Daz f Posted February 4, 2009 Report Share Posted February 4, 2009 I didnt know this was happening until i was told about it Would this upset the handling Can it be cured What gains could i expect ?????? This is a bit of a better pick Quote Link to comment Share on other sites More sharing options...
Tony Posted February 4, 2009 Report Share Posted February 4, 2009 Definitely an issue with torsional chassis flex, what bracing to you have "sprung/ unsprung?". Quote Link to comment Share on other sites More sharing options...
Tony Posted February 4, 2009 Report Share Posted February 4, 2009 Lateral linkages seem reasonably braced..... Why did you remove the rear ARB? Â BHP explains the chassis flex. Â I assume the camber adjuster are front only? Â Has the Geometry calibration been set at all? Â What is the cars arena..... track, trial, drag? Quote Link to comment Share on other sites More sharing options...
Daz f Posted February 4, 2009 Author Report Share Posted February 4, 2009 Definitely an issue with torsional chassis flex, what bracing to you have "sprung/ unsprung?". I have a front strut brace , the centre underneath the car by the rear gbox mount has a big brace And i have a full bolted in roll cage But it does have a webasto sun roof  Quote Link to comment Share on other sites More sharing options...
Rich Posted February 4, 2009 Report Share Posted February 4, 2009 Can't help with your issues but that's a cool looking car and looks like alot of work has gone into it Quote Link to comment Share on other sites More sharing options...
Daz f Posted February 4, 2009 Author Report Share Posted February 4, 2009 Lateral linkages seem reasonably braced..... Why did you remove the rear ARB? BHP explains the chassis flex.  I assume the camber adjuster are front only?  Has the Geometry calibration been set at all?  What is the cars arena..... track, trial, drag?  I removed the rear ARB as i had spoken to some pre 74 race dolomite owners And they said it helped with the turn in and i did notice it was a little better on track Yes camber and castor adjustment only on the front The geometry calibration was set years ago when i first fitted the different rear axle and rebuilt front suspension I do use the car on the road but i want the car to do very well on track days So i would say track arena I also do (not very often) drag and usually put 150 lb springs on the back, Quote Link to comment Share on other sites More sharing options...
Daz f Posted February 4, 2009 Author Report Share Posted February 4, 2009 Can't help with your issues but that's a cool looking car and looks like alot of work has gone into it Thanks it has taken me a while You may recognise the engine i have fitted Here is a build pick Its changed quite a bit since then Quote Link to comment Share on other sites More sharing options...
Rich Posted February 4, 2009 Report Share Posted February 4, 2009 Engines aren't my strong point but is it a cossie? Quote Link to comment Share on other sites More sharing options...
CIH Posted February 5, 2009 Report Share Posted February 5, 2009 oh wow is that the Dolly Cossie from RetroCars issue1 ? I didn't know it was still around! I nearly got a (standard) sprint a few years ago. Even knocked around the Dolomite Owners club forum for a little while. Quote Link to comment Share on other sites More sharing options...
Tony Posted February 5, 2009 Report Share Posted February 5, 2009 What suspension do you have on the front? Quote Link to comment Share on other sites More sharing options...
Daz f Posted February 5, 2009 Author Report Share Posted February 5, 2009 What suspension do you have on the front? I have AVO double adjustables But they are a bit of a shorter stroke I think its a 13" stroke as standard I have 10" as its lowered, Quote Link to comment Share on other sites More sharing options...
Daz f Posted February 5, 2009 Author Report Share Posted February 5, 2009 oh wow is that the Dolly Cossie from RetroCars issue1 ? I didn't know it was still around! I nearly got a (standard) sprint a few years ago. Even knocked around the Dolomite Owners club forum for a little while. Yes it was in Retro issue 1 Quote Link to comment Share on other sites More sharing options...
Tony Posted February 5, 2009 Report Share Posted February 5, 2009 What suspension do you have on the front? I have AVO double adjustables But they are a bit of a shorter stroke I think its a 13" stroke as standard I have 10" as its lowered, Â Do they have adjustable pre-load? Quote Link to comment Share on other sites More sharing options...
