Tony Posted June 27, 2011 Report Share Posted June 27, 2011 More likely it's blocked. Quote Link to comment Share on other sites More sharing options...
mac Posted June 27, 2011 Author Report Share Posted June 27, 2011 More likely it's blocked. ok thanks. and the only method for diagnosing is the lighter steering in one direction when wheels are in the air? nothing else? Quote Link to comment Share on other sites More sharing options...
Tony Posted June 27, 2011 Report Share Posted June 27, 2011 Wheels off the ground, also see if the steering moves when you start the car. Quote Link to comment Share on other sites More sharing options...
mac Posted June 27, 2011 Author Report Share Posted June 27, 2011 Wheels off the ground, also see if the steering moves when you start the car. no it doesnt but something that was happening before i changed the springs and shocks was that eveyr morning i came out to the car the steering wheel would have dropped off to the left (i always always leave it centred when i park) but i havent noticed it at all since i changed springs and shocks. Also told that the tolerance for the subframe position is quite wide by one individual whereas another told me it was a hairs breadth (ppl who moved subframe previously when car went straight). Quote Link to comment Share on other sites More sharing options...
Tony Posted June 27, 2011 Report Share Posted June 27, 2011 Let's hope it's not a wast of money. Quote Link to comment Share on other sites More sharing options...
mac Posted June 27, 2011 Author Report Share Posted June 27, 2011 Let's hope it's not a wast of money. dont think theres any point in going to move the subframe really based on the criteria you mentioned and i know it to be slightly easier to turn left when wheels in the air. Price of playing with moving the subframe would be about half the cost of a recondtioned rack. Quote Link to comment Share on other sites More sharing options...
Tony Posted June 27, 2011 Report Share Posted June 27, 2011 Have someone test the rack and see what they think. Quote Link to comment Share on other sites More sharing options...
mac Posted June 27, 2011 Author Report Share Posted June 27, 2011 Have someone test the rack and see what they think. my mechanic checked for play and said its fine and did his son (good guy) allignment guys did the same and the boss man told me that there is only a tiny bit of play but that if the valve is gone it cant be determined from a visual check. As for the turning left when in the air, two guys think its about the same both sides, one thinks its easier to turn left and this is what i think also (i have tested this a few times myself) although as i said the difference is very very marginal and takes some noticing but is there. was told there is no more testing that can be done on the rack Quote Link to comment Share on other sites More sharing options...
Tony Posted June 27, 2011 Report Share Posted June 27, 2011 Then the cheaper option is to move the sub-frame. Quote Link to comment Share on other sites More sharing options...
mac Posted June 27, 2011 Author Report Share Posted June 27, 2011 Then the cheaper option is to move the sub-frame. not if its not causing the problem which every1 is adamant its not. all the allignment guys say that amount of caster wont cause the pull but will move the subframe is i want. Quote Link to comment Share on other sites More sharing options...
Tony Posted June 27, 2011 Report Share Posted June 27, 2011 In theory the castor difference would need to be more than a degree. Quote Link to comment Share on other sites More sharing options...
mac Posted June 27, 2011 Author Report Share Posted June 27, 2011 In theory the castor difference would need to be more than a degree. yep i know. the subframe seems to line up well both as per the pins and hte geo itself. After last allignment, i was speaking the boss for a while and he said many 6 month old cars didnt line up as well as that and based on the quick glance he has at hte subframe position he wouldnt go chasing that (probably cos he hasnt got a beam jack on the geo) and would change out hte rack. The other guy who has the beam jack said he would move the subframe but didnt think it would make a noticable difference. I cant afford to waste money so am inclined not to look at moving the subframe based on several opinions. What would be your move at this junction. Quote Link to comment Share on other sites More sharing options...
Tony Posted June 27, 2011 Report Share Posted June 27, 2011 Flush the power steering fluid with a cleaner and replace with new fluid. Quote Link to comment Share on other sites More sharing options...
mac Posted June 27, 2011 Author Report Share Posted June 27, 2011 Flush the power steering fluid with a cleaner and replace with new fluid. we did and i was there when it was done, cleaner and new fluid, bought it myself. only a few months ago. After that Quote Link to comment Share on other sites More sharing options...
Tony Posted June 27, 2011 Report Share Posted June 27, 2011 Move the sub-frame before changing the rack. Quote Link to comment Share on other sites More sharing options...
mac Posted June 27, 2011 Author Report Share Posted June 27, 2011 Move the sub-frame before changing the rack. ok i will think on it. not doing it today though. Quote Link to comment Share on other sites More sharing options...
mac Posted June 27, 2011 Author Report Share Posted June 27, 2011 cheers for all the help tony. out of interest have you ever encountered a difference in caster of 28' creating a strong pull in all your years? Quote Link to comment Share on other sites More sharing options...
Tony Posted June 27, 2011 Report Share Posted June 27, 2011 No it's to small an amount. Quote Link to comment Share on other sites More sharing options...
mac Posted June 27, 2011 Author Report Share Posted June 27, 2011 No it's to small an amount. Thanks for that. completely illogical to touch subframe then really. Have you had any racks causing a pull because that seems to be extremely rare also. Quote Link to comment Share on other sites More sharing options...
Tony Posted June 27, 2011 Report Share Posted June 27, 2011 Had that many times over the years....... What about the rack on ER's car, he's braking the car. Quote Link to comment Share on other sites More sharing options...
mac Posted June 27, 2011 Author Report Share Posted June 27, 2011 Had that many times over the years....... What about the rack on ER's car, he's braking the car. Really? you had the rack causing a pull a lot? Do you know if ER's is mark 3? im in ireland so the shipping of a 2nd hand rack would prob make it a lot more than one i could pick up here Quote Link to comment Share on other sites More sharing options...
Tony Posted June 27, 2011 Report Share Posted June 27, 2011 Yeah, because the pressure in the rack is not equal Quote Link to comment Share on other sites More sharing options...
Rich Posted June 27, 2011 Report Share Posted June 27, 2011 It's a MK2 mate so probably different...sounds like a nightmare problem you have though Quote Link to comment Share on other sites More sharing options...
mac Posted June 27, 2011 Author Report Share Posted June 27, 2011 It's a MK2 mate so probably different...sounds like a nightmare problem you have though yeah its been a lengthy process. Car is actually much nicer to drive now since i changed springs and shocks. Car will go where steering wheel directs it and feels more stable but the second the steering wheel is released it wants to go to the left so constant pressure has to be applied to hte steering to counter this. To be honest through process of elimination it can only be the rack and/or subframe position but im not in an position to put more money into it right now without being certain although there appears to be a very grey area surrounding rack issues. TG over on talkford is having an issue with his steering rack not being centered and various other things so im not alone. Quote Link to comment Share on other sites More sharing options...
