Tony Posted February 13, 2008 Report Share Posted February 13, 2008 This customer had the car calibrated and after had appalling handling, his new front tyres were visibly damaged after 50 miles.. The report he was given has been fabricated since the Geometry was obviously distressed so to go from that report to what i measured is not possible.... The car does have one angle that is out of adjustment so there is an issue but the method they used to counter this is a killer... The before figures display how the car was left after their calibration..... I'll display the image again since the forum engine shrinks the first image Can anyone see an issue here Quote Link to comment Share on other sites More sharing options...
Janey Posted February 13, 2008 Report Share Posted February 13, 2008 Eyes are a bit fuzzy but....are half the numbers still out of range ?? and some even worse than they were before Quote Link to comment Share on other sites More sharing options...
jon Posted February 13, 2008 Report Share Posted February 13, 2008 Some interesting toe going on there. Quote Link to comment Share on other sites More sharing options...
Noel Posted February 13, 2008 Report Share Posted February 13, 2008 Some interesting toe going on there. crazy toe might be a better word... or cross eyed perhaps Quote Link to comment Share on other sites More sharing options...
alnug Posted February 13, 2008 Report Share Posted February 13, 2008 I don't understand how you can get that much crazy toe figures!?!?!?!......in the rear it's even worse after?!?!? and why did they make it Toe out MORE in the rear!??! Quote Link to comment Share on other sites More sharing options...
jammy Posted February 13, 2008 Report Share Posted February 13, 2008 did the rear even need adjusting ? Quote Link to comment Share on other sites More sharing options...
Bazza Posted February 14, 2008 Report Share Posted February 14, 2008 interesting that the rear toe is so far out but whats more interesting is that the front looks reasonably within the parameters but tyre wear damage occurs at the front tell more Tony Quote Link to comment Share on other sites More sharing options...
Tony Posted February 14, 2008 Author Report Share Posted February 14, 2008 The problem with this car is the OSR toe adjuster. When the other company tried to calibrate the car the used the camber adjuster to change the toe position. The toe adjuster needs attention but so the owner can drive the car i needed to make things as symmetrical as possible, hence the deeper NSR camber. What happened to the OSF toe i cannot explain..... 22mm of toe in is hardly a small error Additionally his Geo report was doctored, according to that all was well Quote Link to comment Share on other sites More sharing options...
