jammy Posted September 9, 2020 Report Share Posted September 9, 2020 +As I'd fitted new lower arms up front I went and got the Geo done and it reminded me I have an issue to address at the rear of the car.. Surprisingly the all but the toe was spot on still.( all still green and the toe had gone from 0.00 to +0.02!both sides) Anyway the rear tow is the issue... Rear camber L = 1.18 R =1.18 Rear toe L = +0.16 R = +0.06 Would this suggest a bent stub axle? Quote Link to comment Share on other sites More sharing options...
jammy Posted September 9, 2020 Author Report Share Posted September 9, 2020 Unable to edit but the rear camber is - 1.18 both sides. The - seams to of vanished Quote Link to comment Share on other sites More sharing options...
Tony Posted September 10, 2020 Report Share Posted September 10, 2020 The rear toe isn't a problem. If the car has been lowered then yes the camber will move negative but the coil rate is much higher meaning the lowering should be pain free. Quote Link to comment Share on other sites More sharing options...
jammy Posted September 10, 2020 Author Report Share Posted September 10, 2020 I notice it on left turns though and as I want to sell up its something I want to try and sort out before hand.. Would you say it was the n/s rear toe that was the one that's out given the numbers quite high? Quote Link to comment Share on other sites More sharing options...
jammy Posted September 10, 2020 Author Report Share Posted September 10, 2020 https://www.courtenaysport.co.uk/Camber-Toe-Shim-Rear-575400 This have caught my interest, what do you think mate? Quote Link to comment Share on other sites More sharing options...
jammy Posted September 10, 2020 Author Report Share Posted September 10, 2020 This is was the last time I had the astra aligned which was near year and had my old wheels on.. Quote Link to comment Share on other sites More sharing options...
jammy Posted September 10, 2020 Author Report Share Posted September 10, 2020 This was the Geo I had done last week.. Difference now is new lower arms and different wheels and tires (wheels are same type and size as before though) Things was definitely worn/bent in the first pic.. Below is the current settings Quote Link to comment Share on other sites More sharing options...
jammy Posted September 10, 2020 Author Report Share Posted September 10, 2020 Amazing the toe stayed the same on one side and moved 0.02 yet it had been apart for lower ams and the wheels and tyres. And pretty much everything else changed conciderably Quote Link to comment Share on other sites More sharing options...
jammy Posted September 11, 2020 Author Report Share Posted September 11, 2020 I've been trying to locate the manufacturer settings for the rears but not having much luck atm TONY are you able to tell me please? Untill I k ow that I'm actually unsure what side is out Quote Link to comment Share on other sites More sharing options...
Tony Posted September 12, 2020 Report Share Posted September 12, 2020 + 5' min per side will work just fine.... It's very odd he can't find the OEM settings? Remember +5' per side is not the same as +5mm per side. Quote Link to comment Share on other sites More sharing options...
jammy Posted September 12, 2020 Author Report Share Posted September 12, 2020 Well something definitely isn't right tonight as it's gone a bit sloppy on the bend and not plesent to drive. Got some noises up front again which sounds just like it did when the ball pint and front Bush on both lower arms gave up last month... I think the konis might be coming to the end of their lifw as are the H+R springs Quote Link to comment Share on other sites More sharing options...
Tony Posted September 13, 2020 Report Share Posted September 13, 2020 I think you need to jack it up and do a proper inspection. Quote Link to comment Share on other sites More sharing options...
jammy Posted September 13, 2020 Author Report Share Posted September 13, 2020 I fif that today mate.. Got nothing loose worn o. The that the eys can touch or my hands can see. Upfront seems to be OK on a visual along with some wheel shaking trying to find any play but all seems to be where I left it last two ime it was Apart :ponder: Looks like it's suspension time then!!! The springs arnt as firm as they should be now, plus the drivers side is sat lower by 5mm too.. Didn't want to be buying new shocks ro but I may not have a. Choice.. Its starting to crash through all the bad bits on the roads now as well Quote Link to comment Share on other sites More sharing options...
Tony Posted September 14, 2020 Report Share Posted September 14, 2020 If the shocks foot valve is damaged then it could allow vibration and noise. Quote Link to comment Share on other sites More sharing options...
jammy Posted September 14, 2020 Author Report Share Posted September 14, 2020 Think I'll pull it apart as I do t have any spare cash for suspension now anyway Quote Link to comment Share on other sites More sharing options...
Tony Posted September 15, 2020 Report Share Posted September 15, 2020 Can you not remove the coilover and test the shaft? Quote Link to comment Share on other sites More sharing options...
jammy Posted September 16, 2020 Author Report Share Posted September 16, 2020 I'll have to once I'm back in work and can replace what ever is broke.. Till then ill have to surfer it as my work car is down due to a dead duel mass flywheel Quote Link to comment Share on other sites More sharing options...
jammy Posted September 19, 2020 Author Report Share Posted September 19, 2020 OK then so yesterday I removed the recently replaced lower arms and took them back for a swap over for a new pair. Certainly drives way better than it was... Managed to do a warranty swap of the arms there and then as my supplier rang febi direct and Feb I was happy to replace them free of charge No visible signs of defect of than the bushes seem to be softer then on the replacement arms.. Quote Link to comment Share on other sites More sharing options...
Tony Posted September 19, 2020 Report Share Posted September 19, 2020 If the alignment was done on the old arms then you need to doe it again. Reason is the front toe is a "compliance" angle meaning the static toe position assumes how much rolling resistance will move when the car is in motion. Quote Link to comment Share on other sites More sharing options...
jammy Posted September 19, 2020 Author Report Share Posted September 19, 2020 Yes mate it's booked in for next week Quote Link to comment Share on other sites More sharing options...
Tony Posted September 20, 2020 Report Share Posted September 20, 2020 Well done. Quote Link to comment Share on other sites More sharing options...
