Tony Posted May 30, 2008 Report Share Posted May 30, 2008 The OEM front camber should be -30', this cars position was -45' and the checking range (no wear expected) so say Lexus is up to -60'. This tyre had done less than 3k.... It was probably a nick at 2.5k A new tyre has around 7mm of tread.... This one as you can see still had 6.32mm on it's high edge. So that equates to around £110 (per tyre) for .68mm of wear ......... And Lexus say this wear is normal Quote Link to comment Share on other sites More sharing options...
djwozza Posted May 31, 2008 Report Share Posted May 31, 2008 Scandalous, simply scandalous . Who was the poor fellow ? I bet his car runs straight and true after new tyres and some WIM treatment Quote Link to comment Share on other sites More sharing options...
Bobski Posted May 31, 2008 Report Share Posted May 31, 2008 Cant you just turn the tyres around.....then they can run on the unworn side thus doubling there mileage. PS I am Joking............................although by looks of it it would work! Quote Link to comment Share on other sites More sharing options...
Tony Posted May 31, 2008 Author Report Share Posted May 31, 2008 Cant you just turn the tyres around.....then they can run on the unworn side thus doubling there mileage. PS I am Joking............................although by looks of it it would work! Yes you can do but it was to late for this fellow Quote Link to comment Share on other sites More sharing options...
dazz33 Posted May 31, 2008 Report Share Posted May 31, 2008 Geeez thats not good.. ..Good old IS200 inner tyre wear problem that Lexus GB says doesnt exist.. ..what more proof do they need.. Someone needs some WIM surgery.. Quote Link to comment Share on other sites More sharing options...
Tony Posted June 1, 2008 Author Report Share Posted June 1, 2008 Geeez thats not good.. ..Good old IS200 inner tyre wear problem that Lexus GB says doesnt exist.. ..what more proof do they need.. Someone needs some WIM surgery.. It got it Quote Link to comment Share on other sites More sharing options...
norkep Posted June 1, 2008 Report Share Posted June 1, 2008 Looked like mine at first, even down to the new rubber nipples on the walls of tyres See you in July Tony for some much needed WIM Surgery mate, the rear wiggles like crazy under heavy acc even at 70+ See as the car is going to be used more, it's worth sorting out, been like this for a while but the car only does about 1K per year over the last couple of years BR Paul Quote Link to comment Share on other sites More sharing options...
Rich Posted June 2, 2008 Report Share Posted June 2, 2008 How can Lexus say there is no problem when that photo says it all!! Quote Link to comment Share on other sites More sharing options...
Tony Posted June 2, 2008 Author Report Share Posted June 2, 2008 Looked like mine at first, even down to the new rubber nipples on the walls of tyres See you in July Tony for some much needed WIM Surgery mate, the rear wiggles like crazy under heavy acc even at 70+ See as the car is going to be used more, it's worth sorting out, been like this for a while but the car only does about 1K per year over the last couple of years BR Paul Remember on the knowledge day meet the cars are chosen by lucky dip..... Or did you have another date in mind? Quote Link to comment Share on other sites More sharing options...
