Tony Posted August 6, 2008 Report Share Posted August 6, 2008 This owner had gone from pillar to post trying to solve a vibration problem. The graph below shows the tyres rotating profile through 360 degrees in red and the same for the wheel in yellow. As you can clearly see the wheels profile has vertical variants... Effectively the wheels bent! in fact you could have seen this by eye if anyone had bothered to look....> As you can see the peaks are + 1.4mm and -2.1mm. The limit is +- .5mm for all domestic wheels. Quote Link to comment Share on other sites More sharing options...
Rich Posted August 6, 2008 Report Share Posted August 6, 2008 No photos of the wheel then? Can it be straightened or is a new one needed? Quote Link to comment Share on other sites More sharing options...
Tony Posted August 6, 2008 Author Report Share Posted August 6, 2008 No photos of the wheel then? Can it be straightened or is a new one needed? Photo not required..... Point of the graph is to display evidence to the owner the wheel is..... Dead! Quote Link to comment Share on other sites More sharing options...
