Lexus IS200 tyre wear......
The OEM front camber should be -30', this cars position was -45' and the checking range (no wear expected) so say Lexus is up to -60'.
This tyre had done less than 3k.... It was probably a nick at 2.5k
A new tyre has around 7mm of tread.... This one as you can see still had 6.32mm on it's high edge.
So that equates to around £110 (per tyre) for .68mm of wear :D ......... And Lexus say this wear is normal :lol:
Cant you just turn the tyres around.....then they can run on the unworn side thus doubling there mileage. :lol:
PS I am Joking............................although by looks of it it would work!
Yes you can do but it was to late for this fellow :D
Geeez thats not good.. :D ..Good old IS200 inner tyre wear problem that Lexus GB says doesnt exist.. :) ..what more proof do they need.. :) Someone needs some WIM surgery.. :D
Looked like mine at first, even down to the new rubber nipples on the walls of tyres
See you in July Tony for some much needed WIM Surgery mate, the rear wiggles like crazy under heavy acc even at 70+
See as the car is going to be used more, it's worth sorting out, been like this for a while but the car only does about 1K per year over the last couple of years
BR
Paul
BR
Paul
Remember on the knowledge day meet the cars are chosen by lucky dip..... Or did you have another date in mind?
