Tony Posted August 4, 2009 Report Share Posted August 4, 2009 The mission is to transform this MX5 chassis Into a fast-road/ track car. This will involve the compliance bushings, brakes, suspension, wheels and finally the calibration. There's nothing nice when it comes to removing the old bushings so those of you with a nervous condition "look away". Here's the kit After snapping two of the three retaining bolts the first wishbone was off The rear anti-roll bar was removed, without snapping the retaining bolts, which is unusual Next step is removing the bushing. The best way to do this is to heat up the inner core then knock this out Once done the remaining rubber is partially burnt away The trick with the new bushing is to remove the metal core first, push the bushing home then press the core into the bushing Next step is to fit the GAZ Gold Pro Race coilovers, 22 way bump/rebound adjustable, 350lb front coils 250lb rear. I decided to use the race Golds because there's no additional cost but they allow the owner to go way, way low if desired. Now to reinstall the wishbone and ARB To be continued.......... Quote Link to comment Share on other sites More sharing options...
Janey Posted August 4, 2009 Report Share Posted August 4, 2009 Nice start of blog will be good to see how everything improves it bet you've lost count of the number of Roadster snapped bolts by now Tony reminds me...must underseal the Vitz Quote Link to comment Share on other sites More sharing options...
tangoman Posted August 4, 2009 Report Share Posted August 4, 2009 That looks a little familiar... the older type Gaz shocks on mine though. Tangoman. Quote Link to comment Share on other sites More sharing options...
Janey Posted August 4, 2009 Report Share Posted August 4, 2009 You'll have to get the new Tangomobile sorted Lance Quote Link to comment Share on other sites More sharing options...
Tony Posted August 4, 2009 Author Report Share Posted August 4, 2009 That looks a little familiar... the older type Gaz shocks on mine though. Tangoman. Things have moved on with GAZ.... If i recall correctly you was going just fine on the "Golds". Quote Link to comment Share on other sites More sharing options...
Janey Posted August 5, 2009 Report Share Posted August 5, 2009 That looks a little familiar... the older type Gaz shocks on mine though. Tangoman. Things have moved on with GAZ.... If i recall correctly you was going just fine on the "Golds". He was until someone crushed his car for him Quote Link to comment Share on other sites More sharing options...
Noel Posted August 5, 2009 Report Share Posted August 5, 2009 How old is the car? that's a nice bit of rust Quote Link to comment Share on other sites More sharing options...
Tony Posted August 5, 2009 Author Report Share Posted August 5, 2009 Today we had two more bushing to replace then it was brake time new fronts and rears, with Green stuff pads The it was time to fit the new wheels and set the trim height Trim is 120mm at the sill and chassis calibrated to wim fast-road Quote Link to comment Share on other sites More sharing options...
Rich Posted August 5, 2009 Report Share Posted August 5, 2009 Nice blog, how many bushes though!! Could do with some of those wishbones on the mondeo What did you think of the greenstuff pads, I'm thinking of getting those? Are they oem discs? Quote Link to comment Share on other sites More sharing options...
Tony Posted August 6, 2009 Author Report Share Posted August 6, 2009 Nice blog, how many bushes though!! Could do with some of those wishbones on the mondeo What did you think of the greenstuff pads, I'm thinking of getting those? Are they oem discs? On the MX5 there's 30 bushings to replace .. Greenstuff are good but only as good as your hydraulics, i'd be inclined to braid the lines first. Quote Link to comment Share on other sites More sharing options...
