My Swap V8 into IS200
marcus
Hi guys, as most of you know i started my V8 swap some time ago well 11 months to this day :D as all ways i jump in head first :) Why? well you could say im not to good at saveing, so the only thing to do was to start the swap! and by doing so i had to do it.
First i had to find an engine for my swap, i ended up get a LS400 1991 of of ebay for 360.00 i think! it was as the car was not running, so of i go to pick the car up had alook over it, seen what was up with it and with in 30 mins i got it running :D
This is the LS400
http://links.pictures.aol.com/pic/d610zsDH...vm846VxH1_l.jpg
and here is the V8 i will be useing
http://links.pictures.aol.com/pic/d610zsDH...JEj4hu7Pt_l.jpg
The engine has only done 120,000K and as they go on untill about 5 to 600,000K the engine has alot of life in it.
But before i could think about droping the V8 into the IS i had alot of work to get done first. as some weeks before i had started work on the IS first i took the Turbo kit of and that went to a good home, then the gearbox had to come of, then out with the IS engine.
I then started to work on takeing the body/kit of and replaceing it with a custom one that i made, along with a custom bonnet...>>
The custom bonnet, just the one pic for now....
http://links.pictures.aol.com/pic/d610zsDH...FZwLCOt8g_l.jpg
Here is the start of the custom sideskirts i made.....
http://links.pictures.aol.com/pic/d610zsDH...7kszrLxJd_l.jpg
next stage
http://links.pictures.aol.com/pic/d610zsDH...Vwj0NUdvj_l.jpg
and the next
http://links.pictures.aol.com/pic/d610zsDH...qORLTUa5o_l.jpg
and the last stage, they dont sit that low and the full kit is not OTT at all
http://links.pictures.aol.com/pic/d610zsDH...snBxUJF6C_l.jpg
and with that out the way i started the body/work as i want to paint the car "Jet black" and i have to say this is the first and last time i paint a car at home :D but it went well...
Stage 1
http://links.pictures.aol.com/pic/d610zsDH...KNJRIxGUZ_l.jpg
http://links.pictures.aol.com/pic/d610zsDH...gLSn4d61*_l.jpg
stage 2
http://links.pictures.aol.com/pic/d610zsDH...b9uDu9KNk_l.jpg
http://links.pictures.aol.com/pic/d610zsDH...c7JcCHCDw_l.jpg
But this was done some months ago and now im thinking of doing it 2 tone :D
well thats the body work done nex comes the big job, the engine swap :) :)
Post was edited by marcus
  • Replies 64
UPDATE!!!
I went out to start work on takeing the V8 out of the LS400 ( standing there thinking to myself what the hell have i got myself into ;) ) with that i just started to take all the parts around the engine of, and put them to one side.
Took the air/intake of just to make it easy on me to get the rest of the bits of, Then went on to disconnect all the pipe/work from the engine, took the Rad of and the aircon...i have all so done away with the aircon to make room for the Turbo to sit down there.
engine with air/intake off...
http://links.pictures.aol.com/pic/d610zsDH...p*xfP-rCW_l.jpg
all the bit that had to come off are!
http://links.pictures.aol.com/pic/d610zsDH...ZHjVby7cK_l.jpg
Next to come out was the "gearbox" and disconnect the Exhaust's
http://links.pictures.aol.com/pic/d610zsDH...XHnD4BZjW_l.jpg
http://links.pictures.aol.com/pic/d610zsDH...XKjOkfUhg_l.jpg
Next was to take the engine out :) here are some pic,s of it out>>
http://links.pictures.aol.com/pic/d610zsDH...w*IV**GT5_l.jpg
http://links.pictures.aol.com/pic/d610zsDH...ZM1ijyj6H_l.jpg
as you can see by them pic,s its in my workshop, now i could start to work on the engine just to make it look a lot better than it was. once i had it there i took the cam/covers of not just to work on them but to see what was going on inside and this is what i had to find
http://links.pictures.aol.com/pic/70c0WTrx...rF-qxC*8C_l.jpg
as you can see not looking to good, but when i asked around on the V8 site it seemed it was no where as bad as some of the V8,s on there. here is the left side looking a lot better :)
http://links.pictures.aol.com/pic/70c0WTrx...Dlngn0mD3_l.jpg
so with the cam/cover off i started to work on them to make them look 100 time better than they did. they went from this>>
http://links.pictures.aol.com/pic/d610zsDH...ht9r8hSxT_l.jpg
to this>>
http://links.pictures.aol.com/pic/d610zsDH...aao9bblGX_l.jpg
http://links.pictures.aol.com/pic/d610zsDH...mqgmB-Z5v_l.jpg
http://links.pictures.aol.com/pic/d610zsDH...TJa**WgFj_l.jpg
all so did the PS pot>>
http://links.pictures.aol.com/pic/d610zsDH...Kh0OWgHXv_l.jpg
and the fuel rails before>>
http://links.pictures.aol.com/pic/d610zsDH...kOTYBF5iv_l.jpg
fuel rails now>>
http://links.pictures.aol.com/pic/d610zsDH...bjKFUbrnE_l.jpg
ok thats all for now i will do some more later :)
Right where was i....
ruel rails...^^
Right this is what the engine looks like now>
http://links.pictures.aol.com/pic/d610zsDH...xu2jWsziF_l.jpg
so the next thing to do was drop the V8 into the IS for a test fit!
