paule3d Posted March 30, 2015 Report Share Posted March 30, 2015 Hi. Im going to fit 40mm lowered springs on a Mondeo Mk2 (ST24) estate as I'm fed up of the gaping great gap above the wheels! I just realised this will give it positive castor angle at the front. Any idea if this would affect things? I will get a geometry done at some point as I'd like to lower the back and replace all the bushes etc. (Though i heard on the Mondeo there is not a lot of things that can be adjusted such as camber.) So does anyone know if there is anything I need to consider if lowering it? Many thanks. Quote Link to comment Share on other sites More sharing options...
Tony Posted March 31, 2015 Report Share Posted March 31, 2015 Lowering is a wise move on the Mondeo Est..... What makes you think the camber will end up positive? Quote Link to comment Share on other sites More sharing options...
Rich Posted March 31, 2015 Report Share Posted March 31, 2015 With a 40mm drop you will more than likely get a little camber wear on the front, I did with a 30mm drop, the rear should be unaffected though. I would advise you keep away from the camber/caster adjusters they are not very good - been there done that! All you can adjust is the front and rear toe. Quote Link to comment Share on other sites More sharing options...
paule3d Posted March 31, 2015 Author Report Share Posted March 31, 2015 I figured the more pointing downwards the front is, the more leaning forward would be the strut, but on seconds thoughts, I guess it might not it it's all held in place. Thanks Quote Link to comment Share on other sites More sharing options...
Rich Posted March 31, 2015 Report Share Posted March 31, 2015 It will be fine, the handling should be better once lowered, the caster angle shouldn't change, if it does it will only be a little. The adjusters I had fitted move the camber and caster at the same time, which was a nightmare. If the caster is wrong it will make the car feel unstable and I was glad to get them off. I did alot of suspension mods on my Mondeo (hatchback) and despite the size it handled like a go-kart! If you're fitting them yourself watch those pinch bolts! Quote Link to comment Share on other sites More sharing options...
paule3d Posted March 31, 2015 Author Report Share Posted March 31, 2015 Thanks a lot. yeah the pinch bolts, I've had a couple snap....getting used to it now! And the captive subframe bolts!I dropped the subframe recently on 2 mondeos (I have an ST200 hatch for spare parts (and hopefully recon the engine) for the 24 estate), no problems dropping both subframes. It was putting the damn thing back. 3 of the 4 subframe bolts started spinning... now I have holes cut in both footwells and 1 near the washer bottle...lol Quote Link to comment Share on other sites More sharing options...
Rich Posted March 31, 2015 Report Share Posted March 31, 2015 Thanks a lot. yeah the pinch bolts, I've had a couple snap....getting used to it now! And the captive subframe bolts! I dropped the subframe recently on 2 mondeos (I have an ST200 hatch for spare parts (and hopefully recon the engine) for the 24 estate), no problems dropping both subframes. It was putting the damn thing back. 3 of the 4 subframe bolts started spinning... now I have holes cut in both footwells and 1 near the washer bottle...lol Been there done that! I still miss that car Quote Link to comment Share on other sites More sharing options...
Tony Posted April 1, 2015 Report Share Posted April 1, 2015 Edit: I misread the post and thought you said camber not castor The castor will stay the same unless you change the cars rake. Lower at the rear would increase castor, higher at the rear will decrease it. Quote Link to comment Share on other sites More sharing options...
paule3d Posted April 1, 2015 Author Report Share Posted April 1, 2015 Thanks Tony. Car looks nice Rich! What happened to it? Quote Link to comment Share on other sites More sharing options...
Rich Posted April 1, 2015 Report Share Posted April 1, 2015 I broke it and it went to car heaven! I was getting problems with the electrics and wanted a change. Quote Link to comment Share on other sites More sharing options...
Tony Posted April 2, 2015 Report Share Posted April 2, 2015 Must say she did look good for an old lady. Quote Link to comment Share on other sites More sharing options...
