bearman Posted March 29, 2012 Report Share Posted March 29, 2012 Hi, about 6 weeks ago i went along to my local STS Tyre Pros to have 4 wheel alignment done as the outer edge off my front passenger side tyre was getting fairly worn. Had a check around the car yesterday and now both the front tyres inner edges have worn smooth Pretty peeved as i got the alignment done to save any further wear! The central area of the tyre is around 3.5mm. Could STS of messed up the alignment? Thanks Quote Link to comment Share on other sites More sharing options...
Rich Posted March 29, 2012 Report Share Posted March 29, 2012 Was it a geometry or just 4 wheel alignment? Did you get a printout? As you're in Herts might be worth popping over to WIM to get it checked. Quote Link to comment Share on other sites More sharing options...
bearman Posted March 29, 2012 Author Report Share Posted March 29, 2012 Was it a geometry or just 4 wheel alignment? Did you get a printout? As you're in Herts might be worth popping over to WIM to get it checked. Asked for 4 wheel alignment, didnt give me a printout, just a receipt stating 'Geometry - Front and Rear Toe in/Out' Went there as thought WIM had something to do with STS and their equipment is supposed to be decent Quote Link to comment Share on other sites More sharing options...
Rich Posted March 29, 2012 Report Share Posted March 29, 2012 Did you buy it through the WIM website? Any place listed on the website would've given you a printout and Tony would've contacted them beforehand about what to do. Is the car lowered? Where in Herts are you? Quote Link to comment Share on other sites More sharing options...
bearman Posted March 29, 2012 Author Report Share Posted March 29, 2012 Didnt buy directly through the WIM website but went there after seeing it as an option on the website. Definately no printout given just a reciept. Car is standard suspension wise, i'm in Hertford Quote Link to comment Share on other sites More sharing options...
Rich Posted March 29, 2012 Report Share Posted March 29, 2012 Without a printout there's no way of knowing the problem and as you didn't buy via the website you don't have the WIM guarantee. You're only half hour from WIM, I'd get it checked there. Quote Link to comment Share on other sites More sharing options...
Tony Posted March 30, 2012 Report Share Posted March 30, 2012 Doesn't read like a geometry without a printout. How much of the tyre width is involved with the inner tyre wear? Quote Link to comment Share on other sites More sharing options...
Rich Posted March 30, 2012 Report Share Posted March 30, 2012 I'm assuming he used the STS on the Windsor Industrial Estate in Hertford, so they must have the right equipment to do a geometry? Quote Link to comment Share on other sites More sharing options...
Tony Posted March 30, 2012 Report Share Posted March 30, 2012 No printout, no comment. Quote Link to comment Share on other sites More sharing options...
bearman Posted March 30, 2012 Author Report Share Posted March 30, 2012 Doesn't read like a geometry without a printout. How much of the tyre width is involved with the inner tyre wear? Around an inch and a half is smoothed off I've done around 1500 miles since it was adjusted Quote Link to comment Share on other sites More sharing options...
Tony Posted March 30, 2012 Report Share Posted March 30, 2012 If the rest of the tyre is fine then the reason for the wear is camber...... They really need to measure the car again and give you a printout. Quote Link to comment Share on other sites More sharing options...
bearman Posted March 30, 2012 Author Report Share Posted March 30, 2012 I'll try and pop down there tonight/saturday and get them to give me a printout with the reading this time Quote Link to comment Share on other sites More sharing options...
Tony Posted March 30, 2012 Report Share Posted March 30, 2012 Keep us updated Quote Link to comment Share on other sites More sharing options...
bearman Posted March 31, 2012 Author Report Share Posted March 31, 2012 Popped back in today but after checking the tyres they said there is no point in checking the geo with the insides worn that bad. Think they kinda missed my point that they wern't worn at all on the insides until the geo was last adjusted there. Going to pick up a couple of new tyres from Camskill and decide where to take my car for fitting/geo Quote Link to comment Share on other sites More sharing options...
Tony Posted March 31, 2012 Report Share Posted March 31, 2012 Idiots..... Tyre wear doe's not effect the geo readings Quote Link to comment Share on other sites More sharing options...
Rich Posted March 31, 2012 Report Share Posted March 31, 2012 If they're idiots Tony why do you use them?! Quote Link to comment Share on other sites More sharing options...
bearman Posted March 31, 2012 Author Report Share Posted March 31, 2012 Idiots..... Tyre wear doe's not effect the geo readings I didnt think it mattered, is there an advantage to having the geo setup with new tyres or something? Quote Link to comment Share on other sites More sharing options...
Tony Posted March 31, 2012 Report Share Posted March 31, 2012 No the tyre condition makes no difference, in fact i don't even need the wheels on the car Quote Link to comment Share on other sites More sharing options...
bearman Posted April 2, 2012 Author Report Share Posted April 2, 2012 If they're idiots Tony why do you use them?! Would certainly put me off spending £120 at a garage other than probably WIM main HQ where you would actually get the value of someone like Tony working on the car What extra service would you get at a WIM franchise if you booked through the site compared to just going to that location and paying £30-£60 that they charge to regular walk in customers? Quote Link to comment Share on other sites More sharing options...
Tony Posted April 2, 2012 Report Share Posted April 2, 2012 You get our data/ support and we police the work after.... Problem we can get is the approved tech leaves and the company don't inform us. Quote Link to comment Share on other sites More sharing options...
bearman Posted April 4, 2012 Author Report Share Posted April 4, 2012 Took it back in today for a check, all the wheel numbers were green and in tolerance apart from the rear left was out by 0.02 degrees, would this make that much of a difference overall to the front tyres? Couldn't get a print out as their printer is out of ink or something Quote Link to comment Share on other sites More sharing options...
Tony Posted April 4, 2012 Report Share Posted April 4, 2012 Did you see the numbers on the screen. Quote Link to comment Share on other sites More sharing options...
bearman Posted April 4, 2012 Author Report Share Posted April 4, 2012 yup Quote Link to comment Share on other sites More sharing options...