at first i tryed it in with the LS engine mounts on and right away i could see that there was no way that i could use them, so out came the engine and i tryed the IS mounts on the engine and droped it back down and it fitted but It was sitting a bit low so i had to make some 10mm spacer, and now it fits (as if it had all ways been there)
it sits more to the front of the car than the IS engine did but only by 50mm but as its not as long as the 1G-FE so now i have about 100mm at the back of the engine bay :) but as the V8 is not that much heavier than the 1G, it should not be a problem (i hope)
100mm space at the back>>
http://links.pictures.aol.com/pic/d610zsDH...DKLzvAzjk_l.jpg
Engine in place>>
http://links.pictures.aol.com/pic/d610zsDH...-*L5ugiCO_l.jpg
http://links.pictures.aol.com/pic/d610zsDH...P0R0dRyHR_l.jpg
With the engine in place it was time to look for a gearbox. I got a 5 speed gearbox out of supra turbo :) some of the guys in the US use this box and one guy has over 400bhp so i know it can take the power. well it was flip up out of the 5 or 6 speed supra boxs and as the 6 speed is so hard to get and not only that the price tag on the 6 speed it was not much of a flip :) as the 6 speed is about 1K more than the 5 speed.
Hear is the Gearbox i got>>
http://links.pictures.aol.com/pic/d610zsDH...cwQm60U0O_l.jpg
This is what it will look like when its time to fit it>>>
http://links.pictures.aol.com/pic/d610zsDH...AKcNDyjxv_l.jpg
But first i have to get the gearbox adaptor plate so i can bolt the gearbox upto the V8 bellhouseing, i should have it in about 3 weeks :)
I all so have to make shifter extension to relocate the shifter back so it comes up through the right hole, or if any one knows where i can get one from that would help hell of a lot :)
well with the engine in place it was time to take a look at the wireing, the ECU,s will be put in the g/box >>
well the wireing is all most done i have about 6 wires to go but its them 6 that are *^&%^$%%^$ ;) peeing me off...so i have stoped with the wireing and i will go back to them 6 wires later on.... :)
With the wireing put to one side for now i moved on to the manifolds! as i will be going down the Turbo road with this setup i had to make 2 new manifolds and they would have to face the front so i can sit the Turbo at the front, so first i had to get my hands on some manifold flang's and i got them of "Thor" Thanks to roger :) then i went and got all the pipe/work to make them, had to make a log/maifold as there is not much room for anything els.>>
This is where the manifolds meet at the front>>
http://links.pictures.aol.com/pic/d610zsDH...4hKEElKZP_l.jpg
http://links.pictures.aol.com/pic/d610zsDH...vA*c7niCZ_l.jpg
as you can see around the engine/bay i have put Heat Reflective mat, still more to put round some of the pipe/work
I will post up about all the fueling later today...
well the time had come that i had to do the fueling side of things, i looked around for the items i needed and the prices of the fuel fitting here in the UK are way over price :) so i started to look on some US site and ask around where the best place to get them....i end up geting all i needed of a US site called JEGS and as they run there own Drag car useing the same fitting.
Hear are just some of the fittings i used>>
http://links.pictures.aol.com/pic/d610zsDH...f3qxzpqdJ_l.jpg
Bosch fuel pump>>
http://links.pictures.aol.com/pic/d610zsDH...RX32s9KuQ_l.jpg
AEROMOTIVE FPR>>
http://links.pictures.aol.com/pic/d610zsDH...4F-zRrUBt_l.jpg
Duel Fuel lines>>
http://links.pictures.aol.com/pic/d610zsDH...-xGm0dBj2_l.jpg
In that pic^^ you can see comeing of the FPR that the return line was not done at the time of take the pic but it has all been done now, i am waiting for some more fuel hose to get hear to do the last bit of the fueling, its the line from the Bosch pump to the Tank :) it should be hear by the end of the week and once thats done that will be all the fueling side done :)
The IS as it is now>>
http://links.pictures.aol.com/pic/d610zsDH...fInu3T8p-_l.jpg
http://links.pictures.aol.com/pic/d610zsDH...gd4wNHaVa_l.jpg
My gearbox waiting to fitted ;)
http://links.pictures.aol.com/pic/d610zsDH...bQ61AzGOn_l.jpg
My old wheels painted the same as the car.>
http://links.pictures.aol.com/pic/d610zsDH...BqIhlqWVt_l.jpg
post some more later......
props to you for doing the work marcus,
have you got dome details on them Jegs fittings,, been looking at getting some in my suup.
Thanks mate, that site i got them fitting from is www.jegs.com but i will say this make sure you get all the bits you need at the same time as shipping is about $80 to $100 but if you get all you need its not so bad then :D
Excellent stuff Marcus, when do you think it will be finished?
Fancy doing another one..lol
Thanks guys.......... :D
I am hopeing to have it on the road by the end of march next year....... :D
as for doing it for someone else, dont know about that mate.... :D then saying that when my car is back on the road, i'm going to get a 2nd 1UZ-FE engine and have a play around with it.... :D
Some impressive pics there Marcus, only some of them are coming up with an error ?
You have sprayed the complete car in black ?? That's going to be stealth or what!!!!!
Good work, keep up the blog and pics :lol:
Thanks mate........ :D pic,s sould be ok now mate :thumbsup_anim:
Nice topic Marcus, I can't wait to see it finished :)
Thanks mate..... :unsure:
I got my intake back from the polishers today ;) and i have to say he has done a top JOB..
http://links.pictures.aol.com/pic/d610zsDH...tktaufEux_l.jpg
http://links.pictures.aol.com/pic/d610zsDH...WpbZJ*C62_l.jpg
