Steve-O Posted February 15, 2014 Report Share Posted February 15, 2014 Check this out. Was changing the plugs on the S3 this morning and sods law the very last bolt that holds a bracket that obscures the last 2 plugs was chewed up. Not happy. Cue 3 hours cursing and having to buy some expensive metal bits and easy outs. The little s**t finally budged: I was quite pleased i got it out. Replaced them with hex though. Question is : who knows of any genius bolt removal tools for rounded bolts that is less hassle than easy outs? Or any tricks even? Cheers Steve Quote Link to comment Share on other sites More sharing options...
NickT Posted February 15, 2014 Report Share Posted February 15, 2014 Could you use a stud remover on it? I've found that the one that looks like a drill chuck work ok. Quote Link to comment Share on other sites More sharing options...
adam_r Posted February 15, 2014 Report Share Posted February 15, 2014 Steve.. I normally get a cheap screw driver set ( nice soft metal) and hammer it in to the centre, then twist.... or the other option is to use a Tx tool ( star shape ) they normally work very well Quote Link to comment Share on other sites More sharing options...
Steve-O Posted February 15, 2014 Author Report Share Posted February 15, 2014 In this situation there was no room around the bolt as it was sat in a recess in the head. I tried tapping on a socket but the metal was too hard and I thought about the screwdriver but I just couldn't get enough leverage. It was properly welded tight. When I got it, it snapped loose. A torx socket tapped in might have worked but given the socket didn't make much of an impact I had to admit defeat and do it the hard way to ensure I finished the job. There must be some kind of hardened socket set out there with threads that you can tap on and then use a socket to bite into the metal and release it? Just small versions on locking wheel nut removal sockets perhaps? Quote Link to comment Share on other sites More sharing options...
Tony Posted February 16, 2014 Report Share Posted February 16, 2014 I don't think there's any specialist tools so it's down to ingenuity and knowledge i'm afraid..... In the past we have welded a nut onto the offender but as you say in this case room was an issue. Quote Link to comment Share on other sites More sharing options...
