Help with my Geometary Results - Mondeo 2000 - Shows problem with DSF corner
sgking
Hi this week I had 4 wheel alignment done at a Ford garage for £72 quid.
I have fitted all new bolts, new gen ford wishbones, new track rod ends, poly arb bushes, links are 1 year old delphi's.
I also fitted new rear arms and new eccentric / concentric bolts to make rear tracking possible (as old bolts were rust!)
So, I go and get my geo done. Please see the results below.
Please click on the 2 links - I dont know why only 1 pic shows...
Ok so my DSF is still in the red, so this means I have a problem yes?
I am experiencing slight clonking when driving, and slight judder under braking, no wheel bearing noises.
The top mount nut is tight and the spring has not snapped.
Like i said, some parts are new so unlikley to be them.
I was able to tighten the hub nut with my halfords 2ft long breaker bar - it wasnt loose, its just I was able to tighten it slightly.
When jacked up the wheel has play of about 1-2mm when rocked, accompanying it is a rocking noise.
Do you think this is wheel bearing, and if so, could it have prevented the ford garage aligning it sufficiently - its still 'red' on the results sheet?
Thanks all
The printout displayed is completely different to the other one in FB :huh:
Jack the front  up and have someone apply the foot brake, if the play goes then it's the bearing, if it's still there then it's somewhere else.
The OSF camber is a problem. Does the car drift left?
hi thanks for replies!
the strauts and springs are standard st200 (well should be, but i cannot confirm as they have been on the car since before my time).
The reason i noticed is that a month old tyre has been worn down to bare rubber on the inside (twice!) - whilst the outsides are like new!
I will jeck, hold brake and check for play then - this will be tomorrow now. Any other checks i can do, i need this sorted as I cannot afford 55 every month on a tyre! garage probs loves me!
i have a spare st200 hub in storage, so thats good.
would you like me to take pics of anything, if that helps?
thanks very much.
PS Hi rich, long time!
Don't the fords need the sub frame aligned to the body by using long pins first before doing any geometry?
Yes they do but this can't be the case here because if the sub-frame was moved the NSF camber will go out of tolerance.
hi yes it has had a bump, but on the rear, as it has a new drivers side rear wing fitted. Also, I have not had a geo problem with this car in my 5.5 years of ownership, its only now since ive started fitting new parts. i should have left it as it was!haha
The fact the NSF camber is very deep as well suggests the front coils have sagged. Nevertheless the OSF camber is still to deep coil sag or not. As said it should be due to a bent hub? Did they give any more geometry numbers. The data i'm looking for is the SAI/ KPI, the is the inclination/ declination of the lower ball joint. The reason i ask is the data will tell me if the bend is in the sprung or unsprung chassis.
I imagine the front coils could have sagged as they are probably originals.
I have got the wheel off right now and am investigating everything and double checking all bolts are tight. all i have found is the rear subframe bolt needs further tightening - not loose, just that it turns whilst i am trying to torque it to 130. (standard captive nut has been removed and simple bolt used instead.)
that gets me thinking, when i fitted my arb polybushes, i had to hammer a wedge of wood between the subframe and chassis to get clearance on the arb clamp bolts - could this have messed something up? I did it on the other side too though, but the other side geo is ok?
hi re the data you are looking for, sorry that is all the info they gave, and i had to ask for it too!
when i asked for the reports, the main receptionist said to the kid, "photocopies, ok", maybe so that the red warning wouldnt have shown up? but i watched him like a hawk and said ye thats it, ill have that, so he had no choice but to give it to me.
the invoice says:
"completed healthcheck, brake vibration noted, carried out full 4 wheel alignment and adjusted to spec. initial inspection found both f & r toeing out beyond scope of measurement. Turned track rod ends to return back into scope an both front and rear wheels. returned vehicle to machine and completed alignment."
should they have the sai/kpi info on the system, i can ask them to email it to me if so?
ok well all nuts bolts are torqued correctly, nothing looked out of place, bent, loose - all nice and tight.
The disc wasnt sitting perfectly on the hub, so i took the disc and caliper off to check the hub bearing for play but i could not find any. I looked at the back of the brake disc, at the mating surface to the hub, and it had big flakes of rust forming and flaking which i think could very well be the reason for brake judder, and the clunking noises ive been hearing as the disc was not mated to the hub perfectly.
yet to take it for a spin but seems much tighter. would i be right in assuming this would prevent accurate tracking to be done? those flakes of rust were 2mm at worst, and one could have been trapped.
No it wouldn't effect the readings because the Hunter machine does something called ROC ( Run-Out-compensation ) that eliminates things like clamping errors or buckled wheels.
The wooden blocks has nothing to do with the results so don't worry about that. What you need to do is ask for the technicians geometry report which will have the SAI/ KPI ( Reason i say both is terminology differs between machines but SAI/ KPI are the same angle )
If you remove the OSF wheel you need to look for witness marks on the cast hub at the point it bend to meet the strut. If there has been a bend then some of the rust at that point may have fallen off. In addition look at the strut at the point it engages into the hub for a kink/ ripple, this will also suggest a bend.
Oh right i see.
ok so i will ask for the geometary report, is that not what i have posted in post No1? that has a box for SAI but they have not put the results in? Will they still have the SAI results on their systems do you think?Or will I get an excuse over the phone do you think?
Ok i will check the hub and strut asap - one eve this week. i actually was loking at it yesterday and i couldnt see any cracks or stress areas. I will look again though.
took her for a spin today and it drives great, straight, tight, no clunks now - only if i blip throttle when going slow i get some little clunks - they feel more engine/transmission though. - i have solid PU transmission roll restrictors fitted too.
its annoying me now haha
I'm sure Jammy had a similar problem on one of his Mondeos and that was a warped knuckle but it's obviously something you can't see by eye. I would get onto the garage to get the full report, it's what you've paid for so they should provide all of the readings.
ok weell the garage rung back. Mechanic confirms all reading taken have been supplied.
said he had hell of a job doing my car because all my new parts had knocked it out 8mm on the rear and 20mm on the front, and he had to keep re-adjusting before he could get it on the hunter.
He does not know why the drivers front is out of alignment.
So, not much help sadly.
  • 3 months later...
Hi sorry for big delay. I did check the hub and strut for any signs of bending etc and couodnt find any. I used a ruler to check for straighness.
Anyway the plot thickens, my wheel bearing (surprise, surprise) died on that corner straight away and so I have fitted a new hub just this weekend and its alot nicer! I hope it was simply the wheel bearing that will have thrown out the camber as some people have told me that.
Anyway, so now my question is - will I have knocked out the geo further again by replacing the hub? I removed shock/hub and separated on bench and reinstalled?
and can a geo shop do just the one corner for say £20??i dont fancy paying £70 to have it all done when no need.
Thanks
