liner33 Posted September 28, 2010 Report Share Posted September 28, 2010 MOT picked up wear in the rear trailing arms , either the ball joint or the bush or both In line with most of the stuff i do on the Evo I will change both with new and replace all the bolts as well , but since i only had the alignment set recently is there anyway i can do it without throwing the settings out too much ?? Quote Link to comment Share on other sites More sharing options...
Tony Posted September 28, 2010 Report Share Posted September 28, 2010 In a word "no"...... Did we do the geometry and if yes how long ago. Quote Link to comment Share on other sites More sharing options...
liner33 Posted September 28, 2010 Author Report Share Posted September 28, 2010 Yes 28/7/10 @ 50778 miles Mot has just been done at 51292 miles so not that many miles since alignment I can get the arms at a reasonable price at the moment normally £140ish plus the bushes each side but a trader i know is doing them with new bushes for £110 so i will buy them now but probably fit them after xmas . Its only an advisory though wasnt a fail but i am very fussy Quote Link to comment Share on other sites More sharing options...
Tony Posted September 28, 2010 Report Share Posted September 28, 2010 I'll look after you on the re-geo Quote Link to comment Share on other sites More sharing options...
liner33 Posted September 28, 2010 Author Report Share Posted September 28, 2010 Top man It will just effect the rear toe wont it ?? I shouldnt have to remove the lower arms Quote Link to comment Share on other sites More sharing options...
Tony Posted September 28, 2010 Report Share Posted September 28, 2010 Top man It will just effect the rear toe wont it ?? I shouldnt have to remove the lower arms It should just be the rear but i'll whatever needs to be done. Quote Link to comment Share on other sites More sharing options...
