imobiliser problem? car keeps cutting out - accord vtec 2000
Hi all
I have a problem with my car my car keeps cutting out when driving, the only way it starts up again is when take key out of ignition get out car then lock it then unlock it then key in ignition then it will start again. My car is a honda accoer 2.0i vtec exec w reg.
any ideas?
cheers
If it's a stock alarm/immobiliser then it will be built into the ECU, you'll notice a green picture of a key flashing when you take the key out after stopping the engine. If it's this type as mentioned above the easiest way is to plug an OBD2 reader into the car, if there is a fault it should be displayed.
It may have a separate system (normally on the older stuff but I wouldn't be surprised to see otherwise) that is linked in a different way. Certainly on those ones water can find it's way into the siren and screw things up.
Jon
