sbd16v Posted May 2, 2008 Report Share Posted May 2, 2008 regarding the set-up on a astra gte what will work for the track rear camber and front camber and caster settings ??? i dont know to much about suspension so im trying to get an idea for a good base set-up to start with Quote Link to comment Share on other sites More sharing options...
Janey Posted May 2, 2008 Report Share Posted May 2, 2008 I can't answer your q....but just thought I say Hi & Welcome to WIM Quote Link to comment Share on other sites More sharing options...
Tony Posted May 2, 2008 Report Share Posted May 2, 2008 Hello... The GTE has a relatively fixed chassis... Have you fitted any aftermarket adjusters? Quote Link to comment Share on other sites More sharing options...
sbd16v Posted May 4, 2008 Author Report Share Posted May 4, 2008 Hello...The GTE has a relatively fixed chassis... Have you fitted any aftermarket adjusters? yep, gaz gold coilovers front and rear, and eccentric top mounts on the front. im interested in shimming the rear hubs to make the rear camber right but i dont know what to start with when it comes to values gaz made the coilovers with 2.5 degs of camber as they said thats alot closer to the correct terack set up i want it corner weighted and all the camber caster ETC set up Quote Link to comment Share on other sites More sharing options...
Tony Posted May 4, 2008 Report Share Posted May 4, 2008 Hello...The GTE has a relatively fixed chassis... Have you fitted any aftermarket adjusters? yep, gaz gold coilovers front and rear, and eccentric top mounts on the front. im interested in shimming the rear hubs to make the rear camber right but i dont know what to start with when it comes to values gaz made the coilovers with 2.5 degs of camber as they said thats alot closer to the correct terack set up i want it corner weighted and all the camber caster ETC set up Interesting project.... What's your destination with this? road/track/drift and so on. Quote Link to comment Share on other sites More sharing options...
sbd16v Posted May 4, 2008 Author Report Share Posted May 4, 2008 Hello...The GTE has a relatively fixed chassis... Have you fitted any aftermarket adjusters? yep, gaz gold coilovers front and rear, and eccentric top mounts on the front. im interested in shimming the rear hubs to make the rear camber right but i dont know what to start with when it comes to values gaz made the coilovers with 2.5 degs of camber as they said thats alot closer to the correct terack set up i want it corner weighted and all the camber caster ETC set up Interesting project.... What's your destination with this? road/track/drift and so on. track day car, with the ocational trip out onto the road to upset the local chavs Quote Link to comment Share on other sites More sharing options...
Rich Posted May 4, 2008 Report Share Posted May 4, 2008 Sounds like a plan mate...welcome to WIM Quote Link to comment Share on other sites More sharing options...
Tony Posted May 5, 2008 Report Share Posted May 5, 2008 Ok track is the main body of work... Our main problem is going to be the rear... As i'm sure your aware the hub will need to be shimmed with a "shim disc". Historically the GTE offers little camber gains at the rear when lowered so i order to belay over-steer the shims need to be quite aggressive. The final calibration is dependant on the final position of the rear camber/toe. Quote Link to comment Share on other sites More sharing options...
