MKIV Toyota Supra
Thorin
Hi folks, only just recently discovered this forum and there's some very good info on here. I'll shortly be getting my alignment done and was after people opinions on here. :(
I own a '94 MKIV Toyota Supra RZ (Twin turbo), it's on the stock j-spec bilsteins and springs and 245/40/18 front, 275/35/18 back tyres. In stock form the supra is a rather heavy understeery beast so I was looking for something a bit more 'planted'. 99% of the time (if not more) the car is to be used on the road though so I'm not after some race setup or something that's going to give excessive uneven tyre wear.
The following info is from http://mkiv.com/techarticles/lance_alignment/index.html (pasted here for convenience) and the "Lance" set up seems well regarded...
Mr. Lance W. Recommended Alignment
This alignment is the result of experimentation with the factory numbers to improve road feel and to reduce inside edge wear on the rear tires that is common with the factory settings. These settings will add grip at the front and dramatically improve the feedback to the driver in the steering wheel. They will also reduce or eliminate inside edge wear on the rear tires, and I have gone as far as 24,000 miles on a set of Bridgestone S-02s with these settings. The car will still under steer slightly, but the aggressive driver will find much more predictable handling and significantly better feedback from the car. Obviously, these settings are still compromised for street use. Autocross, road race, and drag race competitors can use these as a baseline, but will probably require somewhat different settings to be competitive.
1. What is a Good Street/Lance W. Alignment?
Front:
* Camber - 1.0 degrees
* Caster + 5.0 degrees
* Toe 0.00 mm
Rear:
* Camber -1.5 degrees
* Toe in (total) 1.00 mm
(on 255/40R17 tires this rear toe equates to .090 deg, i.e. .045 deg per side)
(on 275/40R17 tires this rear toe equates to .088 deg, i.e. .044 deg per side)
The Front and Rear Toe are critical to tire wear, even small deviations from spec may cause unusual wear patterns or excessive wear.
2. What is the Stock Toyota Alignment?
Front:
* Camber - 0.5 degrees +/- 0.75
* Caster +3.5 +/- 0.75 degrees
* Toe 0.00 +/- 0.080" (2 mm)
Rear:
* Camber -1.50 +/- 0.75
* Toe in (total) 0.120" (3mm) +/- 0.080" (2mm)
To Calculate Degrees of Toe When Given mm of Toe:
* Note that this is dependent upon the wheel diameter and tire diameter
Formula: Calculate the Wheel + Tire Diameter (in mm) for the stock rear wheel + Tire
Example: (2 * tire width * aspect ratio / 100) + (wheel diameter) = wheel + tire diameter
(2 * 255mm * .4) + (17 * 25.4) = 635.8 mm
Here the goal is 1 mm of total toe in. (This is 0.5 mm on the driver rear tire and 0.5 mm on the passenger rear tire.)
We want to calculate the angle each side wheel + tire must deviate from a line parallel to the centerline of the car.
arcsin(0.5 mm / 635.8 mm) = .045 deg
.045 deg per side * 2 sides = .09 deg total toe in
Now that sounds good to me, but a member on the mkivsupra.net forum has been very vocal about some other settings, and even states that the stock settings, and the Lance ones, are rubbish. The settings however make no sense to me (positive camber on the front??), but I'm no expert. Is he on to something? Settings follow...
Thanks in advance for your comments,
Michael.
Hello and welcome to wim.... Your perception of the last report is totally correct... They are pants on the steer axis suggesting a real problem with cradle symmetry... Unless racing on an oval is your daily drive then positive over negative camber positions are not desired... nor is the displacement of the king-pins!
The Lance settings are comfortable in my opinion, my question is this though.. if under-steer is not desired how would you want the car more planted? This is possible but direct involvement at the Geometry will not satisfy you.
Totally different suggestion.... but won't having extra wide tyres at the back cause under-steer too....?
But I have larger tyres at the front too than the stock set up (235/255), but yes.
Thanks for the reply. I've not had anyone else so far recommend the second lot of settings. I'm just after something a bit less understeery and more balanced really, while not so much as to send me oversteering into a tree, so I think my mind is made up on the Lance settings :(
Another question while I'm here, anyone recommend anywhere to get my alignment setup done in or around the west yorkshire area?
The Lance positions are safe and a good starting position allowing you to develop the handling... I must say though few would recommend deviation from these settings without destroying the tyres.
  • 4 weeks later...
The Lance set-up will give you a nice safe understeer but if you want the car a bit more pointy without damaging tyres you might like to consider the following options.
1) What sort of ride height are you running and is the rear 10/15mm higher than the front?
2) To cure understeer and make the car more pointy consider the following.
Front
Caster=4.5 degrees
Camber=1.5 degrees neg
Toe= Parallel
Rear
Camber=1 degree neg
Toe= 3mm overall toe in
This should not have a detremental effect on tyres.
Hey Thorin, you wont go wrong if you get Tony to do it, he impressed me no end, not with just his work but his appreciation for cars......
[/hijack]
Hi Tony, I can now post eventually.......thanks for the set up the other day, I will post in the newbie section soon....
[/hijack]
[/hijack]
[/hijack]
No problem.... Please introduce yourself and the car to wim.... (i have rolleyes_anim.gif) Well the car anyway!
