andyelcomb Posted August 28, 2013 Report Share Posted August 28, 2013 I know it doesn't matter to some, but what is the correct word spelling - castor or caster? Quote Link to comment Share on other sites More sharing options...
parthiban Posted August 28, 2013 Report Share Posted August 28, 2013 I've always thought castor was technically correct in the UK, but both are acceptable spellings? Quote Link to comment Share on other sites More sharing options...
Sagitar Posted August 28, 2013 Report Share Posted August 28, 2013 Context is all. I guess the question was meant in the context of car geometry and in that context castor and caster are each acceptable according to my trusty Chambers dictionary. Personally I prefer castor in this use, but it's just a habit, in order to differentiate between the little swivelling wheel and the stuff in the caster sugar packet. Interestingly, though retailers always seem to spell it as caster sugar, Chambers says that castor would be correct there also and for the perforated container used for sprinkling the sugar. The only other uses that I know - Castor and Pollux; castor oil and the uses connected with the Beaver - are all spelled "castor". Quote Link to comment Share on other sites More sharing options...
andyelcomb Posted August 28, 2013 Author Report Share Posted August 28, 2013 Thanks Sagitar, that's pretty much what I discovered. Must be one of the very few alternative spellings that is actually ok to use either, but did wonder if our sage had a more specific answer. And yes, the question location does confirm the context. Quote Link to comment Share on other sites More sharing options...
parthiban Posted August 29, 2013 Report Share Posted August 29, 2013 Context is all. I guess the question was meant in the context of car geometry and in that context castor and caster are each acceptable according to my trusty Chambers dictionary. Personally I prefer castor in this use, but it's just a habit, in order to differentiate between the little swivelling wheel and the stuff in the caster sugar packet. Interestingly, though retailers always seem to spell it as caster sugar, Chambers says that castor would be correct there also and for the perforated container used for sprinkling the sugar. The only other uses that I know - Castor and Pollux; castor oil and the uses connected with the Beaver - are all spelled "castor". Once again, my understanding is that castor was originally the correct spelling in all cases (including the sugar), caster is an american (?) spelling that has been adopted over time. Both are acceptable in any case. For some reason I also personally think of caster as the spelling in most cases, and only use castor with reference to castor oil. Quote Link to comment Share on other sites More sharing options...
Tony Posted August 29, 2013 Report Share Posted August 29, 2013 Castor is my vision geometrically but Caster albeit a witness to my realm is American terminology in my opinion. Quote Link to comment Share on other sites More sharing options...
andyelcomb Posted August 29, 2013 Author Report Share Posted August 29, 2013 As a fully paid member of the Old Gits then castor it is! Thanks all. Quote Link to comment Share on other sites More sharing options...
Tony Posted August 30, 2013 Report Share Posted August 30, 2013 Sorted Quote Link to comment Share on other sites More sharing options...
