...
Rich Posted August 16, 2011 Report Share Posted August 16, 2011 I'll guess it's a bolt for the camber then? The TRE (Track Rod Ends) are used to adjust the toe. When was your last geo, I wouldn't of thought they'd be that seized they need cutting off? Quote Link to comment Share on other sites More sharing options...
parthiban Posted August 16, 2011 Author Report Share Posted August 16, 2011 I'll guess it's a bolt for the camber then? The TRE (Track Rod Ends) are used to adjust the toe. When was your last geo, I wouldn't of thought they'd be that seized they need cutting off? This is where I'm a bit confused too, my last geo was around 2 months ago when I had the new tyres fitted........ Quote Link to comment Share on other sites More sharing options...
Rich Posted August 16, 2011 Report Share Posted August 16, 2011 There's no way they should be that seized then, nothing abit of heat couldn't sort out. Quote Link to comment Share on other sites More sharing options...
scorps Posted August 16, 2011 Report Share Posted August 16, 2011 A dealer wont heat t hem up, if they cant get them off they just cut em then hand you a bill for new one's. Quote Link to comment Share on other sites More sharing options...
parthiban Posted August 16, 2011 Author Report Share Posted August 16, 2011 A dealer wont heat t hem up, if they cant get them off they just cut em then hand you a bill for new one's. That probably explains it then - they're supposedly only a few pounds each though so hopefully there won't be a big bill involved. Quote Link to comment Share on other sites More sharing options...
Rich Posted August 16, 2011 Report Share Posted August 16, 2011 They're screwed onto the steering arm though so how they can they be cut off without damaging them! Quote Link to comment Share on other sites More sharing options...
Tony Posted August 16, 2011 Report Share Posted August 16, 2011 Locking nut on the steering arms are known to lock up on the Lexus bit i have never known a problem with the camber bolt? Quote Link to comment Share on other sites More sharing options...
