SMARTLY Posted December 30, 2014 Report Share Posted December 30, 2014 Saw this recommended on another forum but realise it's two wheel, what do you think Tony ( I'm not thinking of buying one ): http://www.trackace.co.uk/ Quote Link to comment Share on other sites More sharing options...
Tony Posted December 30, 2014 Report Share Posted December 30, 2014 Re-development of an old school system... A few points he was correct about is you have to measure toe in degrees rather than mm if the wheel diameter has changed from OEM. He brushed on the topic of rear toe and recognizes that's an issue. On the negative the positions of the systems fingers at the wheel should be at 3 and 9 o'clock or your adding an error, the reason he hasn't done that is the spoiler is in the way of the beam, oh and the wheels on the M3 in the last image are not OEM. Quote Link to comment Share on other sites More sharing options...
Viking Posted December 30, 2014 Report Share Posted December 30, 2014 A rear wheel add on kit is in the pipeline apparently. Quote Link to comment Share on other sites More sharing options...
Tony Posted December 30, 2014 Report Share Posted December 30, 2014 Then in truth he is belittling the current product as a "make do" alignment system. Quote Link to comment Share on other sites More sharing options...