Daz f Posted February 5, 2009 Author Report Share Posted February 5, 2009 What suspension do you have on the front? I have AVO double adjustables But they are a bit of a shorter stroke I think its a 13" stroke as standard I have 10" as its lowered, Â Do they have adjustable pre-load? The only adjustment is spring seat And 13 click adjustment wheel These on the right Quote Link to comment Share on other sites More sharing options...
Tony Posted February 5, 2009 Report Share Posted February 5, 2009 That's a shame, i wanted to off-set the pre-load..... Is there any possibility the bracing could be increased? Quote Link to comment Share on other sites More sharing options...
Daz f Posted February 5, 2009 Author Report Share Posted February 5, 2009 That's a shame, i wanted to off-set the pre-load..... Is there any possibility the bracing could be increased? I would like to purchase some decent shocks but dont know which ones to buy. Do you mean to stiffen the chassis As all i could do now if you mean this is to have the cage welded in fully And have it through the bulk head and welded to the turret tops I think the torsional rigididty is quite good as i can lift the front wheel up of the ground With a jack the doors all open and shut ok. (Which i didnt think was bad for a 35 year old chassis) Not like a Rover 200 my sister had ..... Quote Link to comment Share on other sites More sharing options...
Daz f Posted February 5, 2009 Author Report Share Posted February 5, 2009 Engines aren't my strong point but is it a cossie? Yes it is a cossie engine Here is my rolling road report Its a bit more powerfull now due to more boost and nitrous Got to love the cosworth engine   Quote Link to comment Share on other sites More sharing options...
Tony Posted February 5, 2009 Report Share Posted February 5, 2009 Would you agree the images displaying lift are under acceleration? Quote Link to comment Share on other sites More sharing options...
Daz f Posted February 5, 2009 Author Report Share Posted February 5, 2009 Here is a racing dolomite doing about the same Is it just a trait of the Dolomites to do this ? I hope mine hasnt turned to jelly Quote Link to comment Share on other sites More sharing options...
Daz f Posted February 5, 2009 Author Report Share Posted February 5, 2009 Would you agree the images displaying lift are under acceleration? The very top picture i was on trailing throttle and just turning as i went into the corner too quick And didnt want to touch the throttle until i had made it mostly through the corner Quote Link to comment Share on other sites More sharing options...
Tony Posted February 5, 2009 Report Share Posted February 5, 2009 Here is a racing dolomite doing about the sameIs it just a trait of the Dolomites to do this ? I hope mine hasnt turned to jelly  I see that.... But the problem then was diagonal loading during transition, plus castor sweep was a mystery in those days.  The images of your car are under thrust application, do you agree with that? Quote Link to comment Share on other sites More sharing options...
Rich Posted February 5, 2009 Report Share Posted February 5, 2009 Engines aren't my strong point but is it a cossie? Yes it is a cossie engine Here is my rolling road report Its a bit more powerfull now due to more boost and nitrous Got to love the cosworth engine    That's mental!!  Don't suppose you have a copy of the feature when it was in Retro so I (we) can have a read? Quote Link to comment Share on other sites More sharing options...
Daz f Posted February 5, 2009 Author Report Share Posted February 5, 2009 Here is a racing dolomite doing about the sameIs it just a trait of the Dolomites to do this ? I hope mine hasnt turned to jelly  I see that.... But the problem then was diagonal loading during transition, plus castor sweep was a mystery in those days.  The images of your car are under thrust application, do you agree with that? Yes it does seem to happen under accelerating out of tight corners Could the rear suspension be set up too soft ? Quote Link to comment Share on other sites More sharing options...
Daz f Posted February 5, 2009 Author Report Share Posted February 5, 2009 Engines aren't my strong point but is it a cossie? Yes it is a cossie engine Here is my rolling road report Its a bit more powerfull now due to more boost and nitrous Got to love the cosworth engine    That's mental!!  Don't suppose you have a copy of the feature when it was in Retro so I (we) can have a read? I would have to find it out of the loft and scan it Will have a look at the weekend :-) Quote Link to comment Share on other sites More sharing options...
Daz f Posted February 5, 2009 Author Report Share Posted February 5, 2009 Here is another pick of a racing dolomite back in the 70s that looks like its doing the same as mine Looks like the rear is well squated Quote Link to comment Share on other sites More sharing options...
