Touchless Alignment Equipment from JB Eurotech
wooooohw, slow down guys.
it looks as though this equipment is simply a straight replacement for the equipment you currently use, the only difference is that you dont need to attach anything to the wheels to assess the alignment, hence the "touchless" part of the title.
you will still need to get under the car and make adjustments to calibrate the chassis and all the other godly wizardry you guys perform, but this tecnology simple removes the need to attach anything to the cars wheels for getting a reading.
it looks to simply 3d scan the area of the wheel, thats what the lights are, when its done that it does all the normal things any kit will do, minus the possability of fitting the units to the wheels incorrectly. I know wim wouldnt do that but other facilities im sure might!!!
