Bazza Posted November 30, 2007 Report Share Posted November 30, 2007 when the battery in the starlet is moved into the rear of the vehicle should the cable be fused at the battery end ? if so what size fuse would be appropriate ? Quote Link to comment Share on other sites More sharing options...
Mat Posted November 30, 2007 Report Share Posted November 30, 2007 when the battery in the starlet is moved into the rear of the vehicle should the cable be fused at the battery end ? if so what size fuse would be appropriate ? it doesnt have to be fused, if you use proper car battery cable and use a grommet in the bulkhead....(however...could say safety, it would be better to use a trip breaker ) as for fuse size, 120 amp Quote Link to comment Share on other sites More sharing options...
Bazza Posted November 30, 2007 Author Report Share Posted November 30, 2007 when the battery in the starlet is moved into the rear of the vehicle should the cable be fused at the battery end ? if so what size fuse would be appropriate ? it doesnt have to be fused, if you use proper car battery cable and use a grommet in the bulkhead....(however...could say safety, it would be better to use a trip breaker ) as for fuse size, 120 amp i am all out of wet string so will be using proper cable cheers matty Quote Link to comment Share on other sites More sharing options...
Bazza Posted November 30, 2007 Author Report Share Posted November 30, 2007 2nd question on emergency stop switches why do fia approved ones need to have a resistor ? and what does it do ? read something about protecting the alternator, but still not sure how or why Quote Link to comment Share on other sites More sharing options...
Mat Posted November 30, 2007 Report Share Posted November 30, 2007 2nd question on emergency stop switches why do fia approved ones need to have a resistor ? and what does it do ? read something about protecting the alternator, but still not sure how or why basically, if you dont have the resistor, when you cut the power...the engine could still run,..as the alternator is still turning, hence generating current...the resistor prevents damage to the alternator the isolator i have fitted to the Monster is the Armtech Hybrid Battery Isolator Model No. 70BC06. Quote Link to comment Share on other sites More sharing options...
Ellz Posted November 30, 2007 Report Share Posted November 30, 2007 2nd question on emergency stop switches why do fia approved ones need to have a resistor ? and what does it do ? read something about protecting the alternator, but still not sure how or why Does this mean the starlet is going to be only for the track now ??? Quote Link to comment Share on other sites More sharing options...
Bazza Posted November 30, 2007 Author Report Share Posted November 30, 2007 2nd question on emergency stop switches why do fia approved ones need to have a resistor ? and what does it do ? read something about protecting the alternator, but still not sure how or why Does this mean the starlet is going to be only for the track now ??? yep will be competing in the toyota sprint series next year, so will be having to be mot`d Quote Link to comment Share on other sites More sharing options...
Mat Posted December 1, 2007 Report Share Posted December 1, 2007 There is supposedly a separate MOT for limited road use vehicles involved in Motorsport........... (rally cars, sprint cars etc etc) but id be dammed if i can find any definitive answers Quote Link to comment Share on other sites More sharing options...
scorps Posted December 1, 2007 Report Share Posted December 1, 2007 Why not pop down to your local MOT centre and ask? Quote Link to comment Share on other sites More sharing options...
Mat Posted December 1, 2007 Report Share Posted December 1, 2007 Why not pop down to your local MOT centre and ask? ...........most MOT stations dont know Quote Link to comment Share on other sites More sharing options...
