Tony Posted February 22, 2011 Report Share Posted February 22, 2011 We see a lot of these pocket rockets due to the fact the OEM dampers work very poorly with the OEM coils. After a damper install the chassis is measured and calibrated but we have noticed a problem. On most cars measured we have found the rear "I" beam misaligned, this means the thrust angle and in some cases the camber angles are outside of the suggest settings. Officially the rear toe/ camber and ultimately thrust is not adjustable..... But it is at wim Before After Note the change in OSF camber as well, this is showing how the sprung chassis moves during a camber change even if this is at the rear..... Credit for this research goes to CIH aka Pete/ Pedro Quote Link to comment Share on other sites More sharing options...
Rich Posted February 23, 2011 Report Share Posted February 23, 2011 Pete showed me this last week when he was working on one, good stuff Quote Link to comment Share on other sites More sharing options...
hms Posted February 23, 2011 Report Share Posted February 23, 2011 Another WIM win! There was an article in I think Track Driver mag about the suspension and replacing it with GAZ on the Arbarth 500. Derek got a mention as the suspension technician! h Quote Link to comment Share on other sites More sharing options...
Rich Posted February 23, 2011 Report Share Posted February 23, 2011 Gaz is always getting mentioned in that mag, I think WIM needs an article in there as well Quote Link to comment Share on other sites More sharing options...
Tony Posted February 23, 2011 Author Report Share Posted February 23, 2011 Gaz is always getting mentioned in that mag, I think WIM needs an article in there as well Patience young Luke, patience Quote Link to comment Share on other sites More sharing options...
Rich Posted February 23, 2011 Report Share Posted February 23, 2011 Got something lined up then? Quote Link to comment Share on other sites More sharing options...
Tony Posted February 23, 2011 Author Report Share Posted February 23, 2011 Got something lined up then? Always Quote Link to comment Share on other sites More sharing options...
CIH Posted February 23, 2011 Report Share Posted February 23, 2011 My problem is I'm just too damn good. And I'm too modest. Quote Link to comment Share on other sites More sharing options...
