TheBoy Posted April 7, 2007 Report Share Posted April 7, 2007 Mrs TheBoy's little Rover 25 I think has a problem. Steering wheel offline, and high (but even) wear on the fronts. Generally, I am happy with the handling, and the (until recently) tyre wear, which has been even across the tyre. Should I take it to a local tyre place for cheapo tracking/4 wheel alignment, or should I get a proper geometry check done? Quote Link to comment Share on other sites More sharing options...
Tony Posted April 7, 2007 Report Share Posted April 7, 2007 Good question. Assuming the car has limited compensator's then a global measurement would be a wast of money, unless diagnostics is an intention. Linear toe has the ability to establish the thrust angle......Explained here http://www.wheels-inmotion.co.uk/forum/ind...p?showtopic=118 If this angle is observed then the exact steering centre will be realised. Quote Link to comment Share on other sites More sharing options...
