littlebrownbike Posted July 1, 2009 Report Share Posted July 1, 2009 These little bastards, too wide to straddle smoothly (in my car), and bloody awful if you drive with 1 or more wheels on them. Whats best for the life of the suspension, and the alignment? Quote Link to comment Share on other sites More sharing options...
Tony Posted July 1, 2009 Report Share Posted July 1, 2009 Hit them at reasonable speed and the steering dead ahead. In truth the deflection will only be suspension compression and lateral deflection at the tyre, as uncomfortable as they are they don't represent a risk to the chassis. Quote Link to comment Share on other sites More sharing options...
hms Posted July 1, 2009 Report Share Posted July 1, 2009 If you're lowered then I'd, just this once, disagree with Tony! If there is only one in the lane, I take it to one side, if there are two, one in each lane then i try to rive down the middle of them. Driving on the sides means the pillow is lower, also means I've less chance of bottoming out on the so and so's. h Quote Link to comment Share on other sites More sharing options...
Tony Posted July 1, 2009 Report Share Posted July 1, 2009 I agree to disagree ... Normal tyres do not have the strength to apply sufficient energy to the chassis, if this were the case wim would have a million members. I do agree if the damper stroke bottoms out then the upward stroke could cause issues with the camber. Quote Link to comment Share on other sites More sharing options...
parthiban Posted July 1, 2009 Report Share Posted July 1, 2009 I tend to do what Tony says, except the ones that looks massive and will end up scraping against the bottom of the car.........those ones just slow to a crawl and take them with one side of the car full on. Quote Link to comment Share on other sites More sharing options...
Rich Posted July 1, 2009 Report Share Posted July 1, 2009 I drive straight over them with no problems. That was until I went down Tony Barbers road, they are nasty high ones! Quote Link to comment Share on other sites More sharing options...
Tony Posted July 1, 2009 Report Share Posted July 1, 2009 I drive straight over them with no problems. That was until I went down Tony Barbers road, they are nasty high ones! Did you notice the flashing red lights ...... Their to warn aircraft at night Quote Link to comment Share on other sites More sharing options...
Rich Posted July 1, 2009 Report Share Posted July 1, 2009 First time up that road I went over the hump quick and the car weren't wide enough to go over, I didn't do that again! Quote Link to comment Share on other sites More sharing options...
