Steve-O Posted February 26, 2014 Author Report Share Posted February 26, 2014 I was considering shifting using engine speed but since the gearbox/diff is rather expensive on the S3 i thought i would give it a miss. Quote Link to comment Share on other sites More sharing options...
Rich Posted February 26, 2014 Report Share Posted February 26, 2014 That sounds abit scary, I wouldn't of known what to do in that situation! How do you bump start a car with no clutch? Quote Link to comment Share on other sites More sharing options...
Steve-O Posted February 26, 2014 Author Report Share Posted February 26, 2014 That sounds abit scary, I wouldn't of known what to do in that situation! How do you bump start a car with no clutch? took me a few seconds to work it out - engine off - allows you to move it into gear Once into gear started the car and it bumped itself into motion. didnt like doing it as i am sympathetic to my cars but in this situation it had to be done. Quote Link to comment Share on other sites More sharing options...
Rich Posted February 26, 2014 Report Share Posted February 26, 2014 That sounds abit scary, I wouldn't of known what to do in that situation! How do you bump start a car with no clutch? took me a few seconds to work it out - engine off - allows you to move it into gear Once into gear started the car and it bumped itself into motion. didnt like doing it as i am sympathetic to my cars but in this situation it had to be done. Normally you have the car in 2nd and release the cluth/give it some throttle while rolling forwards. So if you turn the engine off and put it into 1st what did you do after that or does the car not stall when you try to start it? Quote Link to comment Share on other sites More sharing options...
Steve-O Posted February 26, 2014 Author Report Share Posted February 26, 2014 Started it in 1st and it lurched forwards and gave it a touch of gas and she just rolled off as normal. Car wont stall if you have the brakes off as there is nothing to stop the engine from turning over Quote Link to comment Share on other sites More sharing options...
Rich Posted February 26, 2014 Report Share Posted February 26, 2014 Started it in 1st and it lurched forwards and gave it a touch of gas and she just rolled off as normal. Car wont stall if you have the brakes off as there is nothing to stop the engine from turning over Yes that makes sense. Whenever I've jumped a car I usually stop afterwards as well so the clutch goes down once the engine has started. Quote Link to comment Share on other sites More sharing options...
Steve-O Posted February 26, 2014 Author Report Share Posted February 26, 2014 yeah thats the way to do it if you have someone pushing you along To be fair when i have had to bump start i have always done it in 1st - sounds like 2nd is the way to go for a less severe bump Quote Link to comment Share on other sites More sharing options...
Tony Posted February 26, 2014 Report Share Posted February 26, 2014 2nd stationary then hit the starter..... It's jumps for a bit then starts and off you go, no push jump required. Quote Link to comment Share on other sites More sharing options...
Steve-O Posted February 26, 2014 Author Report Share Posted February 26, 2014 2nd stationary then hit the starter..... It's jumps for a bit then starts and off you go, no push jump required. Pretty much what i did but in 1st. I will keep it in mind! (hopefully wont be required though) Quote Link to comment Share on other sites More sharing options...
Tony Posted February 26, 2014 Report Share Posted February 26, 2014 It's all about ratio, 2nd works better and you can drive in that gear without changing gear if you know what i mean. Quote Link to comment Share on other sites More sharing options...
Steve-O Posted February 26, 2014 Author Report Share Posted February 26, 2014 as long as you dont need to slow down much i was in heavy traffic so was quite glad to slow right down. Quote Link to comment Share on other sites More sharing options...
Tony Posted February 26, 2014 Report Share Posted February 26, 2014 Fact is you adapted and overcome, that's what really matters Quote Link to comment Share on other sites More sharing options...
Steve-O Posted February 26, 2014 Author Report Share Posted February 26, 2014 Indeedy! Its going to the garage later so tomorrow i will find out how much this little endeavor is going to cost me! Quote Link to comment Share on other sites More sharing options...
Rich Posted February 26, 2014 Report Share Posted February 26, 2014 Shall I move this thread to the blogs section, it's not really been chassis dynamics related? Quote Link to comment Share on other sites More sharing options...
Steve-O Posted February 26, 2014 Author Report Share Posted February 26, 2014 or general - dont really want it as a blog - might encourage me to start modifying it. I do enough of that on the MX5!! Quote Link to comment Share on other sites More sharing options...
Rich Posted February 26, 2014 Report Share Posted February 26, 2014 Ok mate I'll leave. Quote Link to comment Share on other sites More sharing options...
Tony Posted February 27, 2014 Report Share Posted February 27, 2014 Quote Link to comment Share on other sites More sharing options...
