nitrogen inflation
jammy
It is true the molecules are less susceptible to allow air loss due to their size, but the true promise of Nitrogen was reduced influence of heat and the ability to resist expansion...... Sadly this promise is false so i fail to validate the necessity of dry Nitrogen inflation now.
yes nitrogen - we discussed this before on the forum somewhere...
copied from my previous post:
its law that nitrogen or any other inert gas that contains less than 5% oxygen is used in commercial aircraft wheel assys because nitrogen does not support combustion - important when there is a brake fire or overheat ( AKA numpty pilot slammed the brakes on and tried to take first exit when plane is at max landing weight/speed)
but on a serious note the criteria is aircraft with a MTOW ( max take off weight) of over 5700kg with retractable landing gear that have braked wheel assys. The main reason is to reduce inflight fires from a burst tyre.
a quick copy paste from the EASA regulations:
The majority of in-flight tyre bursts have been attributed to the tyre carcass being weakened by foreign object damage, scuffing, etc., such that a rapid release of pressure takes place. Such failures are usually experienced when the gear has been retracted for some time and the effects of brake heat transfer, internal tyre temperature and differential pressure are combined.
A fatal accident involving cabin decompression and fire has highlighted another mode of tyre failure in flight where a tyre may fail explosively without any significant prior degradation. A tyre inflated with air and subjected to excessive heating, possibly caused by a dragging brake, can experience a chemical reaction resulting in release of volatile gases. Such a chemical reaction in the presence of the oxygen in the contained air may result in a tyre explosion in a landing gear bay and/or in-flight fire since it appears that the
protection normally afforded by conventional pressure relief devices in the wheel would be incapable of responding adequately to the rapid increases in temperature and gas pressure associated with auto-ignition.
Other potential benefits may accrue from the use of nitrogen as it will tend to reduce wheel corrosion, tyre fatigue and the risk of fire when fusible plugs melt due to brake overheating.
