jammy Posted January 25, 2008 Report Share Posted January 25, 2008 what can i say tony drive's spot on now,nice and sturdee and very dirict and positive on steer in and out of bend's... thank's alot tony investigated that leak.seem's to be coming from the shock.so look's like i wlill have to change it. will this b upset the set up or as it is just a straight shock change,should it be ok ??? Quote Link to comment Share on other sites More sharing options...
Tony Posted January 25, 2008 Report Share Posted January 25, 2008 what can i say tony drive's spot on now,nice and sturdee and very dirict and positive on steer in and out of bend's... thank's alot tony investigated that leak.seem's to be coming from the shock.so look's like i wlill have to change it. will this b upset the set up or as it is just a straight shock change,should it be ok ??? Blimey the shock ... You really need to change those rear coils mate!!.... If you decide to replace the hub as well then i will need to re-set the chassis Quote Link to comment Share on other sites More sharing options...
jammy Posted January 25, 2008 Author Report Share Posted January 25, 2008 what can i say tony drive's spot on now,nice and sturdee and very dirict and positive on steer in and out of bend's... thank's alot tony investigated that leak.seem's to be coming from the shock.so look's like i wlill have to change it. will this b upset the set up or as it is just a straight shock change,should it be ok ??? Blimey the shock ... You really need to change those rear coils mate!!.... If you decide to replace the hub as well then i will need to re-set the chassis think it is more down to the rust around the bottom egde inside where the coil sit's thay were in my shed for a few month's and it did leak abit.the shock i took off was ok so i assume it is just down to that will prob leave the hub for now.then when thing's pick up ill get some new 1's Quote Link to comment Share on other sites More sharing options...
Tony Posted January 25, 2008 Report Share Posted January 25, 2008 what can i say tony drive's spot on now,nice and sturdee and very dirict and positive on steer in and out of bend's... thank's alot tony investigated that leak.seem's to be coming from the shock.so look's like i wlill have to change it. will this b upset the set up or as it is just a straight shock change,should it be ok ??? Blimey the shock ... You really need to change those rear coils mate!!.... If you decide to replace the hub as well then i will need to re-set the chassis think it is more down to the rust around the bottom egde inside where the coil sit's thay were in my shed for a few month's and it did leak abit.the shock i took off was ok so i assume it is just down to that will prob leave the hub for now.then when thing's pick up ill get some new 1's Ok mate.... Changing the shock won't effect the work done today Quote Link to comment Share on other sites More sharing options...
jammy Posted January 25, 2008 Author Report Share Posted January 25, 2008 that's what i like to here thank's again tony you have done wonder's today Quote Link to comment Share on other sites More sharing options...
