jammy Posted September 25, 2008 Report Share Posted September 25, 2008 Tony whats the easyest way to do this ? Quote Link to comment Share on other sites More sharing options...
Tony Posted September 25, 2008 Report Share Posted September 25, 2008 Why? Quote Link to comment Share on other sites More sharing options...
jammy Posted September 25, 2008 Author Report Share Posted September 25, 2008 New rack on the stra.and also a mate just had a new box fitted to his omega and wheel is out by miles.so advised him to make sure wheel is centralised before optin for alingment Quote Link to comment Share on other sites More sharing options...
Tony Posted September 25, 2008 Report Share Posted September 25, 2008 I see.... well both examples will need the thrust established so they need to go on a laser rig at least mate. Quote Link to comment Share on other sites More sharing options...
jammy Posted September 25, 2008 Author Report Share Posted September 25, 2008 Lasre ring to get it some what near im gunna fit it and then count turns lock to lock then sit wheel in the middle ie my astra is 3 turns lock to lock so was gunna do full lock then turn back 1 and a half then sit wheel in that spot and get it to you for some magical wimness Quote Link to comment Share on other sites More sharing options...
Tony Posted September 25, 2008 Report Share Posted September 25, 2008 Lasre ring to get it some what near im gunna fit it and then count turns lock to lock then sit wheel in the middle ie my astra is 3 turns lock to lock so was gunna do full lock then turn back 1 and a half then sit wheel in that spot and get it to you for some magical wimness Well yes.... maneuvering the ends in and out will straighten the steering position but my point was this won't finalise the toe. Quote Link to comment Share on other sites More sharing options...
Rich Posted September 25, 2008 Report Share Posted September 25, 2008 Been tinkering again mate! Quote Link to comment Share on other sites More sharing options...
jammy Posted September 25, 2008 Author Report Share Posted September 25, 2008 Lol not yet rich.my non power rack will be here tuesday so will be then.i know the final tow wont be right tony just want it drivable till such time it gets set up again.if the omega needs goe'in then il be bringin that up for ya at some point in the manual there is a guide to go to as to centre the wheel.whisch is summity like 325mm from end of track arm to point a on the rack so will set it there and see what the outcome is from that Quote Link to comment Share on other sites More sharing options...
