Rich Posted February 20, 2010 Report Share Posted February 20, 2010 This thread here Never seen that before...is it a tyre, rim or fitting problem? Quote Link to comment Share on other sites More sharing options...
scorps Posted February 20, 2010 Report Share Posted February 20, 2010 Looks like it hasn't sealed properly on the rim. Quote Link to comment Share on other sites More sharing options...
Tony Posted February 20, 2010 Report Share Posted February 20, 2010 A cut on the bead line due to impact of a cut bead line due to fitting error, once the tyre is removed the location of the "cut" will reveal all. Quote Link to comment Share on other sites More sharing options...
Rich Posted February 20, 2010 Author Report Share Posted February 20, 2010 A cut on the bead line due to impact of a cut bead line due to fitting error, once the tyre is removed the location of the "cut" will reveal all. So the bead line had been split during the fitting process, should the garage replace it for them foc? Quote Link to comment Share on other sites More sharing options...
Tony Posted February 20, 2010 Report Share Posted February 20, 2010 A cut on the bead line due to impact of a cut bead line due to fitting error, once the tyre is removed the location of the "cut" will reveal all. So the bead line had been split during the fitting process, should the garage replace it for them foc? If the bead line is cut then the only way this could happen is by the fitting, garage is responsible without question. Quote Link to comment Share on other sites More sharing options...
parthiban Posted February 21, 2010 Report Share Posted February 21, 2010 Seeing it's a Focus RS and therefore very new it's a problem from the factory isn't it? Quote Link to comment Share on other sites More sharing options...
